04/09/2026 at 14:38 #5989
Sourcing charging equipment from an overseas manufacturer adds a second set of questions to the technical ones. Connector standards, transport documentation, local approvals and the after-sales route all vary by destination, and they determine whether a unit that performs well on paper actually works at the receiving depot. MPMC POWERTECH CORP., established in 2008 and headquartered in Shanghai Pudong, publishes a BCH range with documented deployments in the United Kingdom, the Netherlands and Norway.
MPMC BCH Series mobile BESS charger
What Makes a Unit Deployable at the Destination
Export element
Why it decides the deployment
Published MPMC position
Connector standard
The unit must match vehicles in that market
CCS2 standard; CCS1, GB/T and CHAdeMO as options
Voltage window
Vehicle acceptance varies by manufacturer
DC output 50–1,000 V on the BCH-275-200 and above
Transport documentation
Battery carriage applies to every leg
UN38.3 listed among product compliance references
Product compliance
Determines what may be energised locally
IEC 61851, IEC 61000, IEC 62477 and IEC 62933 by model
Handling on arrival
What the depot can physically receive
880 kg to 19,800 kg by model; container loading published
Remote support
Who diagnoses a fault at distance
EMS with 4G and OCPP 1.6; remote monitoring over Ethernet
These apply by model and market, so the applicable file should be confirmed for the exact configuration and destination together with the party holding each registration.
Documented Overseas Logistics Deployments
MPMC lists a United Kingdom logistics port operation using eight BCH-275-200 units, where a weak local supply had produced ten-hour charging cycles against four-hour port runs until the units were paired with solar infrastructure. Published environmental figures record 3,457 kWh of total output, against which an equivalent 150 kW diesel generator would have consumed 976 litres of fuel and produced 3,123 kg of CO₂.
A Netherlands installation combines the BCH-275-200 with the BCH-500-1000 for a renewable-powered charging station, with a separate Netherlands reference listing a 1 MWh grid-connected station using a 500 kW / 1,000 kWh integrated unit. A Norwegian deployment is listed at 2 MWh with 500 kW per unit and CCS2 output of 360 kW at 400 A. Those figures describe those installations and their utilisation rather than a forecast for another depot.
The Recharge Route Belongs in the Order
A stored-energy charger holds energy rather than producing it, so the recharge arrangement is the one element the equipment cannot bring with it. MPMC lists AC input from grid, generator set or solar on models from the BCH-275-200 upward at 80 kW to 560 kW depending on model, plus a CCS2 DC input allowing the unit itself to be recharged from a fast-charging point at approximately one hour for the BCH-275-200.
For an export enquiry that route should be identified before the unit ships, with a fallback named. Having two available routes is what preserves availability when the primary one turns out to be unavailable at the destination.
MPMC BCH Series mobile BESS charger — containerised outdoor fast charging
Commercial Terms Worth Settling Early
MPMC states that lead times for both standard and customised products are confirmed per order against configuration and current production scheduling, and that pricing is quoted individually against specification, quantity, destination and project requirements, with sales running through direct channels and through distributor and agent networks across Asia, Africa, Oceania, the Americas and Europe.
For an overseas order that structure means the commercial questions have to be asked rather than inferred. Delivery date, shipping sequence on a multi-unit order and the notice period for specification changes all belong in the first commercial conversation rather than in a later clarification.
Conditions at the Receiving Depot
MPMC lists an operating range of −20°C to +50°C with derating above 45°C for the BCH-275-200 and above, and −20°C to +55°C with derating above 40°C for the compact models, with maximum altitude of 3,000 m and 4,000 m respectively. The BCH-275-200 is listed with C4 anti-corrosion coating and a fully sealed liquid-cooled battery pack, with C4 standard and C5 optional on the BCH-800-600.
For a decision made at distance the derated output across the destination’s actual ambient range is more useful than the peak figure, and the coating class should be selected against measured exposure at the depot rather than by country.
Life and Warranty Under Depot Utilisation
MPMC lists 6,000 cycles at 90% depth of discharge across the BCH range, with published warranty terms of 3 years or 1.6 MWh per kWh of total output for the BCH-275-200, BCH-600-400, BCH-800-600 and BCH-500-1000, battery performance at 5 years or 2.57 MWh per kWh, and end-of-life capacity retention of at least 70%. The BCH-80-70 is listed separately at 1 year or 60 MWh with a 3-year or 200 MWh battery warranty.
On a depot cycling daily the throughput allowance is normally reached before the calendar term, so expected annual energy delivered should be checked against it, and sizing run against end-of-life capacity rather than first-year capacity.
Serving Depot Loads From the Same Asset
Beyond vehicle charging, MPMC lists AC output on models from the BCH-60-70 upward, rated from 30 kW to 500 kW depending on model, through CEE sockets and PowerLock connections. On a depot that allows one asset to support workshop equipment, reefer points or temporary lighting alongside charging.
Both draw on the same stored energy, so where site loads run continuously and charging is intermittent the interaction should be modelled and a priority rule agreed before commissioning. For an export enquiry this is worth raising early, because it can change which model suits the depot.
Export Enquiry Checklist
• Confirm the connector standard and voltage window against vehicles in the destination market.
• Confirm which compliance and transport documents apply to the exact model and destination.
• Identify the recharge route at the destination, including a fallback, before shipment.
• Check unit weight and container loading against handling equipment at the depot.
• Request the derated output curve across the destination’s ambient range.
• Specify the coating class against measured exposure at the depot.
• Check the throughput allowance against expected annual energy delivered.
• Agree the remote diagnostic arrangement and the parts holding location.
https://www.mpmc-group.com/
MPMC Powertech Corp. -
