30/06/2025 at 14:09 #3368
In modern packaging production, labeling is an indispensable part of product visual identification, compliance management and brand marketing. The automatic self-adhesive labeling machine is widely used in many industries such as food, beverage, daily chemical, medicine, electronics, etc. due to its high efficiency, precision and high degree of automation. As product forms become more and more diversified, many companies encounter a common problem when using labeling equipment: Can the automatic self-adhesive labeling machine be attached to irregular surfaces? This article will focus on this core issue and comprehensively analyze the adaptability and coping strategies of the automatic self-adhesive labeling machine when facing irregular surfaces from the aspects of labeling principles, equipment construction, technical difficulties, solutions and application examples, so as to help companies better select and use labeling equipment.
1. What is an irregular surface?
In the field of packaging equipment, "irregular surface" usually refers to the surface of the product with curved, inclined, concave and convex, elliptical, triangular, conical or other non-standard geometric structures. Common irregular packaging containers include:
Special-shaped plastic bottles (such as elliptical, conical, and curved)
Polygonal glass bottles
Bottles with convex or concave patterns
Asymmetric spray cans
Multi-sided packaging boxes, etc.
These surfaces are more difficult to label than standard round bottles and square bottles, and they place higher requirements on labeling accuracy, flexible adjustment, and equipment stability.
2. The basic working principle of the automatic self-adhesive labeling machine
The automatic self-adhesive labeling machine mainly completes the labeling action through the following processes:
Product positioning: The product is conveyed to the labeling position by the conveyor belt and is kept stable by the bottle separation or positioning device.
Label peeling: The label roll passes through the peeling plate and the label is separated from the base paper.
Labeling execution: The labeling head accurately attaches the label to the product surface.
Fitting and compaction: The label is compacted with the surface by a roller or brush to avoid bubbles or wrinkles.
The smooth operation of this series of actions is based on the stability of the product surface and the fit between the label and the surface. The irregular surface breaks this "balance" and increases the difficulty of labeling control.
3. Technical challenges of labeling on irregular surfaces
Uneven surface contact
Irregular curved surfaces can easily cause insufficient contact between the labeling head and the product surface, especially for local convex or curved areas, where it is difficult for the labeling head to achieve complete contact, which can easily cause loose labeling or position offset.
Wrinkled or warped labels
When labels are attached to curved surfaces or surfaces with large angle changes, the labels often wrinkle, bubble or edge warping due to uneven force, affecting the appearance and adhesion.
Difficult identification and positioning
Irregular bottle shapes may cause the photoelectric sensor to be unable to accurately identify the product position, or make the labeling position inconsistent, thereby affecting the labeling accuracy.
Adapting to the conflict between speed and stability
In the process of automated labeling that pursues efficiency, the labeling head runs at high speed while adapting to changes in shape, which can easily cause unstable labeling and reduce the qualified rate of finished products.
4. How does the automatic self-adhesive labeling machine deal with irregular surfaces?
Although irregular surfaces increase the difficulty of labeling, with the development of labeling technology, modern automatic self-adhesive labeling machines have a number of technical means to deal with irregular surfaces:
Multi-dimensional labeling head design
Advanced labeling equipment is equipped with a multi-axis labeling head with adjustable angle, height and pressure, which can adjust the exit angle according to the surface characteristics of the product to achieve more accurate fitting. This flexible structure can better maintain the labeling quality when fitting curved bottles, conical bottles and other special-shaped containers.
Flexible labeling device
After labeling, a flexible roller or silicone pressure wheel is used to compact the label at multiple angles and multiple stages, so that the label is more compliant to the curved surface, and even on the undulating surface, it can achieve bubble-free and non-warping attachment.
Intelligent visual positioning system
Some high-end models are equipped with CCD visual positioning system or laser sensor, which can adjust the labeling position and angle in real time by intelligently identifying the product position and shape, greatly improving the accuracy of labeling of special-shaped products.
Customized fixtures or support molds
For special bottle types, equipment manufacturers can customize clamping molds, positioning blocks or support mechanisms to ensure the stability of the product during the labeling process and reduce labeling errors.
Multi-stage servo control system
The multi-axis servo motor controls the advancement, speed and time of the labeling action, adapts to different curvature changes, and realizes "slow first and then fast" or "multi-stage fitting", making labeling smoother and more natural.
5. Typical application examples of labeling on irregular surfaces
Cosmetics industry
Many cosmetic container designs pursue beauty, such as oval bottles, oblique-mouth bottles, and special-shaped hoses. By using an automatic labeling machine specially designed for special-shaped containers, it is ensured that the label fits smoothly on the curved surface and improves the product grade.
Medical supplies packaging
Medicinal eye drop bottles, injection ampoules, etc. often have conical or irregular bottlenecks. Using equipment that supports fine-tuning the labeling angle can effectively label and meet the compliance requirements of the pharmaceutical industry.
Food and Beverage Industry
Common irregular structures such as special-shaped juice bottles and seasoning bottles can be accurately labeled through visual assistance and customized fixtures, and ensure efficient production rhythm.
6. What should be paid attention to when choosing a labeling machine?
If the company's products contain a large number of irregular surfaces, the following points should be considered when purchasing labeling equipment:
Consult whether it supports special-shaped bottle labeling;
Confirm whether the labeling head has multi-angle adjustability;
Evaluate whether it can be equipped with a visual recognition system;
Whether customized molds or fixtures can be provided for different bottle types;
Understand whether the equipment manufacturer has successful cases of irregular labeling;
Request trial samples to verify the labeling effect.
Can automatic self-adhesive labeling machines label irregular surfaces? The answer is: Yes, but you need to choose the right equipment and technical configuration.
Modern automatic self-adhesive labeling machines can cope with a variety of irregular surface labeling needs through structural upgrades, intelligent identification and flexible control. Whether it is a small batch of special-shaped bottles or a large-scale automated production line, as long as you choose a matching solution, you can achieve high-quality labeling effects.
For enterprises, understanding the characteristics of product packaging, clarifying labeling requirements, and choosing customized solutions from professional manufacturers are the key paths to cope with the challenges of labeling on irregular surfaces. In the future, with the further integration of artificial intelligence and mechanical control technology, automatic labeling will continue to make breakthroughs in flexibility and intelligence, providing a better labeling experience for complex packaging products.
If you need to customize labeling solutions or equipment selection recommendations for your company's specific products, please contact us. We are a professional automatic self-adhesive labeling machine supplier , dedicated to providing efficient, accurate and stable labeling solutions for various industries. Whether it is a conventional bottle shape or a special-shaped, irregular surface, we can help customers achieve high-quality labeling effects through advanced equipment technology, flexible labeling structure and customized services. Years of industry experience have enabled us to respond quickly to customer needs and provide one-stop services from solution design, equipment selection to after-sales support, helping companies improve packaging efficiency and product competitiveness.
http://www.beiltpack.com
Shanghai BEILT Machinery Equipment Co., Ltd -
