05/11/2026 at 15:08 #6502
Reliable power transfer becomes more complicated when a facility has more than one available power source. Utility power, diesel generators, photovoltaic inverters, and battery systems can all play different roles in a modern electrical installation. An Automatic Transfer Switch (ATS) provides the switching function between designated sources, but the correct ATS depends on how those sources operate.
A common industry problem is the selection of an ATS based only on rated current or voltage. A 125A transfer switch may have the right electrical rating and still be unsuitable for a particular generator or PV inverter system if the source arrangement, switching logic, or pole configuration does not match the installation.
A more practical approach starts with the relationship between the power sources.
Source Roles Before ATS Selection
The first selection question is not the current rating. It is the role of each source.
A conventional standby system usually contains utility power and a generator. Utility power remains the normal source, while the generator becomes available after a utility failure.
A solar-based system can work differently. The PV inverter may be the preferred source, while utility power remains available as an alternative source. In another installation, a battery inverter may also be involved.
These configurations require different control relationships.
System Type Primary Source Alternative Source Main ATS Concern Utility + generator Utility Generator Generator availability and transfer sequence PV inverter + utility PV inverter Utility Inverter output and source priority Generator + utility + PV System-dependent System-dependent Complete source-management strategy PV + battery + utility System-dependent System-dependent Inverter and energy-storage coordination The ATS should therefore be selected as part of the complete power architecture rather than as an isolated switching component.
Generator ATS Challenges
Generator applications have a specific operational issue: the backup source may not be immediately available when the normal source fails.
A typical Generator ATS system requires the generator to start, reach suitable operating conditions, and then accept the load. The transfer switch forms part of this sequence.
For this reason, a generator ATS should be evaluated according to more than its current capacity. Important considerations include generator voltage, frequency, phase configuration, source connection, transfer class, pole configuration, and control requirements.
A compact system may use a DIN rail automatic transfer switch, while larger installations may require a different physical arrangement.
The TOMZN 110V Automatic Transfer Switch for city power and generator applications is an example of a product positioned around utility-generator backup use. The product configuration is more relevant to generator source transfer than to PV inverter applications.
PV Inverter ATS Challenges
PV systems create a different selection problem.
A photovoltaic panel produces DC electricity, while the ATS normally operates on the AC side of the system. The PV inverter therefore becomes the relevant power source for an AC transfer switch.
The inverter output needs to match the electrical requirements of the ATS and the connected distribution system.
A PV Inverter Automatic Transfer Switch may be used to transfer between inverter power and utility power when the system requires an alternative source. In this arrangement, the utility grid can provide backup when the PV inverter is unavailable or when the system's operating conditions require grid power.
The source priority needs to be clearly defined before installation. Without a clear operating strategy, the ATS may be technically compatible with both sources while still being inappropriate for the intended system.
TOMZN's TOQ7-PV 2P DIN rail automatic transfer switch is an example of a PV-oriented ATS configuration designed around PV inverter and utility source transfer. Its application is different from a conventional generator ATS because the PV inverter is the relevant alternative power source rather than a fuel-powered generator.
The Neutral and Pole Configuration Problem
Pole count is another area where incorrect assumptions can create problems.
A three-phase installation does not automatically require either a 3P or 4P ATS. The correct configuration depends on the system's neutral arrangement and source design.
A 3P ATS switches the three phase conductors. A 4P ATS also switches the neutral conductor.
This distinction becomes important when the utility and backup source have different neutral or grounding arrangements. A project that requires neutral isolation may need a 4P configuration, while another system may be designed around a common neutral.
The issue should be confirmed by the electrical design rather than decided simply because one product has an additional pole.
For three-phase generator installations, the generator neutral arrangement deserves particular attention. The same principle applies when a PV inverter is integrated into a three-phase distribution system.
Current Rating Is Not the Whole Selection
Current rating remains essential, but it should be treated as one selection parameter among several.
A 63A ATS, 100A ATS, or 125A ATS may be suitable for different loads, but the number alone does not confirm compatibility.
The following parameters deserve review:
Rated current
Rated voltage
Frequency
Number of poles
Source type
Switching class
Transfer time
Installation method
Source priority
Load characteristics
For example, a 125A generator ATS and a 125A PV ATS may have similar current ratings while serving completely different system architectures.
A product's published voltage should also be checked carefully. Control voltage, rated working voltage, and source voltage can refer to different electrical characteristics.
A Practical Selection Process
A simple selection process can reduce purchasing errors.
Source identification
The normal and alternative sources should be clearly defined first.
Source priority
The intended preferred source should be identified. This is particularly important in PV systems where the inverter may have priority over utility power.
Electrical compatibility
Voltage, frequency, current, phase configuration, and pole count should be matched with the actual installation.
Transfer requirements
The required transfer speed and switching class should be considered according to the connected load and system architecture.
Installation conditions
DIN rail installation can be suitable for compact distribution equipment, while larger installations may require another mounting arrangement.
Protection coordination
The ATS should operate within a properly coordinated electrical distribution system. It should not be treated as a replacement for required overcurrent, surge, leakage, or other protective devices.
Generator and PV Systems Need Different Thinking
The main industry challenge is often not the ATS itself but the assumption that all backup sources behave in the same way.
A generator is a controllable mechanical power source that can normally be started when required. A PV inverter depends on the operating condition of the solar generation system and its available DC energy source.
That difference affects the transfer strategy.
A generator ATS must accommodate generator availability and startup. A PV ATS must account for inverter availability and the relationship between solar generation and utility power.
Hybrid systems can be more complicated because several sources may exist at the same time. In such projects, the ATS should be selected only after the overall source-management strategy has been established.
Better ATS Selection Through System-Level Planning
The most reliable ATS selection process begins with the power system rather than the product catalog.
For generator backup, the main questions concern generator availability, source transfer sequence, neutral arrangement, and load requirements. For PV systems, the focus shifts toward inverter output, source priority, solar operating conditions, and utility integration.
A suitable Automatic Transfer Switch therefore needs to match both the electrical ratings and the operating role of the source.
For projects requiring generator backup, a dedicated TOMZN Generator Automatic Transfer Switch can be reviewed according to the project's electrical requirements. For solar installations, a TOMZN PV Inverter Automatic Transfer Switch provides a different product direction for PV inverter and utility source transfer.
The key industry lesson is simple: ATS selection should follow the source architecture, not just the current rating printed on the product label. A clear understanding of source roles, neutral configuration, transfer requirements, and inverter or generator characteristics can reduce mismatched equipment and improve the reliability of the complete power transfer system.
http://www.tomznelec.com
浙江同正电气有限公司 -
