07/09/2026 at 15:08 #5996
A Trusted Compressed Air Filter Manufacturer With ISO and CE Certification
Wuxi Yuanmei Filtration & Purification Equipment Co., Ltd., operating under the brand name Yuanmei Filtration (also known as YM Filtration), has built its reputation as a professional industrial filtration manufacturer since its founding in January 2016. Headquartered in Wuxi, Jiangsu Province—recognized as a core hub of China’s advanced manufacturing industry—the company has dedicated more than ten years to the research, development, production, and global sales of compressed air purification solutions. As a National High-Tech Enterprise and ISO 9001 certified manufacturer, Yuanmei Filtration has positioned itself as a reliable partner for industrial clients seeking energy-efficient and customized air treatment systems.
Certification and Compliance Framework
For buyers evaluating a compressed air filter manufacturer with ISO and CE certification, compliance credentials are often the first checkpoint. Yuanmei Filtration holds a comprehensive set of certifications that validate its manufacturing standards:
- ISO 9001:2015 Quality Management System Certificate, valid until December 2028, covering the design, production, and sales of compressed air filters, stainless steel filters, and filter elements.
- ISO 14001:2015 Environmental Management System Certificate, also valid until December 2028, covering environmental management across production and service processes.
- CE Certification in compliance with PED 2014/68/EU (Pressure Equipment Directive), valid for all EU member states.
- RoHS Certification, confirming compliance with restrictions on hazardous substances such as lead, mercury, and cadmium.
- GMP and FDA compliance, with stainless steel filter housing surfaces polished to Ra ≤0.8μm to meet pharmaceutical and food hygiene standards.
- ISO 8573-1:2010 Class 1 compressed air quality standard, supporting ultra-high purity requirements for semiconductor applications.
- ISO 14644 cleanroom classification compliance for pharmaceutical and biotech applications.
These certifications are complemented by the company’s status as a National High-Tech Enterprise (Certificate No. GR202432011263, valid until 2027) and a recognized Technology-Based SME, both of which confirm independent R&D capability and sustained technological innovation.
Core Product Portfolio for Industrial Air Purification
Yuanmei Filtration’s product matrix is designed to cover the full spectrum of compressed air treatment needs. The flagship ACF Series Compressed Air Precision Filters are available in a 1.6MPa standard series and a 2.0MPa/80bar high-pressure series, alongside cyclonic water separators. The ACF Series is certified to ISO 8573-1:2010 Class 0/1 standards—the highest grade in the industry—with 0.01μm ultra-fine filtration and residual oil content as low as ≤0.001ppm.
Beyond the ACF Series, the company manufactures high-efficiency replacement filter elements covering 0.01μm to 10μm precision grades, including activated carbon deodorization filter elements. Its lineup also includes industrial silencers and mufflers in threaded, flanged, and custom configurations for air compressors, vacuum pumps, and pneumatic systems, as well as air flow diffusers designed to improve drying efficiency and airflow uniformity in desiccant dryers. For clients with specialized requirements, Yuanmei Filtration offers customized filtration systems tailored to semiconductor, pharmaceutical, food and beverage, and petrochemical industries.
The ACF Series housings are constructed from aviation-grade silicon-aluminum alloy through one-step die-casting, rated for pressure resistance up to 4.0 MPa (40 bar). Internal electrophoretic coating combined with external electrostatic epoxy spraying provides multi-layer corrosion protection, while the housing design is approximately 30% lighter than traditional stainless steel filters. For extreme corrosion scenarios, 316L stainless steel or PTFE-lined housings are available, supporting continuous operation at temperatures up to 260℃.
Technical Strength Behind the Certification
Certification alone does not guarantee performance—engineering depth does. Yuanmei Filtration holds more than 32 authorized national patents, including utility model patents for backwash filters and quick-install sealing end caps. Its independent R&D team applies CFD flow simulation, material innovation, and structural optimization to reduce system energy consumption by 15–25% compared with traditional solutions. High-precision filter elements achieve 99.9999% particle interception efficiency, meeting ISO 8573-1 Class 0 ultra-high purity standards.
Quality control follows a full-process approach: raw material spectral inspection, in-process 100% online testing, and finished product verification of pressure, leakage, and filtration efficiency. Every product undergoes 100% factory inspection, and batch samples are subjected to a 1,000-hour continuous operation aging test. The company’s testing laboratory is equipped with an OIL-Check400 residual oil detector, a PC400 high-precision particle counter, and an FA510 dew point sensor, enabling independent verification of filtration accuracy, residual oil content, pressure drop, and dew point performance in accordance with ISO 8573-1.
Compatibility and Customization
Compressed air systems in the field often rely on components from a wide range of equipment brands, and compatibility is a common concern for maintenance teams. Yuanmei Filtration’s replacement filter elements are engineered for 1:1 dimensional and performance compatibility with equipment from more than 30 international compressor and dryer brands, allowing installation without pipeline modification. Products support multiple connection standards, including G thread, DN flange, and NPT, across pressure grades from 0.4 to 8.0MPa.
For specialized applications, the company provides OEM/ODM services and tailored designs covering pressure, material (304/316L stainless steel), interface, and flow requirements. The typical research and development cycle for new customized products ranges from 15 to 30 working days.
Global Delivery and After-Sales Support
Yuanmei Filtration’s business coverage extends across Southeast Asia (Vietnam, Thailand, Malaysia), South Asia (India), North America, Europe, the Middle East, and South America. Standard products are delivered within 7–15 working days, with urgent orders available in 3–5 days. Overseas warehouse layouts in Southeast Asia and Europe support local delivery within 2–5 working days.
After-sales service includes a 12–24 month product warranty, 24-hour technical support, on-site installation and commissioning guidance, and predictive maintenance reminders based on real-time performance data tracking. Global agents and distributors receive exclusive distributor authorization, technical training, and marketing material support.
Application Across Critical Industries
Yuanmei Filtration’s systems serve a broad range of industrial sectors, including semiconductor manufacturing, lithium battery production, pharmaceutical and medical sterile production, food and beverage processing, laser cutting equipment, petrochemical, and general manufacturing. In semiconductor clean room applications, its ISO 8573-1 Class 0 certified systems have supported oil content at ≤0.001ppm and particle levels at ≤0.01μm, with system pressure drop reduced by 18%. In lithium battery manufacturing, air supply and drying system upgrades have improved dust control by 40%, reduced product reject rates by 22%, and extended equipment maintenance cycles by 60%.
For industrial buyers researching a compressed air filter manufacturer with ISO and CE certification, Wuxi Yuanmei Filtration & Purification Equipment Co., Ltd. offers a documented combination of certified quality management systems, patented filtration technology, and global service infrastructure. Its ACF Series and supporting product matrix—backed by ISO 9001, ISO 14001, CE, RoHS, GMP, FDA, and ISO 8573-1 compliance—reflect a manufacturing approach built around measurable performance data rather than general claims, giving procurement teams a factual basis for evaluation.
https://www.acf-filter.com
