27/11/2026 at 10:00 #6756
Hydraulic equipment manufacturers often face the challenge of integrating multiple control functions into a compact assembly. Pumps, directional valves, pressure-control components and actuators must connect through carefully arranged hydraulic passages. The manifold block plays a central role in this configuration because it determines how fluid is distributed between different components.
When standard manifold dimensions or port arrangements do not match the equipment design, a customized solution may be necessary. A Non-standard valve block can be manufactured according to specific hydraulic circuit requirements, installation dimensions and technical drawings. However, successful customization involves more than changing the external shape. Internal flow paths, port locations, material selection, machining feasibility and inspection requirements all need to be considered as part of the same engineering process.
Begin with Hydraulic Circuit Requirements
The hydraulic circuit should be the starting point for designing a customized valve block. Before deciding its external dimensions or mounting arrangement, engineers need to understand how the block connects with the pump, tank, valves and actuators.
Common hydraulic port functions include:
P port: Receives pressurized fluid from the pump or pressure supply.
T port: Provides the return connection to the hydraulic tank.
A and B ports: Connect to the working ports of hydraulic actuators or other circuit components.
Additional control ports: May accommodate pilot pressure, drainage, measurement or other application-specific functions.
The actual port configuration depends on the hydraulic system. Some connections need to communicate through internal passages, while others must remain isolated to prevent unwanted fluid connections.
For a manifold serving several valves, engineers should review the circuit relationships before determining the drilling layout. An external port arrangement that appears convenient may create complicated internal passages or unnecessary changes in flow direction. Starting with the hydraulic schematic helps establish a functional connection plan before detailed machining dimensions are finalized.
Designing Internal Passages and External Port Locations
Internal passages are responsible for connecting the manifold's external ports and valve mounting interfaces. Their geometry influences hydraulic flow, structural integrity and manufacturing complexity.
Several factors should be reviewed during the design stage.
Passage direction and length
Unnecessarily long or indirect passages can increase flow resistance. Where the circuit allows, a more direct route may simplify the internal structure. However, passage dimensions and positioning must still comply with the hydraulic design requirements.
Cross-drilled passage intersections
Many manifold blocks use drilled channels that intersect inside the component. The position and direction of these intersections need to be carefully defined so that the intended circuits communicate without connecting passages that must remain separate.
External port accessibility
Ports should provide sufficient space for fittings, tools and hydraulic lines. Their orientation should also correspond with the surrounding machine structure and the intended hose or pipe routing.
Separation between hydraulic circuits
Pressure, return and working passages must follow the specified circuit arrangement. Adequate material needs to remain between relevant channels to meet the design's structural and sealing requirements.
These considerations become increasingly important when a block contains multiple valves and numerous internal connections. A coordinated passage layout can make the component easier to machine, inspect and integrate into the hydraulic assembly.
Balancing Compact Dimensions with Hydraulic and Manufacturing Requirements
Space limitations are common in hydraulic power units and industrial machinery. Designers may want to reduce the overall manifold dimensions to simplify equipment integration, but a smaller block is not automatically a better solution.
Moving ports closer together, for example, may reduce the external size while leaving insufficient space for fittings or internal drilling operations. Similarly, placing two intersecting passages too close to each other can affect the material thickness between channels.
A practical design review should take account of:
Required flow rates and operating pressures
Passage dimensions and hydraulic circuit specifications
Valve mounting and fitting clearance
Material thickness around internal channels
Machining access for drilling and finishing operations
Inspection accessibility for critical features
A customized Non-standard valve block allows these factors to be addressed through application-specific geometry. MAYTAG manufactures hydraulic manifold blocks according to customer drawings and technical specifications, supporting different dimensions, port configurations, material requirements and installation arrangements.
The final design should balance the hydraulic circuit's functional needs with the capabilities of the selected manufacturing process.
CNC Machining of Complex Hydraulic Passages
A valve block design must be suitable for both hydraulic operation and practical manufacturing. CNC machining is used to produce the external geometry, mounting surfaces, threaded connections and drilled internal passages according to the supplied drawings.
Cross-drilled channels are common in hydraulic manifolds. These passages may be machined from different faces of the block and may require specified plugs or closure components after drilling. Drawings should clearly indicate drilling directions, passage depths, intersection locations and closure requirements.
Machining feasibility should be reviewed before production begins. Deep holes, closely spaced channels and complex intersections can influence tool selection, machining sequence and inspection arrangements. Any proposed adjustment should be evaluated against the original hydraulic and structural requirements.
Deburring and cleaning are also essential after machining. Residual burrs or metal particles inside hydraulic passages can interfere with fluid movement or enter downstream components. Manual deburring, thermal deburring and ultrasonic cleaning can form part of the production workflow, depending on the component and project requirements.
These operations help prepare the machined block for subsequent inspection and finishing rather than treating internal cleanliness as a secondary cosmetic issue.
Selecting Materials for Hydraulic Manifold Applications
Material selection influences a valve block's mechanical properties, machining characteristics and suitability for its intended operating environment. The required grade should be determined by the customer's technical specification and the conditions in which the component will be used.
