18/09/2025 at 14:58 #3900
https://www.sowaysensing.com/blogs/Magnetostrictive-Displacement-Sensors-Precision-Solutions.html
Industrial Applications
Soway’s magnetostrictive displacement sensors are designed for high-precision hydraulic and industrial applications. They are ideal for hydraulic cylinder position feedback, injection molding machines, rolling mills, and lifting & hoisting equipment, providing accurate and reliable displacement measurement even in demanding industrial environments.
The sensors are housed in pressure-resistant stainless steel tubes capable of withstanding high hydraulic pressures. The flange uses an O-ring seal to protect the high-pressure area, and the electronics are integrated into a protective housing mounted externally on the cylinder, ensuring stable and long-term performance.
Key Features
High Precision: Resolution of 0.001 mm ensures accurate displacement measurement.
Wide Measurement Range: Stroke lengths from 80 mm to 3000 mm to suit various industrial applications.
Fast Response: Update time of 1 ms (≤1000 mm) / 2 ms (≤3000 mm) provides reliable and timely measurement.
Flexible Output Options: Supports voltage (0.5–4.5 VDC, 0–5 VDC, 0–10 VDC), current (0–20 mA, 4–20 mA), and digital RS‑485 / Modbus outputs according to system requirements.
Non-Contact Operation: Ensures no mechanical wear and maintenance-free operation for long service life.
Durable Construction: Stainless steel measuring rod resists pressures up to 35 MPa, with protection ratings IP67 (optional IP68) for harsh environments.
Flexible Installation: Various thread types allow easy integration into hydraulic cylinders and industrial machinery.
Customer Support & Flexible Solutions
Tailored Offers for Clients: Soway provides dedicated support and competitive pricing for returning and long-term customers.
Custom Configuration: Products can be configured to meet specific project requirements, including stroke length, output type, and protection level.
Practical Packaging & Logistics: Flexible packaging options ensure safe shipping and convenient handling for bulk or custom orders.
Soway’s magnetostrictive displacement sensors combine high precision, reliability, and long service life, making them the preferred solution for high-precision displacement control in industries such as oil, chemical, steel, port, food, and machinery manufacturing.
Shenzhen Soway Tech Limited. (Soway) -
