10/08/2026 at 18:19 #5784
As electric vehicles continue to expand across Europe, charging infrastructure is becoming more sophisticated. While charging stations and charging cables usually receive the most attention, smaller components can also have a direct impact on the reliability of the complete charging system.
One such component is the electric lock used for EV charging connectors and charging equipment.
An electric lock helps secure the connector during the charging process and supports controlled locking and unlocking. For EV charger manufacturers, charging station operators, distributors, and system integrators, selecting the right electric lock is therefore an important part of product design.
For European companies sourcing EV charging components from China, the challenge is not simply finding a supplier. The more important task is identifying a factory with suitable products, reliable manufacturing processes, engineering capabilities, quality control, and stable supply.
Zhangjiagang UCHEN New Energy Technology Co., Ltd., also known as Youcheng Technology, focuses on high-performance charging products for new energy vehicles. Through its DUOSIDA product portfolio, the company provides EV charging products and components for different charging applications.
What Does an Electric Lock Do in an EV Charging System?
An electric lock is a compact electrically controlled locking component designed to secure an EV charging connection.
During charging, the connector needs to remain properly positioned. An electric locking mechanism can help prevent unintended release while the charging system is operating. When the appropriate release condition is reached, the charging control system can activate the unlocking function.
This makes an electric lock different from a simple mechanical locking structure. It can work together with the electrical control system of the charging equipment.
Depending on the charging product, electric locks may be used with:
Charging sockets
Vehicle inlets
AC charging equipment
Charging stations
Charging cables
Other EV charging interfaces
For European buyers, understanding how the lock integrates with the complete charging system is more important than looking at the component separately.
Why Electric Lock Quality Matters
Electric locks are relatively small compared with a complete charging station, but they may experience repeated mechanical operation throughout the product's service life.
A public charging station, for example, can be used by many different drivers. The connector may be inserted and removed repeatedly every day.
If the locking mechanism does not work consistently, it can affect the charging experience and potentially increase maintenance requirements.
A suitable electric lock should provide:
Stable locking
Reliable unlocking
Consistent electrical operation
Appropriate mechanical strength
Compatibility with the connector structure
Suitable service life
Stable performance under the intended operating conditions
For this reason, European buyers should evaluate the manufacturing quality of the lock instead of treating it as an ordinary accessory.
12V and 24V Electric Lock Options
Electrical specifications are among the first factors to check when selecting an electric lock.
Different EV charging systems may use different control voltages. Electric lock products are therefore available in configurations designed for different electrical requirements, including 12V and 24V applications.
The correct voltage should match the control circuit of the charging equipment.
Before purchasing, buyers should confirm:
Rated voltage
Operating voltage range
Current requirement
Control method
Electrical connection
Response characteristics
Compatibility with the charging system
A lock with suitable mechanical dimensions but an incompatible electrical specification may not work correctly after installation.
This is why technical communication between the buyer and factory should take place before sample approval or mass production.
Mechanical Compatibility Is Equally Important
Electrical compatibility is only one side of the selection process.
The electric lock must physically fit the intended charging connector or equipment.
European buyers should check:
Mounting dimensions
Locking pin position
Installation direction
Available installation space
Fixing method
Connector structure
Mechanical travel
For an OEM charging station project, even a small dimensional difference can affect assembly.
A professional manufacturer should therefore be able to provide technical drawings, product dimensions, and other relevant specifications to support the customer's engineering work.
Electric Locks for Type 2 Charging Applications
Type 2 is widely used in European EV charging applications, particularly for AC charging.
For manufacturers targeting European customers, Type 2 compatibility is therefore an important consideration when selecting charging components.
However, buyers should not assume that every electric lock marketed for EV charging will fit every Type 2 product.
The actual compatibility depends on the design of the connector or socket, mounting structure, electrical control system, and locking mechanism.
For this reason, it is better to select an electric lock according to the actual charging product design.
European buyers can review the DUOSIDA Electric Lock product range to examine available products and configurations.
What Makes a Good China Electric Lock Factory?
For European buyers, purchasing directly from an experienced China manufacturer can provide advantages when product customization, technical communication, and repeat production are involved.
But not every company calling itself a manufacturer has the same level of production capability.
A serious EV charging component factory should have several basic capabilities.
Product Development
The manufacturer should understand the electrical and mechanical requirements of EV charging applications.
This allows the supplier to discuss product selection based on the customer's actual application instead of simply recommending a standard catalog item.
Production Capability
The factory should have established production processes and equipment for stable manufacturing.
This becomes especially important when the customer moves from sample orders to repeat production.
Quality Control
Incoming materials, assembly processes, electrical performance, mechanical operation, and finished products should be checked according to defined procedures.
Engineering Support
When customers need changes to dimensions, voltage, mounting structure, or other specifications, engineers should be able to evaluate the requirements.
Stable Supply
A reliable factory should be able to support repeat orders and maintain product consistency across different production batches.
These capabilities are particularly important for European distributors and charging equipment manufacturers building their own product lines.
Product Advantages of a Specialized EV Charging Manufacturer
One advantage of working with a manufacturer focused on EV charging products is that the supplier understands how individual components fit into the complete charging system.
An electric lock is not an isolated product. It works together with connectors, sockets, vehicle interfaces, charging cables, and charging control systems.
Zhangjiagang UCHEN New Energy Technology Co., Ltd. focuses on high-performance charging products for new energy vehicles and has developed a broad DUOSIDA product portfolio.
The company's products cover different EV charging requirements, including charging connection devices and related charging components.
