30/04/2026 at 15:29 #4934
Inconel 718 alloy bars are among the most sought-after materials for industries that demand extraordinary strength, superior corrosion resistance, and the ability to perform under extreme temperature conditions. This high-performance nickel-based superalloy (UNS N07718), known for its exceptional durability, is indispensable across critical sectors such as aerospace, energy production, and petrochemicals.
Key Features of Inconel 718 Alloy Bars
Inconel 718 bars are engineered to perform in environments where other materials often fail. Here’s a breakdown of their vital properties:
Density: 8.19-8.25 g/cm³
Melting Point: 1260-1340°C
Microstructure: Composed of a gamma matrix and reinforcing phases such as γ'' (Ni₃Nb) and γ' (Ni₃(Al,Ti)).
Mechanical Properties (Post-Heat Treatment)
Tensile Strength: ≥1240 MPa at room temperature
Yield Strength: ≥1030 MPa (0.2% yield)
Elongation: ≥12% at room temperature
Hardness: 331-382 HB (around 35-40 HRC)
These properties make the alloy an ideal choice for components subjected to high temperatures and cyclic stresses.
Unmatched Performance in Extreme Conditions
Temperature Resistance: Inconel 718 bars maintain integrity at temperatures up to 700°C, with short-term oxidation resistance reaching up to 1000°C. This makes them perfect for high-temperature applications, including turbine engines and reactor components.
Corrosion Resistance: One of the standout features of Inconel 718 is its ability to resist stress corrosion cracking, pitting, and intergranular corrosion. This makes it highly suitable for use in harsh chemical and environmental conditions, including offshore oil drilling and gas turbines.
Low-Temperature Performance: Inconel 718 also boasts excellent impact resistance at cryogenic temperatures, with an impact energy of over 100 J at -196°C, making it ideal for use in liquid hydrogen and oxygen storage systems.
Versatile Applications Across Industries
Inconel 718 bars are used in critical industries where material performance is paramount. Some of the key application areas include:
Aerospace:
High-pressure compressor discs
Rocket engine components
Aircraft structural parts, such as fasteners and landing gear
Energy & Power:
Components of gas turbines
Reactor pressure vessel bolts for nuclear plants
Hydropower turbine shafts
Petrochemical:
Deep-sea oil drilling equipment
High-pressure reaction equipment
Other High-End Applications:
Automotive turbochargers
Cryogenic storage tanks
Inconel 718 alloy bars offer the durability required for demanding applications, providing unparalleled performance and reliability even under the harshest conditions.
Specifications and Customization
We understand that every project is unique, which is why Inconel 718 alloy bars come in a range of sizes and customizations. The typical round bar diameter ranges from 3.17 mm to 500 mm, with square bars and hexagonal rods also available. Lengths can vary from 1 meter to 6 meters, and we offer precision tolerances for perfect fitting.
Tolerance and Surface Condition
Round Bar Diameter Tolerance: ±1% (standard) or precision grades such as H8-H13 (±0.03–0.2 mm for diameters ≤50 mm).
Surface Roughness: Ranging from 12.5 μm to 0.4 μm, depending on your specifications.
Whether you need a polished surface for aesthetic components or a black skin for industrial uses, we can provide the right finish for your requirements.
Heat Treatment for Optimal Performance
Inconel 718 bars undergo a two-step heat treatment process to enhance their strength and toughness:
Solution Treatment: The bars are heated to temperatures between 1010°C and 1065°C to dissolve coarse phases, making the alloy microstructure more homogeneous.
Dual Aging: This step, performed at 720°C and 620°C, precipitates the γ'' phase, significantly increasing the hardness and enhancing high-temperature performance.
This controlled process ensures the alloy delivers its best possible mechanical properties, making it suitable for the most demanding applications.
Why Choose Inconel 718 Alloy Bar?
When you select Inconel 718 alloy bars, you're choosing a material that will deliver exceptional performance in high-stress, high-temperature, and corrosive environments. This superalloy ensures that your components last longer, with reduced maintenance costs and fewer failures.
By investing in Inconel 718 bars, you’re ensuring that your projects benefit from unparalleled strength, superior corrosion resistance, and enhanced longevity. Whether you're involved in aerospace, energy, or petrochemical sectors, Inconel 718 bars provide the reliability and performance your applications demand.
Contact us today to learn more about how our custom Inconel 718 alloy bars can elevate your projects, or to place an order for this exceptional material. With our commitment to delivering high-quality solutions and precise customizations, we ensure that your projects meet the highest standards.
https://www.zhonggongtemetal.com/Inconel-718-Alloy-Bar.html
http://www.zhonggongtemetal.com
Jiangsu Zhonggongte Metallurgical Technology Co., Ltd. -
