23/10/2025 at 16:40 #4096
Packing a perfume box is a creative and careful job. Whether it is a gift or decoration, exquisite packaging can enhance the texture of the perfume. The following are detailed packaging steps and techniques, with creative solutions of different styles to help you create a unique perfume gift box:
I. Basic Packaging Steps of Perfume Box
1. Prepare Materials
Wrapping paper: Choose according to the size of the perfume box. It is recommended to choose thick colored paper, patterned paper, or special paper (such as pearl paper, cotton, and linen paper).
Ribbon/Rope: Ribbon, hemp rope, metal wire, or lace, the color matches the wrapping paper (such as gold with champagne or black with red).
Decorations (optional): dried flowers, pearl stickers, small cards, sequins, feathers, etc.
Tools: scissors, double-sided tape/transparent tape, ruler, and pencil.
2. Measure and Cut the Wrapping Paper
Place the perfume box in the center of the wrapping paper. The length of the paper should cover the perimeter of the box + 3-5cm on both sides, and the width should cover the height of the box × 2 + 5cm on the top.
Example: If the box size is 10cm (length) × 6cm (width) × 8cm (height), the wrapping paper is recommended to be cut to (10+6)×2+5=37cm (length) × 8×2+5=21cm (width).
3. Wrap the Side of the Box
Left and right sides: Fold the wrapping paper upward along the side of the box and fix it with double-sided tape to form a neat right angle.
Top and bottom edges: Fold the bottom paper inward into a triangle (similar to the bottom folding method for wrapping gifts) and fix it with tape; do not seal the top for the time being, and keep it open.
4. Decorate the Top and Seal
Put the custom perfume box in the wrapping paper, adjust the position, fold the top paper downward, and fix it with tape.
Tie a ribbon in the center of the top, tie a bow or a flat knot, and the excess ribbon can be trimmed into a dovetail or tassel shape.
II. Creative Packaging Style and Skills of Perfume Box
1. Minimalist High-end Style
Color matching: monochrome wrapping paper + thin ribbon of the same color, with metal nameplate or hot stamping sticker.
Tips: Use tweezers to sprinkle a small amount of silver foil fragments on the inside of the wrapping paper, and close the lid to form a faint flashing effect.
2. Romantic Bouquet Style
Steps:
Wrap the perfume box with translucent snow gauze paper or sulfuric acid paper to create a hazy feeling.
Fix the dried flowers (such as eucalyptus leaves and small roses) in the ribbon with a thin wire and wrap it around the top of the box.
Finally, decorate the ribbon knot with a pearl or crystal decoration.
3. Retro Letter Style
Material: kraft paper + hemp rope + wax seal.
Operation:
Wrap the box with kraft paper, spirally wrap the edges with hemp rope, and tie a knot.
Make a handwritten greeting card and fix it with a wax seal at the knot to add a retro sense of ritual.
4. Holiday Limited Style (taking Christmas as an example)
Elements: red and green plaid wrapping paper + golden bells + pine branches.
Tips:
Choose Christmas-themed patterns (such as snowflakes and elk) for wrapping paper.
Replace the ribbon with a golden or red velvet ribbon and hang a small bell on the knot.
Cut a small piece of pine branches and fix it next to the ribbon with hot glue to add a festive atmosphere.
III. Precautions of Packing Perfume Box
Protect the perfume bottle: If the box is light, you can fill the box with bubble wrap or raffia to avoid shaking during transportation.
Tape hiding: Try to stick the tape on the inside or fold of the wrapping paper to keep the appearance neat.
Personalized label: Use a stamp or handwritten font to print a blessing (such as "For You") on the wrapping paper to enhance the sense of exclusivity.
Learn more:www.boxbagpackaging.com
Contact Us:sales01@hxcpc.cn
WhatsApp: 8615359885995
https://www.boxbagpackaging.com/Lid-and-Base-Boxes/custom-perfume-box-packaging.html
Xiamen Hengxing Color Printing Co., Ltd. -
