10/10/2026 at 18:11 #6239
https://www.droneyee-tech.com/zv150p-hybrid-power-uav.html
As industrial UAV applications continue to expand, operators increasingly need aircraft that can support more than one type of mission. A single UAV platform may be required for aerial surveying, maritime monitoring, emergency communications, forest fire monitoring, disaster response, and other demanding industrial operations.
How the ZV150P Hybrid Power UAV Supports Multi-Mission Operations
At Droneyee Tech, we developed the ZV150P Hybrid Power UAV to address these multi-mission requirements. Rather than focusing on a single application, the platform combines hybrid power, fixed-wing VTOL capability, high payload capacity, modular payload integration, long endurance, and multiple flight safety technologies to support a variety of industrial operations.
How do these capabilities help the ZV150P adapt to different mission requirements? Let's take a closer look at its key features and potential applications.
Hybrid Power for Long-Endurance UAV Operations
Long endurance is a critical requirement for many industrial UAV missions. Whether operators are monitoring large maritime areas, surveying remote terrain, or supporting emergency response activities, sufficient flight time helps improve mission efficiency and operational flexibility.
The ZV150P uses a hybrid oil-electric power system designed to support extended flight operations. With a stated endurance of up to 6 hours, the aircraft can remain airborne for long periods while carrying mission-specific equipment.
This capability makes the ZV150P more than a conventional short-duration drone. It is designed as an industrial UAV platform for operations where flight duration, payload capacity, and mission adaptability are important considerations.
For customers conducting large-area surveys or extended monitoring missions, the combination of hybrid power and long endurance provides greater flexibility when planning flight routes and allocating operational resources.
Fixed-Wing VTOL for Flexible Deployment
Another important feature of the ZV150P is its fixed-wing vertical takeoff and landing (VTOL) configuration.
Conventional fixed-wing UAVs typically require suitable runways or designated launch and recovery areas. Multirotor UAVs offer greater flexibility for takeoff and landing but may not provide the same flight efficiency for extended, large-area missions.
The ZV150P combines the advantages of both configurations. Its VTOL capability supports vertical takeoff and landing, while its fixed-wing design enables efficient sustained flight.
The aircraft also features a modular structure designed to simplify transportation and field deployment. According to its stated specifications, the ZV150P can be prepared for takeoff in approximately 15 minutes.
For emergency response teams and operators working in remote areas, this combination of vertical takeoff and landing and rapid deployment can be particularly useful when conventional runway infrastructure is unavailable.
High Payload Capacity for Mission-Specific Equipment
A multi-mission UAV needs more than long endurance. It must also accommodate different types of equipment to meet the requirements of individual operations.
The ZV150P offers a maximum payload capacity of 60 kg, allowing mission-specific equipment to be integrated according to customer requirements.
Depending on the application, potential payloads include:
Satellite communication terminals
PDT base stations
Aerial surveying cameras
Multi-sensor pods
Other mission-specific equipment
For example, the same ZV150P platform can be configured with a surveying camera for aerial mapping or equipped with communication hardware to support emergency communications.
This modular payload approach allows the ZV150P Hybrid Power UAV to serve different operational needs without requiring a completely separate aircraft platform for every mission. The actual payload configuration will depend on equipment dimensions, weight, power consumption, and integration requirements.
1300 W Onboard Power for Mission Equipment
Payload capacity is only one part of successful equipment integration. Many industrial payloads also require a reliable onboard power supply to operate throughout a mission.
To address this requirement, the ZV150P provides up to 1300 W of onboard power for mission equipment.
This capacity supports the integration of equipment such as satellite communication systems, PDT base stations, surveying cameras, and multi-sensor payloads, subject to their individual power requirements and interface compatibility.
By combining payload capacity with onboard power, the ZV150P can serve as an airborne platform for specialized equipment rather than simply carrying passive loads.
For system integrators and project buyers, evaluating payload weight and power consumption together is an important step in determining whether the aircraft configuration meets the requirements of a particular mission.
Supporting Emergency Communication Operations
Communication can become a significant challenge during natural disasters, infrastructure failures, and operations in remote areas where conventional communication networks are limited or unavailable.
The ZV150P is designed to support long-range communication equipment and satellite communication solutions. Its potential configurations include Ka/Ku-band satellite communication systems and other long-distance communication equipment.
With suitable payload integration, the aircraft can support emergency communication operations by providing an airborne platform for communication equipment and data transmission.
Its long endurance is also relevant to these applications, allowing the aircraft to remain airborne for extended periods while supporting communication-related tasks.
The specific coverage, data capacity, and communication performance will depend on the selected equipment, operating environment, and overall system configuration.
Supporting Maritime Monitoring Missions
Maritime monitoring often requires UAVs to cover large areas while operating far from fixed infrastructure. Endurance, communication capability, payload flexibility, and deployment efficiency are therefore important considerations.
The ZV150P's fixed-wing configuration supports sustained flight over large areas, while its hybrid power system is designed to provide the endurance needed for extended monitoring operations.
Multi-sensor payloads can also be integrated according to the specific
http://www.droneyee-tech.com
Beijing Zhuoyi Intelligent Technology Co., Ltd. -
