17/11/2026 at 09:39 #6609
On soft ground, prefabricated vertical drains are generally faster to install, more economical per metre, and far more dependable at depth than sand wick drains. Experience from ground-improvement projects in China and overseas consistently shows PVD shortening consolidation periods and lowering overall treatment costs by a meaningful margin. Shengyuan, a China-based manufacturer that also runs its own installation rigs, can supply both the board and the crew.
1. Prefabricated Vertical Drain vs Sand Drain: Which Is Better?
For almost all soft-ground projects, the prefabricated vertical drain vs sand drain which is better question resolves in favour of PVD — because the board is made in a factory rather than built in the hole.
A sand wick drain is a column of compacted sand formed in the ground by vibration or bottom-feed equipment. Its quality depends on the sand delivered that day and on the operator keeping the column continuous. A PVD is a thin prefabricated band: a corrugated polymer core wrapped in a nonwoven geotextile filter, manufactured to a fixed specification and driven by a slender mandrel.
Both methods shorten the drainage path and turn slow vertical consolidation into faster radial consolidation. The difference lies in how reliably they keep that path open.
Depth. Sand columns are practical only to moderate depth; beyond that the hole tends to neck or collapse and sand is lost. PVDs reach considerably deeper and are the usual choice for large reclamation works.
Consistency. A factory-made board has a known discharge capacity and filter opening size on every metre. Sand columns vary with aggregate grading and site batching, and one weak stretch can break the drainage path. A thin band behaves hydraulically like a compacted sand column of equivalent diameter — and unlike sand, that performance does not drift along the row.
Filter control. The geotextile jacket is specified to an opening size that blocks fines yet passes water. Sand drains rely on the surrounding soil or an added filter layer, neither of which is checked metre by metre.
Disturbance. The PVD mandrel displaces far less soil than a vibroflot, so the smeared zone around the drain is smaller and the clay keeps more permeability. Shengyuan integral hot-melt boards keep their channels open under confining pressure that would crush a cheaper glued core — see our https://www.sywickdrain.com/integral-hot-melt-type-d-plastic-drainage-board-shengyuan.html .
Verification. Board batches can be sampled for tensile strength and discharge capacity before shipping; a sand wick's performance can only be inferred from volume records after it is buried.
Bottom line: PVD wins on depth, consistency and soil disturbance; sand wicks remain competitive only where local sand is unusually cheap and treatment is shallow.
2. How Much Faster and Cheaper Is PVD Than a Sand Wick Drain?
Field experience on plastic drainage board vs sand wick consolidation rate points to a noticeably shorter consolidation period and a substantially lower installed cost — often a fraction of the sand wick price for the same drainage function. The gap comes from three places: no aggregate to truck in, a faster installation cycle, and far less rework on broken columns.
Material and haulage. A manufactured board plus mechanical placement replaces sand supply, transport and vibration rig time.
Install rate. A single PVD rig covers a large area in a short working window, so sizeable sites are boarded quickly with a modest fleet. Shengyuan operates its own rig fleet alongside deep-mixing and stone-column equipment.
Consolidation maths. Radial drainage time scales with the square of the drainage path, so reducing effective spacing cuts consolidation time sharply. That is the physical reason behind the gain, not a sales claim.
Depth economics. Beyond a certain depth a sand wick's cost climbs steeply as holes collapse and must be recharged, while board cost rises almost linearly with length — so the deeper the job, the wider the gap.
Capacity. Large volumes of board can be produced in-house, so big orders ship without the lead time a sand operation would need.
Shengyuan has supplied boards and installation for major airport, port and reclamation projects in China and Southeast Asia — references that hold up to an overseas audit. Our https://www.sywickdrain.com/key-performance-construction-requirements-for-plastic-drainage-board.html page lists the tolerances held on site. As a China manufacturer offering OEM/ODM and wholesale supply, we quote board-only or board-plus-installation.
Bottom line: PVD delivers the same drainage function at a fraction of the installed metre cost and reaches target strength sooner, making it the default on deep or large-area jobs.
Frequently Asked Questions
Q: Does this PVD vs sand wick drain comparison cost speed depth apply to seaport reclamation?A: Yes. PVD is the standard for reclamation in Southeast Asia and southern China because it reaches deep soft layers under fill without the aggregate a sand column needs. Shengyuan has completed reclamation work at home and abroad.
Q: For a shallow site with cheap local sand, prefabricated vertical drain vs sand drain which is better?A: Where treatment stays shallow and sand is genuinely inexpensive on site, a sand wick can still be economical. Once depth increases or the programme is tight, the prefabricated vertical drain vs sand drain which is better answer flips quickly towards PVD on both cost and certainty.
Q: Do you offer OEM, wholesale and installation from China?A: Yes. Jianhu Shengyuan Soft Base Material Co., Ltd. is a China factory providing OEM/ODM, custom core and filter specifications, wholesale pricing and export documents. We can also send installation crews, so board and placement come from one supplier.
Get a Project-Specific Quote
Send your soil report, treatment area and target depth. Shengyuan will return a free board selection and cost estimate within 48 hours, with factory-direct wholesale pricing and an optional installation plan — no obligation, no generic catalogue.
http://www.sywickdrain.com
Jianhu Shengyuan Soft Base Material Co., Ltd. -
