18/05/2026 at 14:46 #5017
In the modern food manufacturing landscape, maintaining absolute product integrity is no longer just a regulatory requirement—it is the cornerstone of brand trust. For global food processors dealing with rigid packaging such as tin cans, glass jars, and Tetra Pak containers, foreign object contamination poses a severe threat.
To mitigate these risks, leading manufacturers are shifting from traditional metal detectors to advanced X-ray inspection systems. As a premier Chinese pioneer specializing in the food safety inspection sector, VIXDETECT is at the forefront of this technological revolution, delivering highly customized, HACCP-compliant X-ray inspection solutions tailored to the unique challenges of the canning and bottling industries.
The Complex Challenges of Inspecting Bottles, Cans, and Jars
Inspecting rigid packaging presents unique obstacles that standard inspection systems fail to address. Food manufacturers frequently encounter:
· Blind Spots: The thick bottoms of glass jars, the ridges of tin cans, and the corners of polygonal containers often hide contaminants from standard single-beam X-rays.
· High-Speed Line Demands: Modern production lines move at blistering speeds, requiring inspection systems that can keep pace without sacrificing accuracy.
· False Rejection Rates (FRR): Variations in packaging thickness can trigger false alarms, leading to costly product waste and unnecessary downtime.
· Material Diversity: Contaminants are not limited to metal; bone, glass, stones, and high-density plastics also threaten product safety.
To solve these industry-wide pain points, the VIXDETECT X-ray for Bottles, Cans & Jars series leverages advanced detection technology and versatile hardware configurations to eliminate blind spots, lower the Total Cost of Ownership (TCO), and protect brand reputation.
Core Advantages of VIXDETECT X-Ray Inspection Technology
The VIXDETECT product ecosystem is engineered around four core pillars: Sensitivity Optimization, Universal Compatibility, Strategic Foresight, and Exceptional Design.
1. Sensitivity Optimization & Precision Imaging
Achieving high-precision detection requires a perfect synergy between hardware and software. VIXDETECT enhances detection accuracy through:
· Multiple Hardware Combinations: Tailored X-ray sources and detectors maximize the contrast between the product and foreign objects.
· High-Bit Grayscale Imaging: Provides ultra-clear, high-resolution imagery, allowing the system to identify minuscule foreign bodies that traditional systems miss.
· Multi-Layered Detection Algorithms: Customized threshold algorithms dynamically adapt to the product's density variations, drastically reducing the False Rejection Rate (FRR) while boosting sensitivity.
2. Universal Compatibility & High-Speed Integration
Modern food factories cannot afford bottlenecks. VIXDETECT systems are built to match the speed of high-throughput production environments:
· Versatile Beam Configurations: Supports horizontal single-beam, angled single-beam, and multi-beam configurations depending on the application.
· Industry-Leading Speeds: Capable of seamlessly inspecting up to 1,800 containers per minute, ensuring zero drag on high-speed filling lines.
· Seamless Line Integration: Designed with different detector specifications to ensure optimal performance across diverse food matrixes.
3. Strategic Foresight: Future-Proofing Your Line
Packaging trends evolve, and VIXDETECT ensures your capital investment remains secure.
· Adaptive Software: The system flexibly adapts to production line upgrades, changes in packaging designs, or new container styles.
· Risk Mitigation: By reliably catching both metallic and non-metallic foreign objects, it protects retail contracts, prevents catastrophic product recalls, and secures consumer satisfaction.
4. Exceptional Design & Low Footprint
Floor space is premium real estate in any manufacturing plant. VIXDETECT addresses this with tailored installation solutions:
· Reduced Modification Costs: The compact footprint minimizes the need for extensive production line restructuring.
· Integrated Conveyor Units: Available as an all-in-one conveyor-equipped unit to accelerate plug-and-play integration into existing lines.
Deep Dive: VIXDETECT Targeted Model Solutions
Different container characteristics demand different X-ray geometries. VIXDETECT has developed specialized models to eliminate specific inspection blind spots.
Feature / Specification
Model VXD-D1825-S
Model VXD-D2253-D
Beam Configuration
Single source: 1 Horizontal + 1 Customizable Tilted Beam
Multi-source: 2 Horizontal + 1 Angled Beam (Dual-View Approach)
Primary Target Packaging
Standard cans, bottom-heavy jars, curved glass
Tetra Pak (up to 270 mm), round/polygonal glass jars
Blind Spot Elimination
Penetrates container bottoms
Penetrates both bottom and sidewalls simultaneously
Contaminant Capability
Metallic & non-metallic in hard-to-reach base areas
Comprehensive multi-angle detection for complex shapes
Model VXD-D1825-S: The Bottom Blind-Spot Eliminator
Traditional X-ray systems projecting a straight horizontal beam often miss contaminants settled at the dome or bottom rim of a tin can or glass jar.
The VIXDETECT Model VXD-D1825-S solves this by utilizing a single X-ray source split into a horizontal beam and a customizable tilted beam. By altering the viewing perspective, the tilted beam directly penetrates the container bottoms. This eliminates traditional inspection blind spots, ensuring that both metallic and non-metallic contaminants located in the most challenging bottom areas are accurately identified and rejected.
Model VXD-D2253-D: Comprehensive Dual-View Mastery
For complex packaging geometries—such as tall Tetra Pak containers or multifaceted polygonal glass jars—a single-view system is insufficient.
The VIXDETECT Model VXD-D2253-D employs an advanced dual-view approach featuring dual horizontally projected beams combined with an additional angled beam. This system easily handles tall packaging profiles (up to 270 mm in height). Because the X-ray beams penetrate through both the bottom and the sidewalls of the containers simultaneously, it offers a 360-degree comprehensive inspection solution that leaves no room for foreign objects to hide.
Why Global Brands Trust VIXDETECT for Food Safety
As a dedicated specialist in food safety detection, VIXDETECT combines cutting-edge Chinese manufacturing agility with strict adherence to global food safety standards like HACCP, BRC, and IFS.
By choosing VIXDETECT, food processors gain a partner committed to lowering the Total Cost of Ownership through durable hardware, free lifetime algorithmic optimization updates, and localized technical support. Whether you are packaging sauces in glass jars, beverages in Tetra Paks, or infant formula in tin cans, VIXDETECT provides the precise, high-speed foresight your brand needs to thrive in a competitive market.
Frequently Asked Questions (FAQs) About Canned Food X-Ray Inspection
Can X-ray systems detect glass contaminants inside glass jars?
Yes. Because glass foreign objects have a slightly different density than the glass container itself, VIXDETECT’s high-bit grayscale imaging and customized threshold algorithms can successfully differentiate and detect glass-in-glass contamination.
What is the maximum production line speed VIXDETECT can handle?
The VIXDETECT series is engineered for high-output environments and can inspect up to 1,800 containers per minute, integrating seamlessly into high-speed automation lines.
How does VIXDETECT help comply with HACCP standards?
HACCP requires identifying Critical Control Points (CCPs) where hazards can be prevented. A VIXDETECT X-ray system serves as the ultimate CCP at the end of the packaging line, automatically logging inspection data and ensuring no contaminated products leave the facility.
Contact VIXDETECT today to get a customized X-ray inspection solution assessment for your bottling or canning production line.
http://www.vixdetect.net
vixdetect -
