10/10/2026 at 18:55 #6242
Selecting the right thermistor chip for temperature sensing applications requires careful consideration of electrical parameters, dimensions, operating temperature, and assembly requirements. As an NTC thermistor chip manufacturer, we offer a range of chip specifications and customization options to support temperature sensing solutions across different industries.
How to Select an NTC Thermistor Chip for Temperature Sensing Applications?
Our NTC thermistor chips feature a Negative Temperature Coefficient (NTC), meaning their resistance decreases as temperature rises. With various R25 values, B values, tolerances, dimensions, and operating temperature ranges available, we support both standard specifications and customized sensor development projects.
Compact NTC Thermistor Chips for Space-Limited Designs
As electronic products become increasingly compact, the size of temperature sensing components plays a more important role in product design.
Our NTC thermistor chips feature a compact structure, with dimensions customizable according to customer requirements. Consistent chip dimensions also support automated assembly, helping manufacturers integrate sensing elements into different sensor designs and electronic products.
Typical applications include:
Battery temperature monitoring
Wearable electronics
Smart home devices
Temperature probes
Automotive electronics
Industrial control equipment
Selecting the Right R25 and B Values
R25 resistance and B value are two essential parameters when choosing an NTC thermistor chip.
Available R25 values include 5KΩ, 10KΩ, 20KΩ, 50KΩ, 100KΩ, and 1000KΩ, while available B values include 3380K, 3435K, 3470K, and 3950K. Customized values can also be developed according to specific project requirements.
For different applications, we offer B value tolerances of ±1%, ±2%, and ±3%, while resistance tolerance can be ±1% or customized as needed.
Selecting the appropriate R25 and B values helps match the thermistor's resistance-temperature characteristics to the requirements of the temperature sensing circuit.
Customized Dimensions and Electrical Parameters
Different temperature sensing products require different chip specifications. Battery sensors, medical temperature probes, and industrial control devices may have different requirements for chip size, resistance, temperature range, and R-T characteristics.
As an NTC thermistor chip supplier, we support customization of key parameters, including:
Chip dimensions
R25 resistance
B value
Resistance tolerance
B value tolerance
Operating temperature range
R-T curve
We also offer different surface electrode materials, including gold, silver, and palladium, according to customer requirements.
These customization options help OEM and ODM customers develop temperature sensing components tailored to their product designs.
Flexible Packaging and Assembly Compatibility
NTC thermistor chips serve as the sensing elements within a variety of finished sensor products.
Our NTC thermistor chips can be incorporated into subsequent manufacturing processes such as glass encapsulation, epoxy resin packaging, silicone potting, and SMD assembly, depending on the intended sensor design and production requirements.
This flexibility allows customers to select suitable packaging and assembly methods for their finished temperature sensing products.
NTC Thermistor Chip Applications
Our NTC thermistor chips serve a broad range of industries, including consumer electronics, automotive electronics, medical equipment, industrial systems, energy equipment, and smart home products.
Consumer Electronics and Home Appliances
In consumer electronics, our NTC chips can support battery temperature protection in smartphones, tablets, TWS earbuds, and smartwatches.
They can also be used for temperature sensing in soy milk makers, coffee machines, air conditioners, and other household appliances.
Automotive Electronics
Automotive systems require dependable temperature monitoring across various electronic components.
Our NTC thermistor chips can be used in new energy vehicle battery packs, motor controller temperature monitoring, in-vehicle air temperature sensors, and seat heater sensors.
Medical Equipment
Temperature sensing plays an important role in many medical and healthcare devices.
Our NTC chips can be used in ear and forehead thermometer probes, ventilator airflow temperature monitoring, and constant-temperature modules for IVD equipment.
Industrial and Energy Equipment
In industrial and energy applications, our NTC thermistor chips can support temperature monitoring and protection in industrial inverters, servo drives, solar inverters, charging equipment, and instrumentation.
They can also be applied to charging pile connector temperature detection.
IoT and Smart Home Devices
As smart home and IoT products become more integrated, compact temperature sensing components are increasingly valuable.
Our NTC chips can be used in environmental sensors, smart plugs with overtemperature protection, and smart thermostatic valves, among other applications.
Consistent Manufacturing of NTC Thermistor Chips
Consistent R25 and B values are essential for calibration and finished sensor performance. Maintaining stable manufacturing processes helps ensure that thermistor chips meet their specified electrical characteristics.
We manage key production stages, from ceramic powder formulation and tape casting to high-temperature sintering and electrode processing. Statistical Process Control (SPC) is applied to important production parameters to help maintain consistency within and between batches.
Our NTC thermistor chips are designed to withstand thermal shock and high-temperature, high-humidity conditions. The standard operating temperature range is -40°C to +125°C, with an extended range of -55°C to +150°C available for applicable requirements.
Working with an NTC Thermistor Chip Manufacturer
For OEM and ODM customers, selecting an NTC thermistor chip supplier involves more than choosing a nominal resistance value. Material control, manufacturing consistency, parameter customization, and production capabilities are also important considerations.
We focus on material control, process consistency, customized specifications, and manufacturing capability to support customers from initial component selection through application development.
Our integrated production process covers ceramic powder formulation,
https://www.jscgsensor.net/ntc-thermistor-chip-for-temperature-sensing-applications.html
Shenzhen Jinshi Sensing Technology Co., Ltd. -
