06/03/2026 at 19:34 #4713
You need reliable equipment when you work in tough places like oil and gas, hydrocarbon, or chemical processing. OH3 vertical overhung pumps are the best choice for high reliability. Their strong design works well in hard conditions, like high heat and pressure, so your operations stay safe and run smoothly.
Key Takeaways
OH3 vertical overhung pumps work well in hard places like oil and gas. They help keep things safe and running smoothly.
These pumps follow API 610 rules. They work well in high heat and pressure. Advanced sealing systems stop leaks.
The vertical in-line design uses less space. It is easy to install. This is good for busy factories where space is important.
Regular maintenance is very important. Daily checks and quick repairs help the pump last longer and work better.
Picking the right materials and sealing systems for your fluids helps the pump work well. It also means less downtime.
What Are OH3 Vertical Overhung Pumps
OH3 vertical overhung pumps are used in tough jobs. They help move liquids in places like oil, gas, and chemical plants. These pumps work well even when it is very hot or there is a lot of pressure. They also fit where there is not much room. The design follows strict rules for safety and efficiency. These pumps have special features to help them work safely and save energy.
API 610 Compliance
You need pumps that follow important rules. OH3 pumps meet API 610 standards. This is the main rule for centrifugal pumps in oil, gas, and chemical work. Because of this, you get:
Pumps that work well in hot and high-pressure places
Pumps that use API 682 mechanical seals to stop leaks
Pumps with standard flange connections for easy setup
API 610 means each pump can handle many flow rates and heads. They can work with pressures up to 2.5 MPa. They can also handle many types of process fluids at different temperatures.
Vertical In-Line Design
The vertical in-line design gives you many benefits. The pump sits right in the pipeline. This saves floor space. The suction and discharge nozzles are lined up. You do not need extra pipes or supports. You also get:
Feature
Description
Space-saving design
Small size fits in tight areas
Easy installation
Lined up nozzles make setup simple
Reduced traffic requirements
Less stuff in busy pump rooms
High-efficiency impeller
Works well and saves energy
Back pull-out configuration
You can fix the pump without moving the motor
Overhung and Flexible Coupling Features
OH3 pumps have an overhung shaft with a strong bearing box. This helps balance forces inside the pump. It means less shaking and longer life for the bearings. You get:
A single suction, balanced closed impeller for smooth running
Special diffusers designed by computers to lower forces inside
A flexible coupling between the motor and pump for easy setup and less wear
Bearings with grease and separate brackets for steady, easy care
Tip: The back pull-out feature lets you fix the pump fast. This keeps downtime short and helps your process stay reliable.
With all these features, OH3 vertical overhung pumps are strong, efficient, and save space. They are a great choice for important jobs in process plants.
High Reliability Advantages
Robust Construction
You need a pump that works in hard places. The OH3 vertical overhung pump uses tough materials and smart building methods. This design makes the pump very reliable every time you use it. The pump meets API 610 and ISO 5199 rules, so it is ready for hard jobs. You can check the main details in the table below:
Specification
Details
Compliance
API 610 (11th edition) or ISO 5199
Hydraulic capacity
50-5,000 m³/h
Pressure ratings
Up to 100 bar
Temperature tolerance
-80°C to +450°C
Material for corrosive fluids
Duplex stainless steel
Material for hydrocarbons
Carbon steel
You get more protection with things like cooling jackets. These stop the bearings from getting too hot. Centerline support keeps the pump straight, even when it gets hot or cold. If you need to move hot liquids, you can use bellows mechanical seals. For special chemicals, you can pick PTFE-lined or high-silicon cast iron for sulfuric acid. Nickel-based alloys work for sodium hydroxide. Open impellers help with thick liquids. These choices help you keep your pump working well in every job.
Note: The closed radial impeller and strong rings on both sides help the pump last longer and run smoothly.
Operational Stability
You want your pump to work without problems. The OH3 pump gives steady performance, even when you use it a lot. The double volute design splits the liquid into two ways. This balances the forces inside and lowers shaking. You get less shaft bending and less wear on the bearings. The table below shows how the pump's parts help you:
Component
Advantage
Less wear, longer durability
Exact craftsmanship
Reduced shaking and sound
High MTBF
Fewer sudden stops
You will see smoother turning and less wobbling, even when the pump works hard. The centerline support and diffuser design also help keep things steady. You get high reliability because the pump does not shake or make loud sounds. This means fewer breakdowns and less time fixing things.
