13/11/2026 at 15:40 #6583
Published: November 2026 | By Gentle King Engineering Team
One model letter, three wattage grades — and a stocking mistake is expensive in both directions. Distributors working through the h4 24v 75/70w vs 100/90w which bulb for trucks decision usually overstock the high-wattage grades and starve the line that actually sells every week. The 2026 split that works: 75/70W as the volume line, 100/90W as the paid upgrade, 150/130W for off-road equipment only.
Gentle King produces all three grades on the same IATF 16949 lines for commercial vehicle programs in North America and Europe, so the numbers below come from batch photometric and life testing rather than catalog claims.
1. Which H4 24V Wattage Grade Fits Which Customer?
Stock 75/70W as your volume line, 100/90W as the paid upgrade, and 150/130W for off-road equipment only. That single rule answers most of the h4 24v 75/70w vs 100/90w which bulb for trucks questions a counter will ever hear — the rest is matching each grade to the buyer behind it.
• 75/70W — the homologated standard. Roughly 1,000 lumens per filament (±15%) and the longest service life of the three, typically 180–500 hours in fleet service. This is the rating ECE homologation is built around, the default on Isuzu, Hino and European tractor heads, and the SKU that turns fastest in any 24V assortment. See the Gentle King H4 24V 75/70W commercial vehicle bulb.
• 100/90W — the paid upgrade. Around 25–30% more lumen output for poorly lit rural routes, at the cost of filament life — rule of thumb, expect roughly a third less service hours. Many 100/90W types carry no ECE road approval, so position them as an upgrade with a legality caveat attached, not as the default replacement.
• 150/130W — off-road equipment only. Maximum output for mining, agriculture and private-land machinery. The heavy duty 150/130w 24v bulbs off road worth it question resolves quickly: worth it where there is no road authority, not worth it for street fleets — heat stress cuts life sharply and no E-mark covers the rating. Keep one bin, priced accordingly.
• Never mix grades across an axle. Both headlamps should run the same wattage grade — a 75/70W on one side and a 100/90W on the other gives the driver an asymmetric beam pattern and can fail an inspection in markets that check it. Counter staff should ask whether the old lamp is being replaced in pairs before recommending an upgrade grade.
A three-bin rule keeps the counter fast: one bin per grade, physically separated exactly like the 12V/24V split, with 75/70W occupying the pick-face slot. Distributors running Gentle King private label and OEM programs usually start with a 60/25/15 assortment — 60% of the H4 budget in 75/70W, 25% in 100/90W, 15% in 150/130W — and re-balance after the first season of sell-through data.
✅ Bottom line: weight the shelf toward 75/70W — it is the homologated, fastest-turning line, and the other two grades are add-ons, not substitutes.
2. Are Blue Coated H4 Bulbs a Third Option to Stock?
Coated bulbs are an upsell on beam color, not on light output — and the are blue coated halogen bulbs legal for trucks answer depends on the E-mark, not the tint. Blue coating filters the yellow end of the spectrum, so the beam reads whiter while total lumens drop — typically around 10% for a coated 75/70W against a clear one.
Legality follows the approval, not the color. In ECE markets a replacement bulb must be homologated as a type and stay inside the white-light color band — a coated lamp with a valid E-mark is street legal, while an unmarked blue bulb is not, regardless of how mild the tint looks. In North America the same logic applies under DOT self-certification: the manufacturer certifies the type, coating included.
For shelf placement, treat coated lamps as a fourth SKU rather than a wattage grade: a homologated coated 75/70W — such as the Gentle King H4B blue coated halogen bulb — sells to drivers who want the whiter look without leaving the legal band. Whenever a customer asks are blue coated halogen bulbs legal for trucks, the E-mark on the carton answers it — keep the mark visible so the question never reaches the returns desk, and never mix coated and clear lamps in the same pick-face.
✅ Bottom line: stock coated 75/70W as a legal upsell with the E-mark on the box — never as a replacement for the homologated clear line.
Frequently Asked Questions
Q: For fleet buyers weighing the h4 24v 75/70w vs 100/90w which bulb for trucks trade-off, what wins?
A: The h4 24v 75/70w vs 100/90w which bulb for trucks decision lands on 75/70W for nearly every street fleet — homologated, longest-lived and cheapest per hour of light. Reserve 100/90W for routes the driver themselves flags as too dark, and treat it as an upgrade sale with the legality caveat.
Q: How much shorter does a 150/130W bulb actually live?
A: Expect roughly half the hours of a 75/70W or less — the filament runs hotter and vibration tolerance drops with it. That is exactly where heavy duty 150/130w 24v bulbs off road worth it turns positive: mining and farm buyers replace lamps on schedule, so raw output beats longevity. Street fleets watching downtime cost should stay clear.
Q: What should winter long-haul routes run?
A: Stay on homologated 75/70W and step up within approval — premium +100% light series give more usable beam without leaving the legal band. Halogen's infrared heat also keeps snow and ice from building on the lens, an advantage worth keeping. The full model map is in the Gentle King 24V truck bulb chart.
Get the Gentle King Wattage Assortment Sampler
Nantong Gentle King Optoelectronics Science And Technology Co., Ltd. manufactures H4 24V bulbs in all three wattage grades plus coated variants for distributor, OEM and private label programs, with E4 and DOT approvals on homologated ratings and IATF 16949 behind every batch. Ask for the wattage sampler carton — one master carton with a 60/25/15 grade mix plus coated samples — and test it against your sell-through before committing to a full wholesale order. We map your current H4 SKUs to the right grade split within 48 hours.
http://www.jiklight.com
Nantong Gentle King Optoelectronics Science And Technology Co., Ltd. -
