16/03/2026 at 14:41 #4727
Dry type transformers play a critical role in modern electrical systems, providing reliable voltage regulation and energy distribution without the need for liquid insulation. At the heart of these transformers are their active parts, which determine performance, efficiency, and durability. Understanding these components and their functions is essential for engineers, technicians, and industry professionals seeking optimal transformer operation. Dingmao (DM), a family-owned comprehensive manufacturer with decades of technical expertise, has been at the forefront of producing high-quality transformer cores, active components, and complete units since 1970. By adhering to strict international standards and leveraging mature manufacturing technologies, DM ensures that their products deliver exceptional reliability and efficiency worldwide.
1. Transformer Core
The core is the central component of a dry type transformer, responsible for providing a controlled path for magnetic flux. High-quality cores minimize energy losses and reduce heat generation, directly impacting the transformer's efficiency. DM specializes in producing amorphous steel cores initially developed in collaboration with GE Prolec, which are widely used in distribution transformers. These cores offer low hysteresis and eddy current losses, making them ideal for energy-efficient designs. Proper core construction ensures mechanical stability, reduced vibration, and long-term durability.
Key functions of the transformer core include:
Magnetic Flux Conduction: Provides a low-resistance path for magnetic flux generated by the windings.
Loss Reduction: Uses high-grade laminated steel or amorphous materials to minimize energy losses.
Structural Support: Maintains the alignment of windings and reduces mechanical stress during operation.
For more details on DM’s advanced dry type transformer cores, visit DM Dry Type Transformer Active Parts.
2. Windings
Windings are conductive coils wound around the core to facilitate voltage transformation. Dry type transformers typically use copper or aluminum conductors, insulated with high-quality varnishes or resin-impregnated materials. DM ensures precise winding processes to maintain uniformity, prevent overheating, and optimize electromagnetic performance.
Primary functions of windings include:
Voltage Transformation: Converts voltage levels between primary and secondary circuits.
Current Handling: Carries the rated current efficiently while minimizing resistive losses.
Thermal Management: Works in conjunction with core and insulation to manage heat generation.
Advanced winding techniques, such as interleaved or sector windings, enhance efficiency and reduce leakage inductance, which improves voltage regulation and transformer lifespan.
3. Insulation System
In dry type transformers, insulation is critical for ensuring safety and operational reliability. Unlike oil-filled transformers, dry type designs rely on solid insulation materials such as epoxy resin, Nomex, or silicone-based compounds. DM’s dry type transformers use state-of-the-art insulation systems that comply with international standards and provide excellent electrical and mechanical protection.
Key functions of the insulation system:
Electrical Isolation: Prevents short circuits between windings and the core.
Thermal Protection: Resists heat and thermal cycling without degradation.
Mechanical Stability: Maintains coil integrity under vibration and load fluctuations.
The proper design of insulation systems extends transformer service life and minimizes maintenance requirements.
4. Magnetic Shielding and Damping Components
Magnetic shielding and damping components reduce electromagnetic interference (EMI) and mechanical vibrations within the transformer. These components include laminated shields, vibration-damping pads, and resin encapsulation. DM incorporates these technologies to enhance transformer stability and reduce noise, which is particularly important in indoor and urban installations.
Functions include:
Noise Reduction: Minimizes humming and vibration during operation.
EMI Mitigation: Reduces interference with nearby electronic equipment.
Enhanced Durability: Prevents mechanical wear and fatigue in the windings and core.
5. Terminals and Connections
The terminals and connection points provide safe interfaces for electrical input and output. In dry type transformers, connections must accommodate thermal expansion, mechanical stress, and electrical load fluctuations. DM’s precise terminal design ensures secure connections and reliable conductivity, which are crucial for long-term transformer performance.
Functions include:
Electrical Continuity: Provides low-resistance paths for current flow.
Ease of Installation: Facilitates connection to primary and secondary circuits.
Safety Assurance: Reduces risk of electrical arcing or accidental contact.
6. Protective Components
Modern dry type transformers often include protective devices such as temperature sensors, pressure relays, and overload protection. While dry type transformers do not use liquid insulation, monitoring systems are essential for preventing overheating and ensuring safety. DM integrates these protective measures in their transformer designs to maintain operational reliability and comply with global safety standards.
Key functions:
Temperature Monitoring: Detects overheating early to prevent damage.
Overload Protection: Prevents excessive current from damaging windings or insulation.
Operational Safety: Ensures compliance with local and international safety regulations.
7. Resin and Encapsulation
Resin encapsulation is widely used in dry type transformers to protect windings and components from moisture, dust, and mechanical stress. The resin also improves heat dissipation and provides additional structural support. DM employs high-quality epoxy resins with uniform curing to enhance thermal performance and mechanical stability.
Functions of resin and encapsulation include:
Moisture Protection: Prevents corrosion and insulation breakdown.
Heat Management: Aids in thermal conductivity and cooling.
Structural Integrity: Keeps windings secure and reduces vibration.
The active parts of dry type transformers—including cores, windings, insulation systems, protective devices, and encapsulation materials—work together to ensure high efficiency, durability, and safe operation. Dingmao (DM), with decades of manufacturing expertise and a commitment to exceeding international standards, delivers transformers that excel in performance and reliability. By carefully designing and producing each component, DM ensures that their dry type transformers meet the demands of modern energy systems worldwide.
For a deeper exploration of DM’s high-quality dry type transformer components, see DM Dry Type Transformer Active Parts.
http://www.dmtransformer.com
Dingmao (DM) -
