19/05/2025 at 13:58 #3038
As the global energy transition and green development trends continue to accelerate, more and more families and businesses are choosing to install solar systems to reduce electricity costs and reduce carbon emissions. As a leading manufacturer of photovoltaic products, the Jinko Tiger series of solar panels we sell has won wide acclaim in the market for their excellent conversion efficiency, reliability, and advanced technology.
However, many people often do not know enough about the performance, applicable conditions, installation precautions, and post-maintenance of Jinko Tiger solar panels before installing them. This article will take you from a professional perspective to fully understand the core knowledge that must be mastered before installing Jinko Tiger solar modules to help you make wise decisions.
1. Introduction to Jinko Tiger Solar Panels
The Jinko Tiger series is a high-end photovoltaic module product launched by Jinko Energy, which uses a number of cutting-edge technologies, such as:
N-type TOPCon high-efficiency cell technology
Half-cut design to reduce power loss
Multi-busbar (MBB) design to improve light capture and current collection capabilities
Low temperature coefficient, better performance in high temperature environments
Among them, the power output range of Tiger Neo, Tiger Pro and other sub-series products covers 400W to 600W or more, which is a highly competitive high-efficiency module on the market.
2. Preparations before installing Jinko Tiger solar panels
2.1 Clarify electricity demand and budget
First, you need to evaluate your electricity consumption: how much electricity does your home or business consume each month, and are there peak and valley electricity prices? Is the goal to generate some electricity for self-use or replace all the electricity from the mains?
At the same time, clarify the budget range. Although Jinko Tiger is a high-end component, its high efficiency can achieve a return on investment (ROI) in a shorter period of time, which is suitable for users with high requirements for power generation efficiency.
2.2 Choose a suitable installation location
The efficiency of solar panels is closely related to the installation location, and the main considerations are:
Roof orientation and tilt angle: In northern China, the best orientation is due south, and the tilt angle should be close to the local latitude.
Sunlight shading: Check whether there are shading factors such as high buildings, poles or trees.
Load-bearing capacity and structure: Jinko Tiger panels usually weigh about 20kg per piece, and it is necessary to ensure that the roof has sufficient load-bearing capacity.
If there is no condition to install on the roof, you can also consider ground brackets or carport systems.
2.3 Communicate with professional installers about the design plan
Although Jinko Tiger modules have outstanding performance, to achieve maximum efficiency, they also need to be reasonably matched with inverters, cables, junction boxes and other system components. It is recommended to choose an experienced installation service provider with power qualifications to customize a personalized design plan and issue a power station simulation report.
3. Detailed explanation of the Jinko Tiger solar panel installation process
3.1 Preliminary survey and drawing design
The installer will come to survey the site, draw the power station design drawing according to the sunshine time, installation area and power demand, and simulate the output power, annual power generation, etc.
3.2 Material preparation and transportation
Jinko Tiger panels are mostly large-size modules, such as 182mm or 210mm cells, so the transportation and handling process should be careful to avoid corner collisions to prevent module breakage.
3.3 Bracket installation and positioning
Install aluminum alloy or galvanized steel brackets according to the drawings to ensure that the brackets are firmly connected to the roof and the angles and directions are accurate. Tiger modules are large in size and require at least two people to collaborate in installation.
3.4 Panel laying and wiring
Lay the Tiger solar panels on the bracket in order and use the MC4 connector to correctly connect them in series or parallel. Make sure that the voltage and current of each group of series panels match the inverter specifications.
3.5 Install the inverter and connect to the grid
Inverters are usually installed near the meter to convert DC power into AC power and connect it to the home grid. Jinko Tiger modules are recommended to be used with brand inverters (such as Huawei, Sungrow, SMA, etc.) to maximize their efficiency.
3.6 System testing and debugging
After the installation is completed, the technicians will conduct a full system test, including insulation, current and voltage, string power generation, etc., to ensure stable operation of the system.
4. Advantages of installing Jinko Tiger panels
4.1 High conversion efficiency, increased revenue
The conversion efficiency of the Tiger series panels is as high as 22%, especially the N-type Tiger Neo modules, which show excellent weak light response and low attenuation rate, which means that you can get higher power generation on the same area.
4.2 Strong reliability and wide adaptability
Jinko Tiger modules have passed a number of international authoritative certifications (such as IEC, UL, TÜV), are resistant to high humidity, high salt spray, and high wind pressure, and are suitable for various complex climate environments.
4.3 Brand guarantee and perfect service
As the world's leading solar brand in terms of shipments, Jinko provides a 25-year linear power output warranty and a 12-15-year product warranty, so that users have no worries.
5. Post-maintenance and usage suggestions
Although solar panels are low-maintenance products, reasonable maintenance still helps to maintain stable performance:
Regularly clean the dust and bird droppings on the surface of the panel, it is recommended to do so at least once a quarter;
Check whether the wiring is loose and whether the inverter is operating normally;
Monitor the real-time data of the system to detect abnormal power generation in time.
Some high-end installation systems also support remote monitoring platforms, which can view power generation data and historical reports on mobile phones for easy management.
Jinko Tiger solar panels have become the preferred photovoltaic module products for many families and businesses around the world with their high conversion efficiency, excellent environmental adaptability and reliable quality assurance. If you are considering installing a solar energy system, whether for self-use or grid-connected profit, Jinko Tiger is a core component you can trust.
Before formal installation, fully understanding the product features, installation details and post-maintenance content will help you build an efficient, safe and long-lasting clean energy system. The future is here, photovoltaics first, choose Jinko Tiger, let green energy start from the roof.
If you need more information about Jinko Tiger components, please contact us. Professional Jinko Tiger component suppliers will provide you with professional, one-to-one solution support.
http://www.janewenergy.com
JA TECH Co.,ltd. -
