15/07/2024 at 13:48 #1463
In today's home and commercial food preservation world, vacuum glass food containers have become the preferred storage solution in the kitchen due to their excellent sealing performance and elegant appearance. Not only that, they also help reduce food waste by extending the shelf life of food, bringing dual benefits to families and the economy. However, like other high-quality tableware, proper cleaning and care are essential to maintain their durability, safety, and appearance.
Pre-cleaning precautions
Before cleaning vacuum glass food containers, you need to know some basic knowledge points. Although glass is tough, it is also fragile, so be careful and gentle when handling it. Avoid excessive force or dropping from a height, which may cause cracks or shatters. Once the glass surface is damaged, such as scratches or cracks, its structural integrity will be affected, which in turn affects the sealing performance and may harbor dirt.
Cleaning steps
1. Pretreatment Before cleaning, remove as much food residue as possible from the container. For foods that are highly adherent, you can soak them in warm water first to soften them to avoid scratching the glass surface with hard objects when cleaning.
2. Choose a soft brush or sponge as a cleaning tool. Avoid using a metal ball or abrasive cleaning cloth. These tools will leave tiny scratches on the glass surface, affecting the appearance and sealing effect.
3. Choose a mild detergent. Strong corrosive detergents may damage the gloss of the glass surface or even weaken the glass material itself.
4. Use warm water for water temperature control. Overheated or overcooled water may cause damage to the glass due to temperature shock.
5. Gentle operation Be gentle when washing. Do not use too much force to avoid unnecessary pressure on the glass.
6. Rinse thoroughly Make sure to rinse all detergents thoroughly with enough clean water. Detergents remaining after drying may affect the taste of food and the sealing performance of the container.
Maintenance and drying
After washing, the vacuum glass container should be wiped dry immediately with a clean towel or dried naturally. Avoid wiping repeatedly with a wet towel, as tiny sand particles may scratch the glass. Heat sources such as stoves or microwaves should not be used to accelerate the drying process. Such rapid temperature changes are very likely to cause glass damage.
Regular inspection and replacement
Regularly check the overall condition of the vacuum glass food container, including its seals and valves. Whenever the seal performance is found to be degraded or damaged, the relevant parts should be replaced in time to ensure the safe storage of food and the long-term service life of the container.
When vacuum glass food containers are not in use, they should be properly stored. They can be placed in a clean, dry, and moderately warm cabinet, avoiding high humidity and extreme temperature environments, which may cause damage to the glass. To prevent accidental breakage, it is best to separate each container with a soft cloth and ensure that they are not subjected to pressure caused by squeezing or excessive stacking.
As an important tool in the kitchen, vacuum glass food containers not only provide superior preservation performance but also show people their elegant appearance. But like all high-quality products, proper cleaning and maintenance are the keys to ensuring its performance and extending its service life. The right amount of preventive maintenance can reduce the risk of accidents and ensure that your investment is worth the money. Therefore, following the above suggestions will not only maintain the functionality of your vacuum glass food containers but also make them look like new every day. Remember, good maintenance habits will accompany your vacuum glass food containers through spring, summer, autumn, and winter, and you can continue to enjoy an elegant life while enjoying healthy and delicious food.
As a vacuum glass food container company, we are committed to providing high-quality, reliable products to meet consumers' needs for food storage and preservation. Our products are beautifully designed, durable, and easy to clean, providing users with a convenient use experience.
http://www.bestfulltech.com
Jiangsu Bestfull Technology Co., Ltd. -
