24/07/2025 at 10:26 #3618
1.Product Overview
Medium efficiency bag filters serve as intermediate filtration in HVAC systems, protecting downstream filters and system components. In environments with moderate air cleanliness requirements, air treated by these filters can be directly supplied to end users.
2. Construction Features
– Filter Media: synthetic fibers ,nonwoven media or imported fiberglass
– Frame: Anodized aluminum alloy profile
– Internal Support: Powder-coated cold-drawn steel wire frame
– Key Advantages:
✓ Large effective filtration area
✓ High dust-holding capacity
✓ Low airflow resistance
✓ Reusable frame structure (only bags require replacement)
✓ Cost-effective maintenance
3. Technical Specifications
| Efficiency Grade | Filtration Efficiency | Color Code | Primary Applications |
| G4 | 35% | – | Pre-filter stage |
| F5 | 45% | White | Pre-medium filtration|
| F6 | 65% | Orange | Commercial buildings, theaters, transportation hubs |
| F7 | 85% | Green | Spray booths, schools, server rooms |
| F8 | 95% | Pink | Pharmaceuticals, food processing, hospitals |
| F9 | 98% | Yellow | Electronics, defense, cleanrooms |
4. Standard Dimensions
– 592×592×600mm (6-pocket)
– 290×592×600mm (3-pocket)
– 592×592×600mm (8-pocket)
– 290×592×600mm (4-pocket)
Custom sizes available upon request
5. Maintenance Protocol
– Replacement Cycle: 3-4 months at rated airflow
– Pressure Drop Indicator: Replace when ΔP ≥400Pa
– Washable Models:
✓ Clean with water/neutral detergent
✓ Air-dry completely
✓ Maximum 2 cleaning cycles
– Note: Service life decreases proportionally with higher particulate concentrations
6. Industry Applications
Widely implemented in critical sectors including:
– Electronics manufacturing
– Pharmaceutical production
– Healthcare facilities
– Food processing plants
This advanced filtration solution represents optimal performance in medium-efficiency air treatment, combining robust construction with operational efficiency. All specifications comply with international air filtration standards (EN779/ISO 16890).
https://www.amdfil.com/medium-efficiency-bag-filters-for-air-purification-systems.html
http://www.amdfil.com
Guangzhou AMD Filtration Technology Co., Ltd. -
