04/08/2025 at 14:01 #3669
With the advancement of the "dual carbon" strategy and the enhancement of people's environmental awareness, more and more families have begun to pay attention to and invest in the construction of photovoltaic power generation. Among the many brands and models of photovoltaic components, Jinko Tiger series photovoltaic panels have gradually become a popular choice for home users due to their excellent performance and good market reputation. So, why should you choose Tiger series panels for home photovoltaics? The following eight reasons will give you a comprehensive analysis.
1. High conversion efficiency, improve power generation income
Jinko Tiger series photovoltaic panels use efficient multi-busbar (MBB) technology, half-cell design and N-type or P-type high-efficiency cells (such as TOPCon, PERC, etc.) to greatly improve the conversion efficiency of components. The photoelectric conversion efficiency of some models can exceed 22%, which is much higher than the 20% efficiency level of many ordinary components on the market.
This means that under the same roof area, the Tiger series can output more electricity, improve the power generation income of the overall system, and bring higher return on investment to families. It is especially suitable for residential users with limited roof space but high demand for power generation.
2. Excellent low-light performance, stable output even on cloudy days
A practical problem faced by home photovoltaic systems is the uncertainty of lighting conditions, such as low-light environments such as cloudy days, overcast days, early mornings or evenings.
Tiger panels perform particularly well in low-light environments. Thanks to its advanced cell technology and high-transmittance packaging materials, this series of panels can still maintain stable output power under low irradiation conditions. This advantage ensures a more balanced power generation performance throughout the year and improves the stability and economy of the overall system.
3. Reliable weather resistance and anti-PID performance to ensure long-term use
Home photovoltaic systems are long-term investments, and a system usually has a service life of more than 25 years, so the durability of the components is crucial. Jinko Tiger series components have undergone rigorous environmental tests such as salt spray, ammonia, sand and dust, and humidity and heat, and have excellent anti-aging capabilities.
At the same time, this series of products adopts a low-voltage working design to effectively reduce the potential induced degradation (PID) phenomenon and ensure the long-term stability of the cell performance. Even when used in high temperature and humidity or seaside salt spray environments, it can maintain excellent performance, which is very suitable for home users in climate-changing areas such as southern China and coastal areas.
4. Beautiful and elegant, improving the overall texture of the roof
The Jinko Tiger series not only focuses on performance optimization, but also puts a lot of effort into the exterior design. Whether it is the all-black series or the silver frame high-contrast design, it shows the integration of technology and aesthetics. For modern homes, photovoltaic modules are not only an energy system, but also a roof decoration element.
The neat and uniform arrangement, combined with the simple and powerful design language of the Tiger series, will not only not destroy the beauty of the roof, but will enhance the overall architectural texture, becoming a green and environmentally friendly solution that is both beautiful and practical.
5. Double-sided power generation design to further increase power generation
Some Jinko Tiger series models adopt a double-sided double-glass design, with front + back double-sided power generation capabilities. In a home photovoltaic system, if it is installed on a white roof, a balcony with high ground reflectivity, or a sunshade roof with plenty of sunshine, the back can get an additional 10%~25% of light, thereby effectively increasing the overall power generation.
This technology is particularly suitable for installation on open carports, glass sun rooms, terraces or courtyard trellises. It is not only practical, but also brings more electricity benefits and improves the efficiency of household energy utilization.
6. Longer warranty period and stable attenuation rate to ensure investment value
Jinko Tiger series modules usually provide a 25-year linear power output warranty, with power attenuation of less than 1% in the first year and no more than 0.4% per year thereafter. After 25 years, they can still maintain at least 87.4% of the initial power. This data is significantly better than the 82.5% power retention level of most standard modules on the market in 25 years.
In addition, some models also provide up to 15 or even 20 years of material and process warranty, which fully reflects the manufacturer's confidence in product quality and also provides long-term use for users.
7. Mature technology, suitable for various inverters and installation scenarios
Jinko Tiger series modules have a wide range of compatibility and are suitable for mainstream photovoltaic inverters and system platforms on the market. Whether it is a centralized, string, or micro-inverter system, it can be easily connected.
At the same time, this series of products is suitable for a variety of roof structures, whether it is a pitched roof, a flat roof, or a color steel tile, asphalt tile, or a concrete roof, it can be easily installed to meet the residential building structure and use requirements in different regions of the north and south. Reasonable control of module weight also helps to reduce the burden on the roof and improve construction efficiency.
8. Reliable mass production capacity and good market reputation
Tiger series components have been widely deployed in many large-scale photovoltaic projects, industrial and commercial photovoltaic systems and distributed home applications around the world, with a huge cumulative shipment volume. The mature production line management, automated manufacturing process and strict quality control system behind it provide a solid guarantee for product stability and consistency.
From the perspective of end-user evaluation, the Tiger series has excellent performance in reliability, power generation performance, after-sales service, etc., and is widely recognized by the market. It is the preferred brand model for many photovoltaic engineering companies and home users.
In the current era of energy structure adjustment and green transformation of families, deploying an efficient, stable and beautiful photovoltaic system can not only bring long-term electricity savings and economic returns to families, but also reflect a sustainable lifestyle.
Tiger series photovoltaic panels, with their superior performance, excellent design, reliable quality and wide applicability, have become the ideal choice for many home users. Whether you are a novice who is installing a photovoltaic system for the first time, or a senior user who pursues higher power generation efficiency, the Tiger series can bring confidence and guarantee to your home energy solution.
If you are looking for a home photovoltaic module with reliable performance, excellent efficiency and long service life, the Jinko Tiger series will be a trustworthy answer. As an exporter of Jinko Tiger solar panels, JA TECH has always been committed to bringing efficient and reliable photovoltaic solutions to home users around the world. We not only provide Tiger series modules with excellent performance, but also provide customers with one-stop services from selection, customization, transportation to after-sales. Whether it is a home rooftop photovoltaic system or an industrial and commercial distributed project, JA TECH can tailor the best energy solution according to customer needs to help achieve a green and low-carbon life.
http://www.janewenergy.com
janewenergy -