For customers that need multiple products, this broader product range can simplify supplier management and technical communication.
The DUOSIDA product portfolio provides additional information about the company's EV charging products.
Quality Control From Components to Finished Products
For small electromechanical components such as electric locks, production consistency is important.
A reliable factory should control quality throughout the manufacturing process instead of relying only on a final visual inspection.
Incoming Material Inspection
Materials and components should be checked before entering production.
This helps prevent unsuitable materials from entering the assembly process.
Assembly Control
The electric lock should be assembled according to defined manufacturing procedures.
Correct assembly is important for both electrical performance and mechanical operation.
Functional Testing
The finished product should be tested to verify whether the locking and unlocking functions operate correctly under the specified conditions.
Final Inspection
Before shipment, products should be checked for specifications, appearance, functionality, and packaging requirements.
For international B2B orders, consistent quality between batches is particularly important.
Certifications and Testing for European Buyers
Certification requirements depend on the product, application, and target market.
European buyers should therefore ask for documentation relevant to the specific electric lock model rather than relying on general claims about factory certification.
Depending on the application, buyers may need to review:
Product test reports
Material information
Quality documentation
Applicable compliance information
Factory quality management information
Youcheng Technology's main products have been tested and certified by professional authoritative institutions such as UL, CSA, TUV, BS, CE, and PSE, with IATF 16949-related automotive quality requirements applicable to relevant products.
Buyers should still verify the exact certification scope and documentation for the model being purchased.
OEM and Custom Electric Lock Solutions
Standard products are suitable for many charging applications, but some European customers require customized components.
For example, a charging equipment manufacturer may need a particular mounting structure. A distributor may require private labeling. An EV charging system integrator may have specific electrical requirements.
An experienced factory should be able to discuss possible customization in areas such as:
Voltage configuration
Mounting dimensions
Locking structure
Connector integration
Product labeling
Packaging
OEM branding
The important point is that customization should be supported by actual engineering and manufacturing capability.
A supplier that only purchases products from another factory may have limited control over technical changes.
Why Factory Experience Matters for Mass Production
Sample approval is only the beginning of a B2B cooperation.
European customers should also consider what happens after the first order.
Can the factory maintain the same specifications?
Can it produce repeat orders consistently?
Can it respond when a technical change is required?
Can it provide technical documents when needed?
Can it manage production schedules for larger orders?
These questions are important because EV charging businesses often require continuous supply rather than a one-time purchase.
An experienced EV charging manufacturer can provide a more stable foundation for long-term sourcing.
Electric Lock Applications in Europe
Electric locks can be used across different EV charging scenarios.
Public Charging
Public charging stations typically experience frequent connector operation. Reliable locking and unlocking are therefore important.
Commercial Charging
Shopping centers, parking facilities, fleet charging sites, and other commercial locations require charging equipment that can operate consistently.
Workplace Charging
Workplace charging stations may serve multiple users every day, making connector reliability important for daily operation.
Residential Charging
Residential EV charging equipment generally has lower usage frequency, but users still expect secure connector operation and convenient release.
The correct electric lock should always be selected according to the charging equipment's actual design and application.
A Practical Checklist for European Buyers
Before selecting an electric lock supplier in China, buyers can compare suppliers using the following points:
Factor Key Question Voltage Does the product match the charging system's control voltage? Compatibility Does it fit the intended connector or socket? Dimensions Are mounting dimensions suitable? Locking Is locking and unlocking consistent? Durability Can it withstand repeated operation? Testing Does the factory perform functional testing? Customization Can the supplier provide OEM or customized designs? Factory Does the company have actual manufacturing capabilities? Supply Can it support repeat production? Technical Support Can engineers assist with integration? This approach gives buyers a more realistic way to compare manufacturers.
Why Consider DUOSIDA for EV Charging Components?
Zhangjiagang UCHEN New Energy Technology Co., Ltd. is focused on high-performance charging products for new energy vehicles.
Through the DUOSIDA product portfolio, the company provides products covering multiple parts of the EV charging ecosystem.
This product-focused approach is useful for customers who need more than one charging component. Instead of treating the electric lock as an isolated accessory, buyers can evaluate it together with other charging products and consider compatibility at the system level.
For European distributors, charging station manufacturers, and EV charging equipment companies, this can simplify product development and sourcing.
The DUOSIDA official website provides further information about the company's charging products and solutions.
Final Thoughts
An electric lock may be a small part of an EV charging system, but its reliability can influence connector security, charging operation, and the overall user experience.
For European buyers, selecting the right electric lock means checking more than voltage and dimensions. Connector compatibility, locking performance, durability, testing, customization, and manufacturing consistency should all be considered.
When sourcing from China, the factory behind the product is equally important.
A capable EV charging manufacturer should have real production capabilities, engineering support, quality control, relevant testing experience, and the ability to maintain stable supply.
For European businesses developing or distributing EV charging equipment, a supplier with broader EV charging experience can also make technical communication easier.
Youcheng Technology focuses on high-performance charging products for new energy vehicles and provides EV charging components and solutions through DUOSIDA. Its electric lock products can be considered for different charging applications where controlled connector locking is required.
For buyers looking for a long-term China EV charging component partner, the most practical approach is to review the product specifications, confirm compatibility with the target charging system, request technical documentation, evaluate factory capabilities, and test samples before moving to mass production.
A reliable electric lock starts with the right product specification, but consistent performance ultimately depends on the manufacturing process behind it.
https://www.duosidaev.com/
Zhangjiagang UCHEN New Energy Technology Co., Ltd. -
