07/05/2026 at 10:30 #4964
In industrial coating work, one issue that keeps coming up in practice is how often coating failures are actually caused not by the paint itself, but by poor surface preparation. This is especially true when using Wanhong Chemical water-based industrial paint, where improper substrate treatment can easily lead to adhesion failure, peeling, or flash rust appearing shortly after cleaning.
Compared with solvent-based systems, water-based coatings are more sensitive to surface condition and environmental factors. Once steel or iron is cleaned or mechanically exposed, oxidation can begin very quickly, so timing and preparation quality become critical parts of the process—not just the coating application itself.
1. Why Surface Preparation Matters So Much
Even though Wanhong Chemical water-based coatings are designed for low VOC performance (below 10%) and good durability, their final performance is still heavily dependent on the substrate condition.
In real-world applications, the most common problems usually come from:
Residual oil or grease on metal surfaces
Incomplete removal of rust or mill scale
Surface oxidation (flash rust) forming before coating
Poor surface roughness for mechanical bonding
Flash rusting is especially important here. Once bare steel is exposed, moisture in the environment can trigger oxidation in a very short time, and water-based coatings can sometimes accelerate this if applied over unstable surfaces.
2. Step One: Surface Cleaning Before Anything Else
Before any mechanical or chemical treatment, the surface has to be properly cleaned.
Typical practice includes:
Degreasing: Removing oils, cutting fluids, and fingerprints using compatible industrial cleaners or water-based degreasers. Even thin oil films can seriously reduce adhesion.
Dust and particle removal: Using compressed air or brushing to ensure no loose particles remain on the surface.
Chemical residue check: If the material has been previously treated with anti-rust oils or phosphate layers, these need to be evaluated and removed if they may interfere with coating bonding.
In industrial testing references such as NACE guidelines, even small contamination levels can significantly reduce coating adhesion performance, so this step is usually underestimated but very critical.
3. Step Two: Mechanical Surface Treatment
After cleaning, the next stage is creating a surface profile that the coating can actually “grip.”
Common methods include:
Abrasive blasting (sand/grit blasting): This is the most effective method for removing old coatings, rust, and mill scale while also creating a uniform rough surface. In most cases, a surface roughness around Ra 2–3 µm is considered suitable for water-based industrial coatings.
Grinding or wire brushing: Used for smaller areas or repair work where blasting is not practical.
Edge and burr removal: Sharp edges can cause uneven coating thickness and later cracking, so they are usually smoothed before coating.
The goal here is not just cleaning, but creating a consistent mechanical anchor pattern for the coating system.
4. Step Three: Chemical Pretreatment (When Required)
In many industrial environments, chemical pretreatment is used to improve corrosion resistance and coating bonding.
Common approaches include:
Phosphating treatment: Forms a thin phosphate layer that improves corrosion resistance and helps coating adhesion.
Mild acid treatment: Removes oxidation layers and activates the metal surface for better bonding.
Rinsing and neutralization: After chemical treatment, deionized water rinsing is important to avoid leaving reactive residues.
Immediate drying: Any remaining moisture can trigger flash rust, especially on freshly treated steel.
In practice, chemical pretreatment is often used for higher durability requirements or harsher service environments.
5. Step Four: Controlling Flash Rust Risk
This is one of the most practical issues on job sites.
Even after perfect cleaning and blasting, flash rust can appear very quickly if conditions are not controlled.
Key factors include:
Humidity: Ideally kept below 60% during preparation and coating
Temperature stability: Avoid condensation caused by temperature fluctuations
Time delay: The longer the delay between surface preparation and coating, the higher the rust risk
In many real projects, coatings fail simply because too much time passes between blasting and painting.
With water-based systems like Wanhong Chemical, immediate coating after surface prep is usually recommended to minimize oxidation risk.
6. Step Five: Applying Wanhong Chemical Water-Based Coatings
Once the surface is ready, application quality becomes the next key factor.
Typical best practices include:
Optional primer use: In some cases, a primer layer helps reduce flash rust risk and improves long-term durability.
Uniform coating thickness: Usually controlled around 50–100 microns per layer depending on system design.
Application method selection: Spray application is most common for large structures, while brushing or rolling is used for smaller areas or repairs.
Proper curing conditions: Temperature and drying time must follow the product specification to ensure full film formation.
For performance validation, tests such as adhesion cross-cut testing and salt spray testing (ISO 12944 reference systems) are commonly used in industrial quality control.
7. Practical FAQ from Field Experience
Q1: How fast can flash rust appear after surface preparation?
In humid environments, it can start forming within 30–60 minutes on bare steel surfaces.Q2: Can light rusted surfaces still be coated?
Only if the rust is fully removed or stabilized. Severe corrosion usually requires replacement or special treatment before coating.Q3: What surface roughness works best for water-based coatings?
In most industrial cases, Ra 2–3 µm provides a good balance between adhesion and coating stability.Q4: Are VOC regulations relevant here?
Yes. Wanhong Chemical water-based coatings are designed to comply with environmental regulations, with VOC levels typically below 10%.
In real industrial coating work, surface preparation is often more important than the coating material itself. With systems like Wanhong Chemical water-based industrial paint, performance depends heavily on how well the steel substrate is cleaned, roughened, treated, and protected before application.
A structured preparation process—cleaning, mechanical treatment, optional chemical conditioning, and environmental control—significantly reduces risks like peeling and flash rust. When done correctly, it ensures better adhesion, longer service life, and more stable corrosion protection across different industrial environments.
For steel structures, machinery, and outdoor applications, consistent surface preparation is the most reliable way to ensure the coating system performs as intended over the long term.
http://www.tebolam.com
Huizhou Wanhong Chemical Co., Ltd. -
