17/11/2026 at 16:35 #6613
Sourcing metal components from overseas can be a gamble. We often see buyers struggling with dimensional errors, poor welding quality, or missing delivery dates. As a manufacturer operating three major production bases in China, we want to share our internal Quality Control (QC) process. We believe transparency is the best way to build trust.
Here is a deep dive into how we ensure quality for our global clients:
1. Raw Material Inspection (The Foundation)
Quality cannot be welded into a bad steel plate. Before any cutting begins, our QC team verifies material certificates (Mill Test Reports). We conduct physical checks on the thickness, chemical composition, and yield strength of the steel. For our hot-dip galvanized parts, we strictly monitor the zinc bath temperature and coating thickness to guarantee anti-corrosion performance in harsh environments.2. Precision in the Fabrication Process
As a National High-Tech Enterprise, we rely heavily on automation. We use CNC machining centers and laser cutting machines to ensure tight tolerances. For heavy-duty sheet metal welded parts, our welders follow strict WPS (Welding Procedure Specifications). We perform NDT (Non-Destructive Testing) on critical structural components, like bridge steel formworks and embedded parts, to check for internal cracks or incomplete fusion.3. Multi-Stage Dimensional Checks
During production, we use CMM (Coordinate Measuring Machines) and calipers to check dimensions against your 2D/3D engineering drawings. We don't just check the final product; we check the first article (FAI) and perform random sampling during mass production to prevent mass defects.4. Surface Treatment & Final Packaging
After fabrication, parts like power iron fittings and metal accessories undergo surface treatments (hot-dip galvanizing or specialized coatings). Our final QC step involves a 100% visual inspection before applying anti-rust oil and packing them securely for ocean freight.The Result?
By maintaining ISO9001:2015 standards, we minimize rework and ensure your project stays on schedule. Whether you need complex precision machined parts or large-scale steel structures, we have the capability to build it right.We fully support OEM/ODM customization. If you have any questions about metal fabrication or need a quote based on your drawings, drop a comment or contact me directly!
Contact Info:
Contact Person: Xie Lei
Email: 441047264@qq.com
Phone/WhatsApp: +86 13607000479
Website: http://www.zlymachinery.comhttp://www.zlymachinery.com
Jiangxi Zhongliyuan Import & Export Co., Ltd. -
