16/11/2026 at 09:25 #6596
Most rivet specification problems are not material problems. They are type problems. A buyer compares blind rivet types for sheet metal assembly by diameter, picks the cheapest option that fits the hole, and only discovers at the assembly station that the fastener grips metal well and tears straight through a composite panel. This guide maps the eight blind rivet designs Nantong Baojun Metal Products Co., Ltd. manufactures to the joint conditions each one was built for, using the same selection logic the factory applies when a customer sends an application.
How do you match a rivet type to the material being joined?
Start with the workpiece, not the catalogue page. When buyers compare blind rivet types for sheet metal assembly, the material being joined decides how much bearing area the rivet has to create on the blind side, and that single variable eliminates most of the range before price is discussed.
Open-end blind rivets are the default for general metal-to-metal assembly. They install from one accessible side of the workpiece, come in aluminum alloy, carbon steel, and stainless steel bodies with domed, large flange, or countersunk heads, and cover body diameters from 2.4 mm to 6.4 mm. Where access is limited and cost per joint matters, they remain the most economical choice in the range.
Thin sheet and non-metallic components need something else. On low-density material, a standard rivet concentrates pressure around the hole and can pull through. Tri-fold blind rivets open into three expanding sections on the blind side, creating a broad bearing surface that spreads the clamping load over a larger area and reduces the risk of pull-through. They are offered in all-aluminum variants and in 304 or 316 stainless steel, with waterproof versions available in both groups.
The softest substrates move the requirement again. Peel type blind rivets are designed for plastic, cardboard, and other soft materials, where the body has to spread rather than clamp hard. Choosing between peel type and tri-fold is genuinely application-dependent, and the honest answer is that a supplier should ask what the panel is made of before quoting a type.
Closed-end rivets cover a different problem entirely: joints that must resist water. A closed body helps prevent water penetration through the rivet and retains the mandrel head after installation, which makes closed end blind rivets for sealed joints the practical choice for exterior panels, enclosures, and any assembly exposed to wash-down or weather.
✅ Bottom line: Match the rivet to the material first. Open-end for metal, tri-fold for thin or low-density sheet, peel type for soft substrates, closed-end where water ingress matters.
What changes when the joint carries load, vibrates, or must stay sealed?
The material decides the family. The service condition decides the grade within that family, and this is where most cost is either justified or wasted.
Where the fastener is part of the load path, structural designs take over. Hem-Firm blind rivets and the Mono-Lock and Now-Lock heavy-duty structural range are specified when the drawing defines shear and tensile requirements the joint must hold, rather than treating the rivet as a sheet retainer. Paying for structural rivets on a non-structural cover panel is waste. Substituting standard rivets on a structural joint is a safety decision, not a purchasing one.
Where the joint vibrates but is not structurally rated, single-bulb blind rivets form a bulb-shaped expansion on the blind side and use a locking mandrel to improve mandrel retention, which helps prevent loosening and the abnormal noise that vibration produces. Double-bulb designs extend the same idea to joints that need a wider bearing area on softer or thinner panels, such as thin sheet joints where the panel itself is the weak point.
Sealing is a separate axis. Closed-end construction handles water penetration through the rivet body, and waterproof variants within the tri-fold range cover low-density panels that also sit in wet service. Buyers often treat sealing and strength as one requirement. They are not, and a joint can need one without the other.
Head style is the last variable and the easiest to overlook. Domed heads are the general-purpose default, large flange heads present a wider bearing face where the panel needs more support, and countersunk heads sit flush where surface clearance or appearance matters. The right combination is confirmed against the selected product rather than assumed from a catalogue table, because the same body diameter is not available in every head style.
✅ Bottom line: Let the service condition pick the grade. Structural for load paths, single-bulb for vibration, closed-end or waterproof variants for sealing.
Do I need a different tool for each rivet type?
Tooling follows body diameter and material more than rivet type, and the setting stroke differs between structural and non-structural designs. Baojun supplies a pneumatic hydraulic rivet gun for industrial use, and the tool specification should be confirmed against the rivet selected rather than the other way round.
Can I order a mixed range rather than one type?
Yes. Most distributors and OEM buyers order several families at once, and mixing open-end, closed-end, and tri-fold lines in a single shipment is normal. What has to be confirmed per line is material, head style, and dimensions, since not every combination exists in every size. For a distributor building a stock range, the practical starting point is the two or three types that match the local assembly base, then broaden once sell-through is known.
Do you support custom and private label production?
Baojun supports custom rivet manufacturing based on customer requirements, including design and production to a drawing or sample, and works with buyers on OEM and ODM arrangements. For peel type blind rivets for plastic parts, the substrate sample matters more than the drawing, because the failure mode depends on how the panel deforms under clamp load.
Send the application, the material stack, and the hole condition, and the Baojun team will return a written selection review within two business days: recommended type per joint, available material and head combinations, and the dimensions that need confirmation before a quotation is issued. Buyers comparing peel type blind rivets for plastic parts or closed end blind rivets for sealed joints can request samples alongside the review, so the first assembly trial is not delayed by a second round of technical questions.
Published: November 2026 | By Baojun Engineering Team, Nantong Baojun Metal Products Co., Ltd.
http://www.baojunrivet.com
Nantong Baojun Metal Products Co., Ltd. -
