06/11/2026 at 17:49 #6518
Mold temperature control is one of the most critical factors determining product quality, cycle time, and dimensional stability in plastic injection molding and related manufacturing processes. Heat accumulation within molds and hydraulic systems can lead to warping, inconsistent part dimensions, and extended cooling cycles if not managed properly. For manufacturers evaluating equipment to solve these challenges, Jiangsu Obuy New Energy Development Co., Ltd. (operating under the Obuy and Obuytech brand names) offers a range of industrial chillers engineered specifically for mold and process cooling applications.
Understanding the Role of Industrial Chillers in Mold Temperature Control
An industrial chiller removes waste heat generated during molding and machining processes by circulating chilled water through the mold or machine components. Stable chilled water supply is essential: Obuy’s chillers deliver chilled water across a 5–35°C range with temperature control accuracy of ±1°C, which helps maintain consistent mold surface temperatures throughout production runs. This level of precision directly supports repeatable part quality and reduces the risk of thermal-related defects.
Why Air-Cooled Chillers Are Ideal for Mold Cooling Applications
Among the different chiller technologies, air-cooled units are particularly well suited to mold cooling environments where space or water resources are limited. Air-cooled chillers use a vapor-compression refrigeration cycle with air as the cooling medium, eliminating the need for cooling towers, cooling water pumps, or complex piping. This plug-and-play characteristic supports rapid deployment and retrofit projects, allowing manufacturers to install cooling capacity directly on the production floor by simply connecting to a power supply and chilled water pipes.
Obuy’s air-cooled chillers operate across a wide range of -15°C to 45°C and use hydrophilic aluminum fin coils that resist dust accumulation and frost formation, reducing maintenance requirements. According to the company’s technical documentation, maintenance for these units is limited mainly to condenser fin dust cleaning, with no water treatment system needed—an important consideration for mold shops seeking to minimize downtime.
Obuy’s Product Lineup for Precision Mold Cooling
Obuy offers two chiller products designed specifically around mold cooling needs, in addition to its broader air-cooled, water-cooled, heat pump, and evaporative cooling lines.
Industrial Air Cooled Water Chiller for Plastic Injection Molding and Mold Cooling
This chiller is positioned as a dedicated solution for plastic injection molding machine and mold temperature control. It targets the common challenge of heat accumulation in injection molds and hydraulic systems that can affect product quality and cycle times. By using direct air-cooled heat rejection, the unit supports production-floor installation without water system dependencies, helping maintain stable mold temperatures while avoiding cooling tower requirements typically seen in plastics processing facilities.
3 HP Box Type Air-cooled Industrial Chiller, Built-in Water Tank & Pump for Mold Cooling
For mold cooling applications requiring a self-contained setup, Obuy’s 3 HP box-type chiller integrates a water tank and pump directly into a compact footprint, removing the need for separate tank and pump installation. This unit features a high-efficiency condenser and compressor designed for high heat exchange efficiency, with anti-scaling and anti-corrosion components that adapt to varied water quality conditions. It also includes intelligent temperature control and fault self-diagnosis for remote monitoring and easier maintenance, and operates across a wide range of -10°C to 45°C to accommodate complex operating conditions.
Technically, this box-type unit achieves a COP of 3.5–6.5, with energy consumption reduction of over 20% versus standard air-cooled chillers, while maintaining ±1°C temperature control accuracy and stable 5–35°C chilled water delivery. Beyond mold cooling, this configuration is also referenced for use in chemical processing, pharmaceuticals, electronics manufacturing, new energy battery testing, plastic processing, commercial central air conditioning, data centers, laboratory precision instrument cooling, and food processing cold storage—reflecting the flexibility of the box-type design across multiple industrial settings.
Technical Capabilities Supporting Consistent Mold Temperatures
Across its chiller lines, Obuy applies a consistent technology platform built around the vapor-compression refrigeration cycle, with scroll, screw, centrifugal, or piston compressor options depending on product and capacity. For mold cooling specifically, the combination of a wide operating temperature range, ±1°C control accuracy, and anti-scaling/anti-corrosion heat exchange components helps ensure that chilled water quality and temperature remain consistent even as ambient or water-source conditions vary. Intelligent temperature control, fault self-diagnosis, and remote monitoring are standard features across Obuy’s product lines, giving mold shop operators visibility into system performance without requiring constant on-site supervision.
Delivery models for these units include fully integrated plug-and-play configurations, skid-mounted systems with pre-piped interfaces, and split configurations for higher-power installations, giving manufacturers flexibility in how they integrate chilling capacity into existing or new production layouts.
Certifications and Engineering Experience Behind Obuy’s Chillers
Jiangsu Obuy has obtained three major management system certifications—ISO9001, ISO14001, and ISO45001—along with CCC and CE certifications, providing third-party verification of quality, environmental, and occupational health and safety management practices. The company states that it provides energy-saving smart manufacturing and integrated intelligent control solutions based on multi-energy combinations for markets around the world, and has delivered over 1,000 energy-saving solutions and project cases, some in cooperation with Fortune Global 500 companies, foreign-invested enterprises, central state-owned enterprises, and other state-owned enterprises.
Backed by 20 years of engineering experience, Obuy also states that it provides technical guidance, installation, construction, commissioning, and after-sales services, aiming to help customers achieve goals related to low carbon operation, energy saving, consumption reduction, and emission reduction. For mold cooling customers specifically, this breadth of experience translates into equipment that has been engineered and refined across a large number of real-world industrial deployments.
Choosing the Right Chiller for Mold Cooling Needs
When evaluating an industrial chiller for mold temperature control, manufacturers should consider site conditions such as available space, water access, and installation timelines. Obuy’s air-cooled chillers, including its dedicated plastic injection and mold cooling unit and its box-type chiller with built-in water tank and pump, are designed to address these considerations directly—offering stable chilled water from 5–35°C, ±1°C temperature control accuracy, and simplified installation that avoids cooling tower infrastructure.
For manufacturers seeking a chiller solution that combines precise temperature control, reduced installation complexity, and a track record supported by internationally recognized certifications, Jiangsu Obuy New Energy Development Co., Ltd. presents a product portfolio built specifically around the demands of mold temperature control and broader industrial process cooling applications.
https://www.obuytech.com/
Jiangsu Obuy New Energy Development Co., Ltd. -
