24/02/2026 at 02:00 #4672
In the demanding world of industrial compressed air systems, reliability isn't just a preference—it's an absolute necessity. Downtime is costly, and the integrity of every component is critical to maintaining seamless, efficient, and safe operations. At the heart of maintaining this integrity for your ATLAS COPCO OIS280KW compressor is a vital component: the Oil Stop Valve. RUNGO presents the genuine ATLAS COPCO 3001172200 OIS280KW Oil Stop Valve Kit, a precision-engineered solution designed to ensure your compressor operates at its peak, with zero compromises on performance or longevity.
This comprehensive product description delves into the importance of this specific kit, its technical specifications, the crucial role it plays within your compressor system, and why sourcing this genuine part from RUNGO is the definitive choice for engineers, maintenance managers, and procurement specialists.
Understanding the Critical Role of the Oil Stop Valve (Kit 3001172200)
The Oil Stop Valve is far more than a simple fitting; it is a fundamental safeguard within your ATLAS COPCO OIS280KW screw compressor. Its primary functions are pivotal:
Prevention of Oil Flooding: During compressor shutdown, this valve immediately and securely blocks the oil flow from the separator vessel back into the compressor element and the air/oil system. This prevents an excessive accumulation of oil, known as flooding, which can lead to difficult starts, potential hydrostatic lock, and severe damage to the compressor screw element.
Maintaining System Pressure Differential: It helps maintain the necessary internal pressure differentials within the lubrication circuit, ensuring that oil is delivered to bearings and gears under the correct pressure during operation and that it is retained during standby.
Ensuring Clean Start-Ups: By preventing oil from entering the compression chamber while the unit is off, the valve guarantees that on start-up, the compressor begins unloaded and clean, avoiding oil carry-over into the air network and protecting downstream equipment like dryers and filters.
Enhancing Energy Efficiency and Oil Life: A properly functioning oil stop valve minimizes oil circulation where it isn’t needed, contributing to stable operating temperatures and optimal oil life. It supports the overall energy efficiency of the OIS280KW unit by ensuring the system works as designed, without internal leaks or pressure losses.
Failure of this component can lead to a cascade of operational issues: excessive oil consumption, contaminated compressed air, increased operating temperatures, higher energy bills, and ultimately, catastrophic bearing or rotor failure. Therefore, the ATLAS COPCO 3001172200 kit is not a spare part—it is an essential maintenance item for proactive reliability programs.
Detailed Technical Specifications and Kit Contents
The ATLAS COPCO 3001172200 OIS280KW Oil Stop Valve Kit is a complete, ready-to-install assembly. It is meticulously designed to match the original part's dimensions, material properties, and performance tolerances, ensuring a perfect fit and function within your OIS280KW compressor.
Genuine Part Number: 3001172200
Compatibility: Specifically engineered for the ATLAS COPCO OIS280KW stationary screw compressor series. (Always verify your compressor model and serial number).
Kit Composition: The kit typically includes the complete valve assembly, which may consist of the valve body, piston, spring, seals, gaskets, and necessary fasteners. This all-in-one package ensures that every wearing part of the valve mechanism is replaced, restoring the assembly to like-new condition.
Material Science: Components are constructed from high-grade materials specified for the challenging compressor environment:
Body & Internal Mechanics: Manufactured from corrosion-resistant alloys and hardened steels to withstand continuous exposure to hot oil and system pressures.
Seals & Gaskets: Utilizes advanced nitrile, fluorocarbon, or other specialty elastomers compatible with compressor lubricants (mineral, synthetic, or PAO-based) and resistant to high temperatures, ensuring a perfect, lasting seal.
Performance Parameters: The valve is calibrated to operate within the specific pressure and flow ranges of the OIS280KW lubrication circuit, responding accurately to the compressor's control signals for instant opening and closing.
The RUNGO Advantage: Quality, Assurance, and Partnership
Choosing the ATLAS COPCO 3001172200 OIS280KW Oil Stop Valve Kit from RUNGO is a decision for quality, reliability, and peace of mind.
Uncompromising Quality Assurance: Every kit in our inventory undergoes rigorous verification processes. We understand that "genuine" means more than just a number—it means guaranteed material integrity, precise dimensional accuracy, and flawless performance. Our 3001172200 kit is sourced and supplied to meet or exceed the original equipment manufacturer's specifications.
Technical Expertise and Support: RUNGO is more than a supplier; we are a technical partner. Our team possesses deep knowledge of ATLAS COPCO compressors and their auxiliary systems. We provide not just the part, but also support documentation and the expertise to assist with compatibility verification and installation guidance.
Inventory Excellence & Fast Delivery: We maintain a strategic inventory of critical spare parts like the 3001172200 OIS280KW Oil Stop Valve Kit. Our efficient logistics network is designed to get this essential component to your facility quickly, minimizing your equipment's downtime risk. When you need it, we ensure it's available and on its way.
Cost-Effective Reliability: While competitive, our pricing reflects the inherent value of a genuine-quality part. Investing in the correct kit prevents the far greater costs associated with compressor downtime, secondary damage, and lost production. It is the most economical choice over the total lifecycle of your valuable OIS280KW compressor.
Commitment to Operational Safety: Using a properly specified and manufactured valve kit is a critical safety practice. It ensures the compressor's protective systems function as intended, safeguarding both your personnel and your capital asset from the risks of mechanical failure.
https://www.aircompressorpartscn.com/consumable-parts-atlas-copco/atlas-copco-3001172200.shtml
RUNGO -
