21/11/2026 at 04:50 #6680
https://en.cosmos-ml.com/industry-blog/Hydraulic-Press-for-Ceramic-Grinding-Wheel-Manufacturing.html
Ceramic grinding wheel manufacturing requires accurate powder forming, stable pressing pressure, and consistent product dimensions. During production, uneven powder distribution, inaccurate positioning, or unstable pressing conditions can lead to density variations, cracks, and dimensional deviations. A suitable hydraulic press helps manufacturers maintain forming consistency and improve production efficiency.
COSMOS PRESS provides servo-driven hydraulic press solutions for precision powder forming and abrasive wheel manufacturing, including the High Precision Powder Forming Servo Driven Hydraulic Press (CMHe Series).
1. What to Consider When Choosing a Hydraulic Press
A hydraulic press for ceramic grinding wheel production needs to provide stable pressure, accurate positioning, and flexible process adjustment. These factors directly affect the consistency of the formed products.
Stable pressing pressure helps compact abrasive grains and bonding materials evenly, while accurate platen movement and mold positioning support dimensional consistency. The machine should also allow operators to adjust pressing speed and pressure according to different grinding wheel specifications.
In addition, a rigid machine structure is important for repeated pressing operations, while flexible operating modes can make mold adjustment and daily production more convenient.
2. Benefits of Servo Hydraulic Press Technology
Servo-driven hydraulic presses offer flexible control over pressing speed, pressure, and machine movement. This allows manufacturers to adjust forming conditions for different abrasive materials, mold designs, and product dimensions.
For ceramic grinding wheel production, several features are particularly useful:
Pressure and position feedback: High-precision pressure and displacement sensors provide feedback during operation. The main cylinder displacement precision can reach ±0.03 mm, supporting accurate positioning during pressing.
Flexible process adjustment: Operators can adjust operating parameters to suit different powder materials and product requirements.
Multiple operating modes: Point motion, manual, and semi-automatic modes support mold adjustment, process setup, and routine production.
Smooth operation: The servo motor drive system adapts to different speed and pressure requirements, helping achieve smoother and quieter machine movement.
These functions give manufacturers greater flexibility when setting up and managing powder forming processes.
3. CMHe Series Servo Hydraulic Press for Powder Forming
The COSMOS PRESS High Precision Powder Forming Servo Driven Hydraulic Press (CMHe Series) is designed for precision powder forming applications, including ceramic grinding wheel and other abrasive product manufacturing.
Its main features include:
Main cylinder displacement precision within ±0.03 mm.
High-precision pressure and displacement sensor feedback.
Servo control for flexible speed and pressure adjustment.
FEA-based structural design to improve frame strength and rigidity.
Single-station and double-station operation options.
Point motion, manual, and semi-automatic operating modes.
Compatibility with different auxiliary machine combinations.
Human-machine interface for parameter setting and function saving.
For grinding wheel manufacturers, these features support accurate positioning, adjustable pressing conditions, and flexible production configurations.
4. Customized Hydraulic Press Solutions for Grinding Wheel Production
Ceramic grinding wheels vary in diameter, thickness, abrasive composition, mold structure, and pressing force requirements. Selecting the right hydraulic press therefore requires consideration of the actual product and production process, rather than machine tonnage alone.
COSMOS PRESS can evaluate product dimensions, mold specifications, pressing requirements, positioning accuracy, and expected production capacity to recommend a suitable equipment configuration.
Whether upgrading existing abrasive wheel production equipment or setting up a new powder forming process, manufacturers can work with COSMOS PRESS to develop a hydraulic press solution based on their production requirements. Providing product drawings and technical specifications helps the team assess the application and discuss a suitable configuration.
COSMOS PRESS -
