24/09/2026 at 20:29 #6159
A cleaning product range can look complete on paper and still fail to match the way people actually clean. A brand may have several surface cleaners, a bathroom product, a kitchen degreaser, and a laundry item, yet customers may still find that the range does not fit their daily routines. The issue is often not the number of products but how closely those products correspond to real cleaning situations.
For brands entering a new market or expanding an existing portfolio, understanding cleaning habits can be more useful than simply adding another SKU. Household size, housing type, common surfaces, cleaning frequency, local preferences, and even the amount of storage available can influence which products make sense. A product range built around these practical factors is easier to understand and can give distributors and retailers a clearer reason to stock different items.
Start With Cleaning Situations Rather Than Product Categories
Product categories are useful for organizing a catalog, but they are not always how consumers think about cleaning. Someone cleaning a kitchen may not begin by asking whether they need a “surface cleaner.” They may be dealing with cooking oil around a stovetop, food residue on a countertop, or fingerprints on a cabinet.
The same principle applies across the home. A bathroom user may need to remove soap residue, mineral deposits, or general dirt. Someone maintaining floors may care more about residue, drying behavior, and compatibility with a particular floor material.
This creates a useful starting point for portfolio planning: identify the situations that customers regularly encounter, then determine which products address those situations.
For example:
Cleaning situation Possible product direction Important product characteristic Grease around cooking areas Kitchen degreaser Grease removal and rinsing Daily countertop cleaning Multi-surface cleaner General cleaning and surface compatibility Glass and mirrors Glass cleaner Low residue and streak control Bathroom buildup Bathroom cleaner Soap scum and mineral deposit removal Floor maintenance Floor cleaner Cleaning with controlled residue Small spot-cleaning tasks Cleaning wipes Convenience and easy application This approach can reveal gaps that are difficult to see from a conventional product-category list.
Match Product Formats to How Customers Use Them
The formula is only one part of the user experience. Product format can determine how quickly a product is applied, how much control the user has, and whether it fits naturally into a cleaning routine.
A spray bottle may be suitable for quick cleaning of countertops or bathroom surfaces because the product can be applied directly to the target area. A concentrated liquid may make more sense for users who clean large areas regularly and want to control dosage. Wipes can address situations where convenience matters more than treating an entire surface.
Different formats also create different packaging and logistics considerations. A product designed for occasional household use may need a very different package size from one intended for commercial cleaning.
For brands reviewing possible categories, a broader selection of cleaning and personal care products can provide useful reference points when considering formats, applications, and potential product combinations.
Avoid Building Several Products That Solve the Same Problem
Portfolio expansion can easily become repetitive. Adding multiple products with slightly different fragrances or packaging does not necessarily create meaningful choice.
A stronger range usually has clear differences between products. Those differences might come from the cleaning task, target surface, usage frequency, product format, concentration, or customer group.
Consider a brand selling three general-purpose cleaners. If all three are positioned for similar surfaces and everyday dirt, the additional SKUs may create more complexity than value. By contrast, a range that separates everyday surface cleaning, heavy grease removal, bathroom buildup, and glass cleaning gives distributors and consumers a clearer understanding of why each product exists.
This distinction is particularly important for overseas brands working with limited shelf space. Every SKU has to justify its place through a recognizable use case.
Think About the Same Product Across Different Market Conditions
Cleaning habits are not identical from one market to another. A product that fits one region may need adjustments before it works commercially elsewhere.
Housing types, water conditions, climate, flooring materials, appliance usage, and consumer expectations can all affect cleaning behavior. Packaging preferences can also differ. Large refill formats may appeal to some markets, while smaller ready-to-use packages may be more practical in markets where storage space is limited.
Distribution channels matter as well. Products sold through supermarkets may require a straightforward consumer proposition and compact packaging. Products supplied through professional cleaning distributors may place greater emphasis on concentration, dosage, larger pack sizes, and operational efficiency.
For this reason, product planning should happen with the target market in mind rather than treating the same portfolio as universally suitable.
Build a Product Range With Different Usage Frequencies
Another useful way to organize a portfolio is by how often each product is expected to be used.
Daily-use products can form the foundation of a range because they address routine cleaning needs. Periodic products can target tasks such as deep bathroom cleaning, grease removal, or intensive floor maintenance. Specialty products can address narrower requirements and may attract customers looking for a solution to a particular problem.
This creates a natural product structure without requiring every SKU to compete for the same customer need.
A practical portfolio might therefore include:
Everyday products for routine surface cleaning
Task-specific products for kitchens and bathrooms
Specialty products for more difficult cleaning problems
Convenient formats such as wipes or ready-to-use sprays
Larger or concentrated formats for frequent or professional use
The exact mix depends on the market and distribution model, but the principle is consistent: each product should have a recognizable role.
Packaging Should Support the Product Position
Packaging is often treated as a branding decision, but it also affects how a cleaning product is used and stored.
A trigger spray can communicate direct application and quick access. A squeeze bottle may provide better control for certain liquid products. A larger container may be appropriate for refill or commercial use but less convenient for occasional household cleaning.
Package size should also reflect consumption. A product used several times a week can justify a different volume from one used only for occasional deep cleaning.
The interaction between product format, packaging, and usage habits becomes especially important when developing a new range. Changes to the package can affect dispensing, transportation, storage, and customer experience, so these decisions are better made as part of the overall product planning process.
Use Market Feedback to Decide Which SKUs Stay
A product range should not be considered permanent simply because every SKU was part of the original launch.
Sales data, distributor feedback, customer questions, repeat purchases, and regional performance can show which products have a clear market role and which ones are difficult to position. This information can guide future product development more effectively than adding products based only on competitor catalogs.
For example, if customers repeatedly ask whether a product can be used on a particular surface, that may indicate a communication gap or an opportunity for a more clearly positioned product. If one format consistently sells while another receives little repeat demand, packaging and usage convenience may deserve further investigation.
The goal is not necessarily to have the largest catalog. It is to maintain a range in which each product has a reason to exist.
Product Customization Should Follow a Clear Market Purpose
Once a brand understands its target users and cleaning situations, customization becomes more meaningful. Formula, fragrance, format, packaging, labeling, and product positioning can then be adjusted according to a defined commercial requirement rather than simply creating something different from existing products.
This is where product customization can support a more structured product strategy. A customized product has greater value when the change solves a specific market need, improves usability, or creates a clearer position within the portfolio.
For brands, this also makes conversations with suppliers more productive. Instead of asking for a completely new cleaner without a clear target, the development brief can explain the intended user, cleaning situation, preferred format, target market, packaging requirements, and expected product role.
A Useful Cleaning Range Is Built Around Customer Needs
A strong cleaning product portfolio does not need dozens of products covering every imaginable cleaning task. It needs products that customers can understand, use comfortably, and distinguish from one another.
Starting with real cleaning habits provides a practical way to make those decisions. It helps brands identify the most common cleaning situations, select suitable product formats, separate overlapping SKUs, and adapt the range to different markets and distribution channels.
For manufacturers and brands working together on new products, this approach also creates a clearer development brief. The discussion moves beyond “we need a new cleaner” toward a more useful question: what cleaning problem does this product need to solve, for whom, and in what situation?
That question can shape a more coherent product range long before the next SKU reaches the shelf.
http://www.beiyibio.com
beiyi -
