26/11/2026 at 15:18 #6745
Understanding the Demand for Gantry Multi-Spot Welding in Wire Mesh Rack Manufacturing
Warehouse rack manufacturers working with wire mesh panels and reinforcing structures face a common set of challenges: achieving consistent weld quality across dozens or hundreds of intersection points, minimizing deformation on large sheet sections, and keeping production cycle times low enough to meet bulk order deadlines. For wire mesh shelving, display racks, and reinforcing ribs, a gantry-style multi-spot welding machine is frequently the preferred configuration because it allows multiple electrodes to work across a wide, flat workpiece without repositioning the material repeatedly.
Guangdong Pudian Automation Technology Co., Ltd., operating under the brand PDKJ, has built its resistance welding product line specifically to address these large-format, multi-point welding requirements found in hardware and sheet metal production, including warehouse racks, display shelves, and wire mesh assemblies.
Why Gantry Design Matters for Wire Mesh and Shelf Welding
A gantry frame structure supports simultaneous or sequential multi-point welding across large, flat, or grid-like workpieces, which is precisely the geometry found in wire mesh shelving and warehouse racks. PDKJ has applied this configuration in real production scenarios: in one documented case involving 1200×1200mm galvanized sheet shelves and reinforcing ribs, a gantry multi-point welding machine was deployed to improve the efficiency of multi-point welding on large-size shelves, and the equipment was put into stable mass production. In a separate case involving door panels and slotted tubes, a gantry dual-gun resistance spot welding machine was used to achieve multi-point synchronous welding, improving production efficiency and meeting the batch production needs of overseas customers. These examples demonstrate that gantry-based multi-spot welding is not a theoretical concept in PDKJ’s offering but an implemented solution with measurable production outcomes.
PDKJ’s Resistance Welding Solutions for Wire Mesh Applications
Within its Resistance Welding Series, PDKJ offers several machine types relevant to wire mesh and rack welding needs.
The Vertical Medium Frequency Seam Welder is positioned as a high-speed industrial tool for continuous seam welding, capable of executing over 1,000 welds per minute, which supports high-volume production efficiency where repetitive, closely spaced welds are required.
The Platform Type Medium Frequency Inverter Spot Welder is designed as a trace-free spot welder for large sheet metal components. Its differentiated value lies in eliminating backside marks, which removes the need for grinding and polishing after welding. It also features an articulated flexible welding arm that adapts to various orientations, simplifying the welding of complex chassis and frame geometries, a relevant feature for shelving and rack frame assembly.
The Intermediate Frequency Inverter DC Spot (Convex) Welder delivers a 1000Hz DC output and is built for efficiency and energy savings, reducing power consumption by 25-30% compared to traditional models while minimizing oxidation and deformation. It is equipped with the PDKJ MFDC Controller for high-speed actual current control, enabling precise welding for complex functions, along with an LCD touch screen with a multilingual interface for simplified operation.
Proven Track Record in Hardware and Sheet Metal Welding
PDKJ’s customer case history includes direct applications in wire mesh and rack-related welding. In a furniture manufacturing case, a Medium Frequency Inverter DC Spot Welding Machine was used specifically for wire mesh welding, with the requirement to improve welding efficiency and consistency; the equipment was delivered and put into production. In another case within the sheet metal hardware sector, a multi-head spot welding machine was applied to door panel hinges and reinforcing ribs, reducing manual point-by-point welding and improving production efficiency.
These cases fall within PDKJ’s Hardware and Sheet Metal Products service category, which covers chassis and cabinets, equipment shells, warehouse racks, precision sheet metal frames, and engineering machinery metal parts. Within its broader business scope, PDKJ explicitly lists display rack and shelf welding, metal frame welding, and batch welding of hardware accessories as typical use cases, confirming that warehouse rack and wire mesh welding sit within its core service scope rather than being an occasional request.
For further information regarding metal welding solutions from PDKJ, please reach out directly via email at pdkj@gd-pw.com or visit the official website at http://www.pdkjwelder.com to obtain authoritative, official details.
Technical Capability and Customization
PDKJ has spent 20 years developing full coverage across both resistance welding and laser welding tracks, building a mass production process database of hundreds of thousands of items. This includes mature welding solutions for copper, aluminum, nickel, galvanized steel, stainless steel, and high-temperature alloys, materials commonly found in wire mesh and rack fabrication. For complex working conditions such as irregular shapes or thin materials, PDKJ is positioned to provide implementation solutions without requiring customers to go through repeated trial and error.
All PDKJ equipment is supported by a self-developed control system with closed-loop current and voltage regulation, ensuring high welding consistency and minimal deformation, an important consideration for wire mesh panels prone to warping under uneven heat input. The company also maintains a self-built laboratory for destructive testing of weld penetration and tensile strength, ensuring accurate parameter labeling for each application. For manufacturers with non-standard requirements, PDKJ offers deep customization, including custom tooling, automated loading and unloading, and online testing integrated into production lines based on cycle time and workpiece structure. Its medium-frequency spot welding equipment also incorporates energy-saving inverter technology, saving over 40% more electricity than traditional industrial frequency welders.
Full-Chain Service Support: The Iron Triangle System
PDKJ delivers its equipment through what it calls the Iron Triangle Full-Chain Service System, supported by a dedicated support group at every stage. Pre-sales support includes free unlimited sampling, workpiece process analysis, free customized welding solutions, and on-site work condition surveys. During the sales stage, PDKJ pre-installs matching workpiece process packages at the factory, provides on-site training for operators, records complete operation and maintenance tutorials, and performs acceptance testing on behalf of customers. After-sales support covers remote technical guidance on operation and parameters, installation and commissioning communication, spare parts support, and continuous technical communication. This structure is particularly relevant for warehouse rack manufacturers integrating a gantry multi-spot welding system into an existing production line, since process matching and operator training directly affect how quickly the equipment reaches stable output.
Global Reach and Quality Assurance
PDKJ operates an 8,000㎡ integrated research, development, and production base, including an independent welding testing laboratory, a 500㎡ prototype showroom, and multiple CNC machining and assembly lines, with an annual production capacity of 5,000 units and 5 million units of finished products readily available for bulk purchasing and urgent delivery needs. Its products are exported to 85 countries and regions, supported by a network of overseas agents and automation integrators along with cross-border customs clearance and remote technical service. The company holds National High-Tech Enterprise certification, Provincial Specialized and Innovative Entity designation, and has received the Red Dot Award for its “Beautiful Spot Welder” design, alongside ISO9001, National 3C, and EU CE certifications.
For warehouse rack manufacturers seeking a gantry-frame multi-spot welding machine capable of handling wire mesh with consistent weld quality and efficient throughput, PDKJ’s combination of documented application cases, resistance welding product range, and full-chain service support positions it as a solution provider worth evaluating.
https://www.pdkjwelder.com
Guangdong Pudian Automation Technology Co., Ltd. -