The double volute cuts up to 90% of side forces.
Even pressure keeps the shaft steady.
You get longer service life and fewer repairs.
Space-Saving Benefits
You need equipment that fits your plant well. The OH3 vertical in-line pump saves space because it goes right in the pipeline. You do not need extra supports or big bases. The suction and discharge nozzles line up, so you can set up the pump fast. This design makes busy pump rooms less crowded and makes fixing the pump easier.
In-line suction and discharge save floor space.
The back pull-out feature lets you fix the pump without moving the motor.
You can put the pump in small spaces, which helps you use your area better.
Tip: Saving space and less crowding make the OH3 pump great for busy industrial sites.
You get high reliability from strong building, steady work, and a design that fits your plant. The OH3 pump helps you handle high pressure, high heat, and tough chemicals. It also saves space and lowers downtime.
OH3 vs. Other Pump Types
Vertical vs. Horizontal Pumps
Vertical and horizontal pumps are different in how you take care of them. Vertical pumps, like the OH3, use less space. They fit well in small areas. You see them a lot in busy plants where space is tight. Horizontal pumps let you reach inside parts more easily. This makes fixing them faster and simpler.
Pump Type
Maintenance Accessibility
Reliability Implications
Horizontal
Easier to service
High flow capabilities
Vertical
More involved
Space-saving design
Horizontal pumps make it easy to check and change parts. Vertical pumps are harder to fix, but they help you use your plant space better.
In-Line vs. Other Configurations
The OH3 pump has an in-line design. The suction and discharge nozzles are lined up. You can put the pump right into your pipeline. You do not need extra pipes or big bases. This setup costs less and keeps your plant less crowded.
Think about these cost impacts:
Feature
Impact on Costs
Optimized for inline setup
Reduces installation costs due to simplified alignment
Back pull-out design
Lowers maintenance costs by simplifying servicing
The back pull-out feature lets you fix the pump without moving the motor. This saves you time and money when you do maintenance.
Performance and Reliability Comparison
You want a pump that works well and lasts long. The OH3 pump meets API 610 standards. It can handle many flows and pressures. You can use it for hot, cold, or corrosive fluids. The closed radial impeller and strong rings help the pump run smoothly. This means less downtime.
Vertical in-line pumps save space and fit in busy plants.
Horizontal pumps are easier to fix and set up.
The OH3 pump gives you good performance, reliability, and saves space.
Tip: Pick the pump type that fits your plant best. If you need to save space and do tough jobs, the OH3 vertical in-line pump is a smart choice.
Applications & Selection
Key Industries & Use Cases
OH3 vertical overhung pumps are used in very tough jobs. They work in oil and gas, hydrocarbon processing, and chemical plants. These pumps help move liquids, boost pressure, and handle hot or dangerous fluids. The table below shows where these pumps are used every day:
Industry
Specific Applications
Hydrocarbon Processing
Acid Feed, Olefin Charge, Sour Water Handling
Chemical Production
Acid Recirculation, Depropanizer Charge
Other Critical Processes
Polypropylene Feed, Reflux, Overhead
You can also find OH3 pumps in power plants. They move hot water and help with condensate transport. These pumps are used for pipeline pressurization and fuel oil transfer too.
Tip: If you need a pump for hot, high-pressure, or strong chemicals, the OH3 design will work well for you.
Selection Criteria for Reliability
You want a pump that works well and does not break often. First, check if the pump meets API 610 or ISO 13709 rules. Look for in-line suction and discharge, a closed radial impeller, and a flexible coupling. These parts help stop shaking and lower wear. Make sure the pump has wear-resistant rings and uses API 682 sealing systems to stop leaks.
Use this checklist when you pick your OH3 pump:
Make sure it meets API 610 or ISO 13709
Check if it has an in-line design to save space
See if the materials match your process fluid
Make sure it works for your temperature and pressure needs
Look for easy fixes like back pull-out construction
Sizing and Specification
Pick the right size pump for your plant’s flow and pressure. The OH3 pump can move up to 2,600 m³/h and reach heads up to 300 meters. It works in temperatures from -40°C to 250°C and pressures up to 5.0 MPa. Choose duplex stainless steel or carbon steel for tough fluids. Always match the pump’s size and build to what your job needs.
Note: Picking the right size and type helps your pump work better and last longer.
http://www.jsfeiyuepump.com
Feiyue -
