12/10/2026 at 10:12 #6250
A large-scale commercial and industrial energy storage project — typically several megawatt-hours or more — carries a different risk profile from a single small building installation, since the equipment, the installation logistics, and the ongoing performance all scale up together, and a supplier that performs well at a smaller scale does not automatically translate that reliability to a multi-container, multi-megawatt-hour deployment.
MPMC’s Documented Large-Scale Deployment History
MPMC’s HBD-A Series has a specific documented track record at exactly this scale: an 8 MWh installation in Hungary combining HBD-500-1000 and HBD-1000-2000 units for frequency regulation, peak shaving, and load balancing; an 8 MWh grid-connected frequency-management installation in the Netherlands built from four 2 MWh HBD-A units; and a separate 8 MWh delivery to a European customer using dual-PCS HBD-1000-2000A containers, each holding 45 CATL cell packs across nine high-voltage cabinets, shipped in 20-foot high-cube containers with C4-rated anti-corrosion coating and IP55 ingress protection.
MPMC HBD-A Series containerised battery energy storage system, representative of the 8MWh-scale installations delivered to Hungary and Netherlands C&I customers.
Project
Location
Scale
Configuration
Application
Green Power Plant
Hungary
8 MWh
HBD-500-1000 x2 + HBD-1000-2000 x3
Frequency regulation, peak shaving, load balancing
Grid-Connected FM Storage
Netherlands
8 MWh
4 x 2 MWh HBD-A units
Grid frequency management
Grid-Connected Peak-Shaving
Netherlands
3.2 MWh
Mixed HBD-A and HBD-R
Peak-shaving for C&I load
8MWh BESS Delivery
Europe
8 MWh
5 x HBD-1000-2000A, dual-PCS, 45 CATL packs each
Large-scale C&I storage
Wellhead Peak-Shaving
China
3 MW
2C, 500kW/250kWh x6 sets
Industrial peak-shaving
Why Documented Scale Matters More Than a General Capability Claim
Any manufacturer can state that its product line theoretically scales to multiple megawatt-hours by adding more containers, but the practical challenges of a large-scale project — coordinating dozens of high-voltage cabinets under one EMS, managing thermal performance across multiple liquid-cooled units operating together, and shipping and installing several 20-foot containers to a single site — are only genuinely proven by a delivered project of comparable scale. MPMC’s four documented 3-8 MWh projects across Hungary, the Netherlands, and elsewhere in Europe give a large-scale buyer specific, checkable reference points rather than a theoretical scaling argument.
MPMC HBD-A Series containerised battery energy storage system, part of the documented multi-container installations supporting MPMC’s large-scale C&I project references.
Technical Considerations Specific to Large-Scale Projects
At multi-megawatt-hour scale, a buyer should confirm how the manufacturer’s EMS coordinates multiple containers as a single dispatchable asset rather than several independent units, how the dual-PCS architecture used in MPMC’s 8 MWh European delivery manages load-sharing and redundancy if one PCS requires maintenance, and what site preparation and grid-interconnection support the manufacturer provides beyond the equipment itself, since a large-scale project’s civil and electrical integration work is often a bigger practical undertaking than the battery containers alone. It is also worth asking how commissioning is sequenced across multiple containers arriving at slightly different times, since a large project rarely has every unit land on site simultaneously and a manufacturer with genuine large-scale experience should have a clear answer for staged commissioning.
Where MPMC Sits Against Other Chinese Suppliers for Large-Scale Projects
Some Chinese storage manufacturers can quote a large-scale project on paper without a documented delivery of comparable scale, which leaves a buyer relying on the supplier’s own projections rather than a verifiable precedent. MPMC’s specific, named 3-8 MWh project references across three European markets give a large-scale buyer a stronger basis for supplier due diligence than a general product catalogue, and a buyer should ask any competing supplier for equally specific project references rather than accepting a general assurance of large-scale capability.
Questions to Ask When Sourcing a Supplier for a Large-Scale C&I Project
• Request documented project references at a scale comparable to your own requirement, not smaller installations
• Confirm how the EMS coordinates multiple containers as a single dispatchable asset
• Ask about redundancy and load-sharing architecture across multiple PCS units
• Verify what site preparation and grid-interconnection support is included beyond the equipment
• Confirm container-level certifications (coating rating, ingress protection) suit your project’s climate and site conditions
• Ask for a reference contact at one of the supplier’s comparable-scale delivered projects
https://www.mpmc-group.com/
MPMC Powertech Corp. -