MAYTAG's listed material options include several groups:
Material category
Available grades
Ductile iron
QT500-7, QT450-12
Carbon and alloy steel
45#, Q345B, Q355D, 42CrMo
Aluminum alloy
AL6061-T6, AL6082-T6, AL7075-T6
Copper
C18000
Different materials offer different characteristics, so selection should consider operating pressure, component geometry, structural requirements and machining conditions. Surface treatment requirements should also be confirmed during the engineering review.
Material substitution should not be made without customer approval, especially when the drawing specifies a particular grade or mechanical property. Maintaining consistency between the approved material specification and the production material is important for project quality control.
Inspecting Port Geometry and Internal Passage Quality
A finished hydraulic manifold must meet the dimensional requirements of the drawing as well as any additional functional requirements defined for the application. Inspection should therefore cover the relevant interfaces and internal features, not just the external dimensions.
Typical inspection points may include:
Port positions, diameters and thread specifications
Valve mounting surfaces and hole patterns
Critical distances between reference features
Specified passage intersections and closure locations
Burr removal and internal cleanliness
Surface treatment and final appearance
Coordinate measuring machine (CMM) inspection can support the verification of specified dimensions and geometric relationships. It is particularly useful when several mounting features must maintain defined positions relative to one another.
For applications where internal passage integrity or pressure containment is critical, the project should also specify the required inspection or testing procedures. These requirements need to be agreed upon before production so that the manufacturing and quality teams can plan the appropriate checks.
MAYTAG's manufacturing workflow includes raw material inspection, CNC machining, CMM inspection, manual deburring, visual inspection, thermal deburring, ultrasonic cleaning, surface treatment, ultrasonic washing and final inspection. This sequence provides multiple stages for checking and preparing customized components.
Custom Valve Blocks for Different Industrial Sectors
Hydraulic manifold requirements vary according to equipment function, installation space and operating conditions. A valve block designed for one machine may not be directly suitable for another application, even if the two systems use similar hydraulic components.
In wind power equipment, customized manifold blocks may need to fit specific hydraulic control assemblies and mounting structures. Solar energy-related equipment can also require particular dimensions and port arrangements. Other industrial machinery may use compact manifolds with unusual connection orientations or specific material requirements.
MAYTAG's listed manufacturing range includes both compact components and larger valve blocks, with example dimensions such as 600 × 390 × 200 mm and 560 × 350 × 290 mm. The supplied product information also indicates a component weight range of approximately 1–200 kg. Actual production feasibility depends on the drawing, material, geometry and machining requirements of each project.
For equipment manufacturers, providing complete application information helps determine whether the proposed block design can be produced using the required processes.
MAYTAG's Precision Machining Background
MAYTAG WUXI PRECISION MACHINERY CO., LTD. is a family-owned precision machining company established in China in 2011. Its manufacturing focus includes hydraulic manifold blocks and customized machined components produced according to customer drawings and specifications.
The company is located in Meicun Industrial Park, Wuxi New District, and operates a manufacturing facility covering approximately 2,700 m². Its team includes more than 50 employees, supported by machining and inspection technologies for customized industrial production.
Its manufacturing development includes several milestones:
2011: Company establishment in Wuxi, China.
2015: Obtained ISO 9001 certification.
2017: Introduced lean manufacturing concepts and relocated its operations.
2018: Implemented digital factory processes.
2021: Advanced intelligent manufacturing standardization.
These initiatives reflect an ongoing focus on production organization, manufacturing management and process improvement. The company's main application sectors include wind power, solar energy and other industrial fields.
For buyers evaluating a custom machining supplier, relevant considerations include drawing interpretation, material control, machining capabilities, dimensional inspection and the ability to follow project-specific requirements.
Preparing Technical Documentation for a Custom Valve Block
A complete technical package can reduce uncertainty during quotation, engineering review and manufacturing. Before requesting production, customers should prepare the latest drawings and provide the information needed to understand the hydraulic and mechanical requirements.
Important documentation may include:
Updated component drawings with revision numbers.
Hydraulic circuit diagrams showing the required connections.
Material grades and any applicable material specifications.
Port dimensions, thread types and connection details.
Critical dimensional and geometric tolerances.
Surface treatment and finishing requirements.
Inspection criteria and any specified testing procedures.
It is also helpful to identify the features that have the greatest influence on hydraulic function and assembly compatibility. This allows the manufacturer to review machining feasibility and prioritize inspection around the most important dimensions.
Where the valve block connects with existing valves, fittings or machine structures, related interface drawings can provide additional design context. This information helps clarify port positioning, mounting relationships and available installation space.
Building a Manufacturing Plan Around the Hydraulic Design
A customized manifold block requires coordination between hydraulic circuit requirements and manufacturing details. Port locations, internal passages, material selection, drilling access and inspection methods should be evaluated together before production starts.
For equipment manufacturers that need application-specific dimensions and connection arrangements, a Non-standard valve block offers an alternative to standard manifold configurations. Drawing-based CNC machining, dimensional inspection, deburring and cleaning provide a structured approach to producing components for individual hydraulic systems.
With its experience in hydraulic manifold block machining and its manufacturing facility in Wuxi, MAYTAG WUXI PRECISION MACHINERY CO., LTD. supports customized valve block requirements for wind power, solar energy and other industrial applications. Clear technical drawings, confirmed hydraulic connections and agreed inspection standards help establish a practical foundation for manufacturing components that match their intended equipment.
http://www.wuximaytag.com
WUXI MAYTAG PRECISION MACHINERY CO.,LTD -
