14/10/2025 at 17:51 #4051
https://www.bodhicollector.com/central-cartridge-downdraft-bench.html
The HCD-T1 Central Cartridge Downdraft Bench, developed by Wuxi BODHI Environmental Technology Co., Ltd., is a precision-engineered workstation designed to provide efficient dust and fume collection directly from the working surface. Its design integrates structural durability, ergonomic form, and superior filtration performance to create a cleaner, safer, and more comfortable industrial workspace.
Design Elements
The HCD-T1 downdraft bench is built with a robust welded steel frame that ensures mechanical strength and long-term reliability. The surface of the bench is flat and perforated, allowing air to flow evenly across the work area for consistent suction performance. Its rectangular, space-efficient structure makes it easy to integrate into existing production lines or individual workstations.
The overall dimensions of the HCD-T1 are optimized to accommodate a wide range of industrial tasks, from grinding and polishing to welding and material finishing. The table height and working area are ergonomically designed to support comfortable operation, minimizing operator fatigue during extended use. The powder-coated finish provides resistance to corrosion and wear, maintaining a clean and professional appearance over time.
Central Cartridge Filtration System
At the heart of the HCD-T1 lies its central cartridge filtration system, engineered for high filtration efficiency and low maintenance. The cartridge filters are made from high-quality polyester or nano-fiber materials, capable of capturing fine dust particles and fumes with exceptional precision.
The filtration process begins as contaminated air is drawn downward through the bench surface, where particles are trapped within the cartridge media. Clean air is then discharged back into the workspace or ducted out as required. The pulse jet cleaning system (optional on certain models) automatically removes accumulated dust from the filter surface, ensuring consistent airflow and extending filter life.
Downdraft Airflow Technology
The HCD-T1 uses a powerful downdraft airflow mechanism, which directs suction downward through the perforated tabletop. This design effectively prevents dust, smoke, and airborne particles from spreading into the operator’s breathing zone. The result is a localized air extraction system that keeps the workspace free from contamination, improving both safety and air quality.
The balanced airflow distribution ensures that even lightweight dust and fine particulates are quickly captured. This makes the HCD-T1 ideal for processes such as manual grinding, sanding, polishing, or cutting—applications that typically generate high dust concentrations.
Accessories and Options
The HCD-T1 downdraft bench can be customized with a variety of accessories and optional configurations to meet specific application needs. These include:
Adjustable side and back panels to contain dust and optimize airflow direction.
Noise-reducing enclosures for a quieter working environment.
Integrated lighting systems for improved visibility during precision work.
Heavy-duty casters or fixed legs for flexible installation.
Custom table dimensions and filter materials to match unique process requirements.
The HCD-T1 Central Cartridge Downdraft Bench combines durable construction, intelligent airflow management, and advanced filtration technology into one integrated system. Designed and manufactured by Wuxi BODHI Environmental Technology Co., Ltd., it offers a professional and efficient solution for dust control across a wide range of industrial operations. By capturing contaminants at the source, the HCD-T1 not only protects workers’ health but also enhances overall productivity and workplace cleanliness.
Wuxi BODHI Environmental Technology Co., Ltd. -
