13/11/2026 at 17:26 #6585
Air suspension systems are widely used in modern transportation and industrial equipment because of their ability to provide adjustable support, maintain vehicle height, and improve vibration control. From passenger cars and heavy-duty trucks to trailers, buses, and industrial machinery, these systems rely on several interconnected components to deliver consistent performance.
Unlike traditional suspension systems that mainly use metal springs, air suspension technology utilizes compressed air to support loads and regulate suspension movement. However, achieving reliable operation requires more than simply installing an air spring. Compressors, shock absorbers, control valves, sensors, and pneumatic connections all play important roles in the overall system.
For automotive distributors, vehicle maintenance companies, and fleet operators, understanding these components can make product selection, replacement, and system maintenance more efficient.
VKNTECH, operated by Guangzhou Viking Auto Parts Co., Ltd., specializes in air springs, shock absorbers, and air compressors for passenger vehicles, commercial transportation, and industrial applications.
Essential Components of an Air Suspension System
An air suspension system consists of several functional parts that work together to support vehicle weight, regulate air pressure, and control suspension movement. Understanding the purpose of each component is important when selecting replacement products.
1. Air Springs for Load Support and Height Adjustment
Air springs are fundamental components of an air suspension system. They use compressed air contained within reinforced rubber bellows to support vehicle loads and absorb road-induced movement.
By adjusting internal air pressure, the system can change suspension height and adapt to different loading conditions. This provides greater flexibility compared with conventional steel coil springs.
Air springs are available in several structural configurations depending on their intended applications:
Sleeve air springs are commonly found in truck, trailer, and cabin suspension systems.
Double convoluted air springs feature two bellows sections and are used in commercial vehicles and industrial equipment.
Triple convoluted air springs provide alternative structural configurations for applications requiring specific load and movement characteristics.
Passenger car air springs are developed for vehicle-specific suspension assemblies and installation requirements.
When purchasing replacement air springs, buyers should pay attention to product dimensions, mounting configurations, original equipment numbers, and vehicle compatibility.
2. Air Suspension Compressors for Pressure Supply
The air suspension compressor is responsible for generating and supplying compressed air to the system. It works in coordination with electronic controls, sensors, and valve assemblies to maintain the required pressure and vehicle height.
When a suspension system needs additional air, the compressor provides the necessary pressure to adjust the air springs. If the compressor develops a fault or cannot generate sufficient pressure, the suspension may respond slowly or fail to reach its intended height.
Several technical factors should be checked when choosing an air suspension compressor:
Original equipment part number and reference information.
Vehicle manufacturer, model, and production year.
Electrical requirements and specifications.
Compressor mounting structure.
Air outlet and connection configuration.
Compatibility with the vehicle's existing suspension control system.
VKNTECH supplies passenger car air compressors for different vehicle applications, including replacement solutions associated with Mercedes-Benz and other premium automotive platforms.
3. Shock Absorbers for Controlled Suspension Movement
While air springs provide load support, shock absorbers serve a different purpose. Their main function is to control excessive suspension movement and reduce continuous oscillation after the vehicle encounters uneven road surfaces.
In an air suspension assembly, shock absorbers work together with air springs to maintain more controlled vehicle movement and improve suspension response.
Depending on the vehicle's original design, some passenger car applications use integrated air spring and shock absorber assemblies.
For replacement purchases, it is important to verify damping configuration, mounting dimensions, vehicle application, and original equipment references to ensure proper compatibility.
4. Control Valves and Height Sensors
Air valves and height sensors help regulate the operation of an air suspension system.
The valve assembly controls the direction and distribution of compressed air between the compressor, air springs, and other pneumatic components. Height sensors measure the relative position between the vehicle body and suspension structure.
Based on sensor signals, the electronic control unit can determine whether the suspension needs to increase or decrease its height.
These components are particularly important in systems featuring automatic ride-height adjustment. Malfunctioning valves or inaccurate sensor signals may lead to uneven vehicle height, incorrect suspension responses, or excessive compressor operation.
Therefore, replacement components must meet both physical installation requirements and electronic system compatibility standards.
5. Air Lines, Connectors, and Supporting Accessories
Air lines and fittings form the connection network between the compressor, valves, and air springs. They allow compressed air to travel through the system and maintain the required pneumatic connections.
Over time, damaged tubing, loose fittings, or deteriorated seals can cause air leakage and pressure loss. These issues may affect suspension performance even when the main components remain functional.
For this reason, air lines and related accessories should be inspected during routine maintenance and when replacing major air suspension components.
How Air Suspension Components Coordinate During Operation
The performance of an air suspension system depends on the cooperation of its individual components. Each part contributes to a different stage of the operating process.
