23/10/2026 at 18:15 #6380
The HFM series corrosion-resistant and wear-resistant centrifugal pump is designed for industrial applications involving corrosive liquids, slurries, and demanding transfer conditions. Developed to address leakage risks associated with conventional pump sealing structures, it features a lined pump design with the shaft seal position and inlet arranged in the same direction.
Designed for Corrosive Liquids and Slurries
The HFM pump can transfer both corrosive and non-corrosive clear liquids and slurries at temperatures up to 100°C. Its corrosion-resistant and wear-resistant construction makes it suitable for various industrial processes where fluid compatibility and equipment durability are important.
The pump can also serve as a pressure-feeding pump for filter presses, supporting solid-liquid separation processes in industries such as non-ferrous metal smelting and mineral processing.
Applications in Metallurgy and Mineral Processing
The HFM series is suitable for a range of industrial applications, including:
Non-ferrous metal hydrometallurgy: Filter press feeding and process fluid transfer in zinc, copper, cobalt, nickel, and manganese production.
Mineral processing: Slurry transfer in metal ore and non-metallic mineral processing.
Non-metallic minerals: Applications involving materials such as titanium dioxide and kaolin.
Environmental protection: Sludge and waste residue transfer.
Chemical and pharmaceutical industries: Pressure filtration and process fluid delivery.
Other industrial processes: Dyeing, food production, and related applications requiring suitable liquid or slurry transfer equipment.
Selecting the appropriate pump requires consideration of the medium's chemical properties, solids content, temperature, flow rate, and required delivery pressure.
Product Features and Configuration
The HFM series combines a lined pump structure with corrosion-resistant and wear-resistant materials to address the challenges of industrial fluid transfer. Polymer, fluoroplastic, and composite materials are listed among the product material options.
For projects requiring specific operating conditions, buyers can discuss the suitable configuration and technical requirements with the manufacturer. Product color options include blue and gray, while order quantities and pricing are negotiable upon inquiry.
Find a Suitable HFM Pump for Your Application
For metallurgy, mineral processing, environmental protection, and other industrial applications, the HFM corrosion-resistant and wear-resistant centrifugal pump offers a solution for transferring compatible liquids and slurries, including filter press feeding duties.
Contact the manufacturer to discuss the medium, operating temperature, solids content, flow requirements, and pressure conditions to determine a suitable pump configuration.
http://www.zxbypump.com
Jiangsu Zhenxing Pump Industry Co., Ltd. -
