20/11/2026 at 10:00 #6647
Why China Is the Global Hub for Private Label Heat Pumps Designed for Home Use
Homeowners and HVAC brands around the world are searching for a dependable China private label heat pump for home use, driven by rising demand for environmentally friendly, energy-efficient, and low-carbon heating and cooling solutions. Manufacturers and brands increasingly need flexible production partners that can deliver compliant products across different markets without independently building their own R&D and manufacturing systems. Guangzhou SPRSUN New Energy Technology Development Co., Ltd., operating under the brand name SPRSUN, has positioned itself as a professional air to water heat pump manufacturer based in China, serving the global HVACR market with a primary focus on Europe and other international markets.
A Manufacturing Heritage Built Over 27 Years
SPRSUN was founded in 1999 and began with an initial focus on solar water heaters before entering central hot water system development and application in 2003. This evolution into heat pump manufacturing reflects more than 27 years of heat pump R&D, manufacturing, and sales experience as a privately held manufacturer. In 2010, the company developed its first integrated residential air-to-water heat pump for the European market, a milestone that laid the foundation for its current home-use product lines. The company has exported products for 17 consecutive years to Europe and now supplies more than 60 countries and regions worldwide, covering Europe, Asia, Oceania, and the Americas.
Private Label Manufacturing Built Around Flexibility
For brands and businesses exploring a China private label heat pump for home use, SPRSUN offers OEM manufacturing, ODM product development and manufacturing, and private label manufacturing alongside standard product sales. This openness extends across appearance, structure, function, technical specifications, control systems, product configuration, branding, and packaging, allowing partners to bring a fully customized residential product to market under their own identity.
Operationally, this flexibility is supported by an 85,000 m² self-owned 5G smart manufacturing facility with annual production capacity over 500,000 units. Four automated flexible production lines allow model changeover within 30 minutes, which is particularly valuable for private label partners that require multiple product variants without long retooling delays. Standard product production lead time runs approximately 7–40 days after order confirmation, while in-stock samples can be dispatched within 7 days. Project-based order confirmation covers specifications, customization scope, minimum order quantity, pricing, and estimated delivery schedule, and standard products support sample orders including single units with no fixed minimum order quantity, while customized products have MOQ and pricing evaluated per project.
Home-Use Heat Pump Product Lines
Several of SPRSUN’s product lines are specifically relevant to residential, home-use applications. The Air-to-Water Heat Pumps line, using R290 and R32 refrigerants, is built for space heating, cooling, and domestic hot water in residential and commercial buildings. This line traces back to the integrated residential unit for the European market launched in 2010, which provided heating, cooling, and domestic hot water in one system. Key features include Full DC Inverter Technology with temperature control accuracy of ±0.5°C and efficiency improvement of approximately 5%–15% compared with standard inverter systems, Quiet Revolution Technology achieving sound pressure levels as low as 36 dB(A) at 1 meter, Dual-Zone Temperature Control for independent settings in two zones, and Advanced Intelligent Remote Control through Wi-Fi app connectivity, IoT cloud management, energy monitoring, and remote fault alerts.
The Multifunctional Heat Pumps line, also using R290 and R32 with a maximum outlet water temperature of 75°C, integrates space heating in winter, space cooling in summer, and domestic hot water supply throughout the year into one system—addressing the common household need to replace separate appliances for heating, cooling, and hot water while reducing installation complexity and space requirements.
For homes in extreme cold climates, particularly Northern Europe, the EVI Ultra-Low Ambient Temperature Inverter Heat Pumps use Enhanced Vapor Injection technology to improve low-temperature heating efficiency by 30% or more and support stable operation down to -30°C, aided by Smart AI Defrost and Freeze Protection. SPRSUN exported EVI heat pumps designed for operation at temperatures as low as -25°C to Northern Europe as early as 2013, and a split-type ultra-low-temperature heat pump was launched in 2018 for flexible installation.
The Domestic Hot Water Heat Pumps line, using R290 refrigerant with a maximum outlet water temperature of 75°C, provides dedicated hot water solutions for residential and commercial settings, building on the company’s involvement in central hot water systems dating back to 2003.
Quality Assurance Behind Every Private Label Unit
Private label partners rely on consistent, verifiable quality standards, and SPRSUN supports this through nine specialized laboratories covering performance, acoustic, mechanical reliability, and durability testing, along with dedicated R290 production safety systems and multi-stage quality control with 10 parallel testing stations. The laboratory environment spans an ambient temperature range of -50°C to +60°C and a water temperature range of 5°C to 80°C, with a -50°C laboratory completed in 2026 now in trial operation. Real-time testing data is recorded with barcode-linked traceable inspection reports, searchable by barcode and product ID, with Excel data export available for quality verification.
Certifications relevant to residential heat pump markets include ISO 9001, ISO 14001, and ISO 45001 management system certifications obtained in 2005, along with CE product certification, CCC certification obtained in 2012, TÜV testing per EN 14511 in 2012, TÜV A+ energy label approval in 2015, KEYMARK certification obtained in 2022, and TÜV SÜD ErP A+++ energy efficiency assessment for the latest R290 and R32 DC inverter heat pump series. Additional compliance schemes include AIT, SAA, RoHS, BAFA, ErP, MSC, and CB.
Supporting Global Partners Beyond Manufacturing
Approximately 90% of SPRSUN’s business comes from overseas markets, with Europe accounting for more than 70% of overseas business. To support international private label and OEM/ODM partners, the company provides pre-sales product knowledge training, technical consultation, installation and commissioning guidance, common after-sales technical training, spare parts support, 24-hour online service, product documentation, troubleshooting assistance, and certification coordination support. Two European customer service centers in Poland and Greece are under preparation as of October 2026, reflecting continued investment in closer regional support for European partners. The company’s headquarters will relocate to No. 10, Zhizao Avenue, Xiancun, Zengcheng District, Guangzhou, China, 511335, effective October 2026, consolidating operations within its newly completed 5G smart factory.
For brands seeking a China private label heat pump for home use, SPRSUN’s combination of long-standing manufacturing experience since 1999, dedicated home-use product lines, documented laboratory testing, and internationally recognized certifications offers a structured basis for evaluating private label and OEM/ODM partnerships in the residential heat pump sector.
https://sprsunheatpump.com/
Guangzhou SPRSUN New Energy Technology Development Co., Ltd. -
