14/05/2026 at 10:47 #5004
When planning an FTTH (Fiber-to-the-Home) network, one of the most critical—but often underestimated—components is the fiber optic splitter. It directly determines how efficiently optical signals are distributed from the central office to multiple end users, and it has a major impact on both service quality and overall deployment cost.
In real-world deployments, the splitter is not just a passive component—it defines how scalable, stable, and cost-effective the entire FTTH architecture will be.
Ningbo Jingkon Optical Communication, established in 2007, has been widely involved in FTTH infrastructure solutions. Through its product line under Jingkon Fiber Communication, the company provides fiber optic splitters for FTTH networks along with related components such as optical cables, adapters, splice closures, and distribution frames. With ISO 9001 production systems and certifications including CE, ROHS, and PTS, its products are designed to maintain low insertion loss, stable uniformity, and long operational lifespan.
1. Why fiber optic splitters are so important in FTTH design
In an FTTH system, a single optical signal must be distributed to multiple users. The splitter is the component responsible for dividing that signal.
What many network planners quickly realize is that the splitter determines three key system behaviors:
How much signal each user receives
How evenly the signal is distributed across all endpoints
How scalable the network will be in future expansions
A poorly selected splitter can lead to weak signal strength, uneven performance across subscribers, or unnecessary infrastructure cost.
2. Understanding splitting ratios in real deployment scenarios
The splitting ratio (for example 1:4, 1:8, 1:16) defines how one optical input is divided into multiple outputs.
In practical FTTH planning, each ratio has clear implications:
● Signal distribution impact
Higher split ratios distribute power across more users, which naturally reduces signal strength per endpoint. Lower ratios maintain stronger signal quality but require more splitter units across the network.
● Cost structure balance
Using higher split ratios can reduce hardware quantity, but may increase the need for signal amplification or more precise power budgeting. Lower ratios increase hardware usage but help maintain stronger and more stable signals.
● Future scalability
Selecting the right ratio is not just about current demand—it also determines how easily the network can expand without major reconstruction.
The fiber optic splitters provided by Jingkon Fiber Communication are designed with low insertion loss and high output uniformity, giving operators more flexibility when choosing ratios based on deployment needs.
3. Key technical factors when selecting FTTH splitters
1. Network architecture
Different FTTH topologies influence splitter placement:
Tree structures often rely on centralized high-ratio splitters
Distributed or urban dense networks typically use multiple low-ratio splitters
Hybrid models combine both approaches for flexibility
2. Subscriber density and transmission distance
The number of users and the fiber distance directly affect optical power budget planning.
Longer distances or higher user counts require more careful balancing of splitter ratios to ensure each endpoint still receives usable signal strength.
3. Optical power budget calculation
A proper FTTH design must consider:
Transmitter output power
Fiber attenuation
Connector and splice losses
Receiver sensitivity
High-quality splitters such as those from Jingkon Fiber Communication help reduce unnecessary signal loss through stable insertion loss control and uniform output distribution.
4. Environmental durability
In real deployment environments, splitters must withstand:
Temperature variations
Humidity exposure
Mechanical stress during installation or maintenance
Jingkon products are designed and tested to meet international standards such as CE and PTS, ensuring stable operation in diverse environmental conditions.
4. Balancing cost efficiency and signal performance
In FTTH projects, cost optimization and signal stability must be balanced carefully.
Common deployment strategies include:
Using 1:8 or 1:16 ratios in suburban or wide-area coverage scenarios
Using 1:4 or 1:8 ratios in dense urban environments where signal strength is more critical
Combining centralized and distributed splitter placement to reduce unnecessary infrastructure duplication
A key advantage of using low-loss components is that they reduce the need for additional amplification equipment, which helps control long-term operating costs.
With Jingkon Fiber Communication’s fiber optic splitters for FTTH networks, operators can better balance cost control with stable optical performance.
5. Installation and maintenance best practices
Even high-quality components can underperform if installation practices are not properly followed.
Some practical guidelines include:
Conduct insertion loss and uniformity testing before deployment
Avoid contamination during handling and installation
Clearly label all output ports for easier maintenance
Design splitter placement with future expansion in mind
Proper planning at the installation stage significantly reduces long-term maintenance costs and network troubleshooting complexity.
FAQ
Q1: How do I choose the correct splitting ratio for an FTTH project?
It depends on subscriber density, network topology, distance, and power budget. Low-loss splitters from Jingkon Fiber Communication provide more flexibility in these decisions.Q2: Does a higher split ratio reduce signal quality?
Yes, because optical power is divided among more outputs. However, proper design and low-loss components can help maintain acceptable performance.Q3: Why are Jingkon splitters commonly used in FTTH systems?
Because they offer low insertion loss, stable output uniformity, and compliance with international certification standards, which improves long-term network reliability.Q4: How can FTTH costs be optimized without sacrificing performance?
By selecting appropriate split ratios, using low-loss components, and optimizing network topology layout.
Final Thoughts
In FTTH network construction, the fiber optic splitter is a foundational component that directly affects performance, scalability, and cost structure.
A well-planned system requires more than just connecting fiber—it requires careful optical power management and component selection.
By using certified, low-loss solutions such as those from Ningbo Jingkon Optical Communication, operators can build FTTH networks that are both scalable and stable, while maintaining consistent service quality for end users across different deployment environments.
http://www.jingkon.com
Ningbo Jingkon Fiber Communication Apparatus Co., Ltd. -
