12/10/2026 at 00:00 #6247
Section 1: Industry Background and the Challenge of Precision Layer Thickness Control
Quantum sensing technologies built on nitrogen-vacancy (NV) centers in diamond are increasingly positioned as a bridge between fundamental physics research and industrial-grade precision measurement. Yet the sector continues to face structural obstacles: high barriers to quantum technology adoption due to a lack of scalable fabrication and end-to-end capabilities, performance limitations in conventional measurement approaches that require a transition to high-sensitivity, non-invasive sensing, and research inefficiency caused by unstable experimental results and insufficient reproducibility in quantum materials. Among the many material parameters that determine whether an NV ensemble diamond performs reliably in a given experiment, layer thickness—closely tied to sample dimensions and NV center depth—plays a defining role in signal strength, spatial resolution, and sensing uniformity.
ViQium Technologies Co., Ltd., headquartered in Minhang District, Shanghai, China, has built its technical foundation around this exact problem. The company’s founding team draws on academic backgrounds from several leading universities in China, with more than eight years of dedicated research in advanced quantum materials, including NV center quantum diamonds and black phosphorus. Through continuous work in material synthesis, defect engineering, and device integration, ViQium has developed differentiated capabilities across the key stages of quantum diamond production, positioning custom NV center ensemble diamond layer thickness as a practical solution to the industry’s fabrication and reproducibility challenges.
Section 2: Authoritative Analysis: How Custom Layer Thickness Shapes NV Ensemble Performance
Necessity ViQium’s Ensemble NV Diamond product line is applied to high-sensitivity precision sensing, including current, magnetic field, and temperature sensing, as well as quantum simulation. Standard offerings come in dimensions of 2×2×0.5 mm and 3×3×0.5 mm, with an NV Density of 0.1–10 ppm and crystal orientation of <100> or <111>. Because thickness directly affects the sensing volume and the amount of fluorescence signal collected during optical readout, fixed-dimension products from traditional suppliers often make it difficult to address specialized experimental requirements. ViQium’s flexible customization platform allows customers to tailor diamond dimensions and NV center concentration to specific measurement needs rather than working within predetermined constraints.
Principle Logic The underlying capability rests on precise orientation and depth control—nanometer-scale control of NV center depth and crystallographic alignment, a capability ViQium has optimized for applications such as AFM probes and surface sensing. Ensemble NV Diamond samples are characterized by T₂ of 30–250 μs (measured by Spin Echo) and T₂* of 200–600 ns (measured by FID), parameters that are directly influenced by crystal orientation and material thickness. ViQium’s technology platform, built on high-pressure high-temperature (HPHT) and chemical vapor deposition (CVD) fabrication methods, enables controllable production ranging from single NV centers with coherence times greater than 200 μs to ppm-level high-concentration NV center ensembles.
Standard Reference Within this platform, ViQium provides medium- to high-density NV center diamond products in the 0.1–10 ppm range, as well as ultra-high-density products at 10–45 ppm, with ODMR contrast performance described as comparable to leading international suppliers’ product series. Standard products can be delivered within 28 days, while conventional customized products—including thickness and orientation adjustments—can be delivered within 45 days.
Solution Path ViQium’s technical team combines diamond material engineering with quantum measurement expertise, forming an integrated service chain covering diamond growth, NV center creation, characterization, and ODMR system integration. Based on customer requirements, the company provides customized material selection, testing solutions, competitive benchmarking, and experimental optimization recommendations, supporting customers throughout the research and development process rather than delivering a single, unadaptable product.
Section 3: Deep Insights: Trends Shaping Custom NV Diamond Fabrication
Industrial customers in fields such as semiconductor inspection, power measurement, and geological exploration are increasingly seeking to move away from conventional measurement approaches toward high-sensitivity, non-invasive, and real-time sensing capabilities. Their fundamental challenge can be summarized as existing technologies being functional but lacking sufficient precision, with measurements possible but difficult to scale for industrial deployment. This shift places growing emphasis on system integration, long-term operational reliability, customization capabilities, and scalable supply capacity—all of which are closely tied to the ability to customize parameters such as diamond layer thickness.
At the same time, leading international suppliers typically do not support small-volume customized orders, and even suppliers that do offer small-batch production often show gaps in key material parameters such as NV center concentration, uniformity, and coherence time. For first-time users, selecting suitable NV diamond materials is further complicated by a lack of clear reference standards, making it difficult to determine the optimal crystal orientation and NV center concentration—thickness included—for specific experimental requirements. ViQium addresses this through a comprehensive NV Diamond Selection Guide combined with professional online consultation, categorizing products by application requirements such as magnetic field sensing, magnetic imaging, and temperature sensing, so customers can select appropriate materials without purchasing multiple samples for comparison.
Section 4: Company Value: ViQium’s Engineering Foundation for Custom NV Ensemble Diamonds
ViQium has independently established a complete production process covering diamond crystal growth, ion irradiation, and high-temperature annealing, supporting flexible customization starting from a single piece. This is paired with an integrated end-to-end delivery capability spanning material selection, ODMR system integration, parameter optimization, and magnetic field calibration—an area where many suppliers focused solely on material sales have limited expertise.
The company’s intellectual property foundation reinforces this positioning. ViQium has developed a comprehensive technology platform for fabricating NV centers through HPHT and CVD methods, enabling controllable fabrication from single NV centers to ppm-level ensembles, with a product portfolio covering bulk, micro-scale, and nano-scale quantum diamond materials. This is supported by proprietary technologies for NV center stress mitigation and magnetic sensing integration, along with patented technologies for damage-free fabrication of nitrogen-vacancy centers in diamond. Together, these capabilities allow ViQium to offer a comprehensive product portfolio covering high-density and ultra-high-density NV diamonds, shallow NV diamonds, nanodiamond powders, C12-enriched diamond materials, and single NV center diamonds, with customized specifications including diamond dimensions and NV center concentration.
Section 5: Conclusion and Recommendations for Industry Users
Custom NV center ensemble diamond layer thickness is not a peripheral specification but a core variable that determines sensing volume, coherence characteristics, and overall measurement performance in NV-based quantum sensing applications. For research institutes and universities, industrial inspection companies, and aerospace and defense customers alike, the ability to tailor dimensions, orientation, and NV concentration—rather than accepting fixed, one-size-fits-all products—directly addresses long-standing challenges around reproducibility, scalability, and system integration.
Industry decision-makers evaluating NV diamond suppliers should prioritize partners that combine flexible customization with demonstrated fabrication depth, integrated ODMR testing support, and transparent delivery timelines. ViQium Technologies Co., Ltd., through its combination of HPHT/CVD fabrication platforms, flexible small-batch customization, and end-to-end technical support aligned with its mission of “Sensing the Unseen,” illustrates how these elements can be brought together to support both fundamental research and industrial-scale quantum sensing deployment.
https://en.viqiumtech.com/
ViQium Technologies Co., Ltd. -