Air Pressure Generation: The compressor produces compressed air when the system detects a need for pressure adjustment or vehicle height correction.
Air Distribution: The valve assembly directs the compressed air to the appropriate air springs according to the system's control requirements.
Load Support: The air springs use internal air pressure to support vehicle weight and maintain the required suspension height.
Suspension Movement Control: Shock absorbers regulate suspension oscillation and work alongside the air springs to manage movement during driving.
Position Monitoring: Height sensors continuously provide position information to the electronic control system, allowing appropriate adjustments when necessary.
Because these components operate as an integrated system, selecting compatible replacement parts is essential. Products that appear similar in shape or dimensions may still differ in pressure requirements, mounting structures, or electronic specifications.
Air Suspension Applications Across Different Industries
Air suspension technology serves a wide range of transportation and industrial requirements. The design and configuration of the components vary according to vehicle structure, load conditions, and operating environments.
Passenger Vehicles
Premium passenger cars commonly use air suspension systems to provide adjustable ride height and controlled suspension characteristics.
Typical replacement products include passenger car air springs, air suspension struts, compressors, and related assemblies.
VKNTECH provides passenger car air suspension products for applications associated with Mercedes-Benz, BMW, Audi, Porsche, Land Rover, and other vehicle platforms.
Trucks and Trailers
Commercial trucks and trailers frequently operate under changing load conditions. Air springs help support these loads while maintaining the required suspension height.
Depending on the vehicle design, common replacement components include truck air springs, trailer air springs, lifting axle air springs, and shock absorbers.
Buses and Driver Cabin Suspension
Bus suspension systems use air springs to support vehicle weight and manage road vibration. Cabin air springs are installed between the driver's cabin and the chassis to help reduce vibration transmitted from the vehicle frame.
Seat air springs are another specialized product category used in commercial vehicle seating applications.
Industrial Machinery
In industrial environments, air springs are used for vibration isolation and pneumatic movement applications.
Their selection depends on factors such as load capacity, operating pressure, installation dimensions, and required movement characteristics.
Important Considerations When Purchasing Replacement Air Suspension Parts
Choosing the correct replacement component requires more than comparing product appearance. Automotive distributors, repair workshops, and fleet maintenance businesses should consider several technical factors before placing an order.
Check Original Equipment Numbers
Original equipment references provide an important starting point for identifying suitable replacement products. Part number cross-referencing helps narrow down compatible options.
Confirm Vehicle Compatibility
Always verify the vehicle brand, model, manufacturing year, axle position, and suspension configuration. Similar vehicle models may use different suspension components.
Compare Installation Dimensions
Important measurements include air spring height, bellows diameter, piston dimensions, mounting-hole positions, and air inlet locations. Accurate dimensional matching helps avoid installation problems.
Understand Operating Conditions
Load requirements, working pressure, suspension travel, and operating height should all be considered when selecting an appropriate component.
Evaluate Manufacturing Quality
The quality of rubber materials, reinforcement layers, metal structures, sealing components, and manufacturing processes can influence product durability and operational reliability.
For wholesale buyers and distributors, additional considerations include product model coverage, supply consistency, technical assistance, and after-sales support.
VKNTECH: Air Suspension Manufacturing for Diverse Applications
VKNTECH, operated by Guangzhou Viking Auto Parts Co., Ltd., has been engaged in the research and manufacturing of air springs, shock absorbers, and air compressors since 2009.
The company operates a 30,000-square-meter production facility and has developed a product portfolio covering more than 1,500 models for different air suspension applications.
Its product range includes commercial vehicle air springs, passenger car air suspension springs, passenger car air compressors, convoluted air springs, industrial air springs, and air lift and air ride kits.
This product coverage enables VKNTECH to serve different purchasing requirements across the automotive aftermarket, commercial transportation sector, and industrial equipment market.
For distributors, wholesalers, and vehicle service providers, understanding the specifications and intended applications of each component is an important step toward selecting suitable products.
An effective air suspension system relies on the combined performance of air springs, compressors, shock absorbers, control valves, height sensors, and pneumatic accessories. Each component has a distinct responsibility, and their compatibility directly influences overall system operation.
Whether the application involves passenger cars, commercial trucks, trailers, buses, or industrial machinery, selecting replacement parts according to original specifications and actual operating requirements helps maintain reliable suspension performance.
With an extensive range of air suspension products and more than 1,500 developed models, VKNTECH provides component solutions for different vehicle and industrial applications, supporting distributors and business partners in meeting diverse market demands.
https://www.vkairspring.com
Guangzhou Viking Auto Parts Co.,Ltd. -
