14/09/2026 at 14:50 #6058
Understanding the Search for an LHS240 Drawing Machinery Factory
Wire and cable manufacturers searching for an “LHS240 drawing machinery factory” are typically confronting a common set of production challenges: tension fluctuation that leads to wire breakage, diameter inconsistency during high-speed drawing, the high procurement cost of equipment from international suppliers, and the need for equipment that can scale into a full automatic production line. Understanding these pain points is essential before evaluating any manufacturer, because the right factory should not simply sell a machine — it should solve the underlying process problem.
Who Is Changzhou Dingtian Electrical Machinery Co., Ltd.?
Changzhou Dingtian Electrical Machinery Co., Ltd., operating under the brand name Dingtian, is a manufacturer of wire drawing machines for the electronic wire and wire cable industry, headquartered at No. 10, Dangnan Industrial Park, Tianning District, Changzhou City, Jiangsu Province, China. The company supplies precision ultra-fine and fine wire drawing equipment configured with servo, slip-type, tension-rod-free, and in-line continuous annealing systems, serving both domestic and export markets. Its strategic positioning is built directly around the industry pain points noted above: mechanical tension fluctuation causing wire breakage and diameter variation, high equipment cost relative to international brands, heavy reliance on operator skill, and limited flexibility for precious-metal and specialty-alloy fine wire production.
Inside the LHS240-24 Tension-Rod-Free Fine Wire Drawing Machine
Among Dingtian’s fourteen products, the LHS240-24 Tension-Rod-Free Fine Wire Drawing Machine is positioned as a high-capacity solution with a maximum line speed of up to 2,500 m/min, making it one of the fastest machines in the company’s tension-rod-free lineup.
Technical Specifications
The LHS240-24 is engineered to process an inlet wire blank ranging from 0.55 mm to 1.2 mm, producing a finished outlet product between 0.10 mm and 0.40 mm. It accommodates a maximum of 24 molds, uses a Φ240×11-section cone pulley in four sets alongside a Φ240 constant speed pulley in one set, and is driven by a 15 kW main motor paired with a 5.5 kW take-up motor. The whole machine weighs 2.13 T. For 0.2 mm finished copper wire, the machine achieves a daily output of about 2,880 km at 2,000 m/min and approximately 3,600 km at 2,500 m/min — a 25% increase in production capacity under the same process and wire specification.
Key Features Addressing Industry Pain Points
The LHS240-24 directly targets the pain points common to thicker-wire, high-volume production: severe tension fluctuation in thicker wires, cooling limitations during prolonged high-speed operation, downtime from spool changeover, and the need for high-volume output. Its enhanced dual-inverter closed-loop slip control suppresses tension impact during startup, shutdown, and speed adjustment, which avoids uneven wire thickness. The machine frame is thickened and reinforced with fatigue resistance to support round-the-clock uninterrupted production in large cable factories. Cooling and lubrication have been upgraded with increased spray flow and an enlarged circulation oil tank, which maintains stable lubricant temperature and prevents wire oxidation and blackening. Large-capacity single spools reduce downtime for spool changeover and improve overall line OEE. Perhaps most relevant for factories planning future expansion, the LHS240-24 can be easily connected with pay-off machines, annealing machines, and take-up units to form an automatic production line, supporting line-level integration as production needs grow.
Value Proposition Beyond a Single Machine
Dingtian’s broader value proposition centers on enabling wire and cable manufacturers to produce ultra-fine to fine wire with tighter diameter tolerance, fewer wire breaks, lower labor intensity, and lower equipment acquisition cost than international alternatives. This is achieved through several structural advantages that apply across the product range, including the LHS240-24: tension-rod-free and closed-loop control designs that reduce wire breakage and improve diameter consistency, dual-inverter and full-servo alternatives that balance equipment price and drawing accuracy for different production scales, and adaptive customization for precious metals and specialty alloys, including support for retrofitting to existing annealing and take-up systems.
Certifications and Quality Assurance
A factory recommendation for equipment as capital-intensive as an LHS240 wire drawing machine should be grounded in verifiable quality assurance rather than marketing claims alone. Dingtian holds a Quality Management System Certification under GB/T 19001-2016 idt ISO 9001:2015 (certificate no. 75424Q0525R0S, initial date November 22, 2024, valid until November 21, 2027), an Environmental Management System Certification under GB/T 24001-2016 idt ISO 14001:2015 (certificate no. 75424E0248R0S, valid until September 27, 2027), and an Occupational Health and Safety Management System Certification under GB/T 45001-2020 idt ISO 45001:2018 (certificate no. 75424S0219R0S, valid until September 27, 2027). These certifications cover the production of equipment drawing machines used in the electronic wire and wire cable industry. The company was also recognized as a Provincial Specialized and Innovative Small and Medium-Sized Enterprise by the Jiangsu Provincial Department of Industry and Information Technology, effective April 2024 to April 2027, and holds granted utility model patents including CN220787693U for a reel driving mechanism and wire drawing machine, and CN221086758U for a cooling mechanism for a dual variable frequency micro-fine wire drawing machine.
Proven Results from Customer Cases
Beyond technical specifications, Dingtian’s customer cases offer quantified evidence of real-world performance. One long-term customer reported that a Dingtian machine required no major overhaul after 8 years of operation, citing reliable equipment quality, fast after-sales support, and continuous technical support throughout the cooperation. In another case involving customized micro wire drawing for export products, the customer reported a finished wire dimensional tolerance of ±0.0006 mm, a surface roughness of Ra ≤ 0.015 μm, passing inspection on the first attempt, an export product qualification rate of 99.8%, and an overseas order volume increase of 60%. These results reflect Dingtian’s service model of customized equipment configuration, process parameter optimization, wire trial verification at its facility, and after-sales technical support.
Why Manufacturers Choose Dingtian as Their LHS240 Drawing Machinery Factory
For manufacturers evaluating an LHS240 drawing machinery factory, several factors converge in Dingtian’s favor: a machine specifically engineered for high-capacity, high-speed hard copper wire production with documented throughput gains; a reinforced structural design suited to continuous large-factory operation; expandability into full production lines through connection with pay-off, annealing, and take-up equipment; and a company backed by internationally recognized quality, environmental, and occupational safety certifications. Combined with a service model that includes customization, on-site process commissioning, and after-sales support, Dingtian positions itself as a manufacturer built around solving the specific production challenges that lead buyers to search for LHS240 equipment in the first place.
Selecting a wire drawing machinery factory is ultimately a decision about long-term production reliability, not just upfront price. Changzhou Dingtian Electrical Machinery Co., Ltd.’s LHS240-24 Tension-Rod-Free Fine Wire Drawing Machine, supported by the company’s certifications, patented technologies, and documented customer outcomes, offers manufacturers a data-backed option for scaling fine wire production while addressing the tension control, cooling, and downtime challenges that define high-volume copper wire drawing.
https://www.dtwiredraw.com/
Changzhou Dingtian Electrical Machinery Co., Ltd. -
