09/06/2025 at 16:40 #3196
High-Precision On-Site Machining with MT Flange Milling Machine FMCNC6000
When it comes to on-site machining of large-scale components, particularly in high-demand industries such as nuclear power, precision is not just a requirement—it’s a necessity. MT Portable Machine has consistently delivered advanced flange milling solutions tailored for large-diameter workpieces, offering fully CNC-controlled flange milling machines designed for extreme accuracy and reliability. Our experienced engineering team has developed multiple models of high-performance CNC flange milling machines to meet various field machining challenges.
The FMCNC6000 flange milling machine is one of MT’s flagship products. Engineered for large-diameter flange machining, it supports a processing diameter range of up to 6 meters. Its fully programmable CNC control system ensures precise tool movement, allowing automated circular milling of sealing surfaces and bolt-hole patterns with tight tolerance. The machine is equipped with a servo-driven rotation system for smooth indexing and a hydraulic power unit for high-efficiency milling. It supports various milling strategies including face milling, groove cutting, and RTJ sealing face machining, making it ideal for heavy-duty field applications.
This particular FMCNC6000 machine is scheduled for shipment to a nuclear power facility, where it will be used to machine large flanges and critical mounting surfaces of heavy reactor components. Due to the enormous size of the parts involved, on-site machining is the only viable solution. MT’s portable, precision-engineered milling machine allows in-situ processing, saving time and eliminating the need for disassembly or transport.
If your projects involve large flange or circular surface machining, MT Portable Machine can provide you with CNC-based field machining equipment that ensures accuracy, efficiency, and performance. Contact our technical experts at info@mtportable.com to learn more about our flange milling machine solutions and how we can assist with your on-site machining requirements.
http://www.mtportable.com
Jichuang Machinery Manufacturing Wuxi Co.,Ltd -
