19/11/2026 at 17:58 #6643
Global HVAC brands, importers, and distributors searching for “R290 inverter heat pump ODM specifications” are generally trying to answer one practical question: which manufacturing partner can deliver a compliant, efficient, low-GWP heat pump under a customized or private label program, backed by real production and testing capability? The following overview, based on verified corporate data from Guangzhou SPRSUN New Energy Technology Development Co., Ltd. (brand name SPRSUN), outlines what buyers should expect from a qualified R290 heat pump ODM partner and how SPRSUN’s documented capabilities address those requirements.
Why R290 Matters for ODM Buyers
R290 (propane) refrigerant has become central to the next generation of eco-friendly heat pumps because it supports the global shift toward environmentally friendly, energy-efficient, and low-carbon heating and cooling solutions. For brands that do not want to independently build R&D and manufacturing systems, working with a manufacturer that already produces R290 units at scale—and has dedicated safety systems for this refrigerant—reduces both technical risk and time to market.
SPRSUN launched its next-generation eco-friendly R290 inverter heat pump in 2023, following more than two decades of heat pump R&D. The company was founded in 1999 and has accumulated over 27 years of heat pump R&D, manufacturing, and sales experience, giving it a long operating history specifically relevant to refrigerant transitions in the HVACR industry.
Core R290 Inverter Heat Pump Specifications
Buyers evaluating ODM specifications typically want to confirm temperature control precision, efficiency gains, noise levels, and refrigerant-specific safety handling. Based on SPRSUN’s documented product data:
- Full DC Inverter Technology: Delivers temperature control accuracy of ±0.5°C and an efficiency improvement of approximately 5%–15% compared with standard inverter systems.
- Quiet Revolution Technology: Achieves sound pressure levels as low as 36 dB(A) at 1 meter, through vibration-damping mounts, acoustic insulation, and a silent-box compressor enclosure.
- ErP A+++ Energy Efficiency: The latest R290 and R32 DC inverter heat pump series have been assessed by TÜV SÜD for ErP A+++ energy efficiency.
- Maximum Outlet Water Temperature: Up to 75°C, applicable across the Multifunctional Heat Pump and Domestic Hot Water Heat Pump lines that utilize R290 refrigerant.
- Advanced Intelligent Remote Control: Wi-Fi app control, IoT cloud management, energy monitoring, and remote fault alerts, supporting both User App and Dealer App interfaces.
These specifications are embedded across SPRSUN’s R290-based product lines, including Air-to-Water Heat Pumps, Multifunctional Heat Pumps, Domestic Hot Water Heat Pumps, and Swimming Pool Heat Pumps—all of which list R290 as a supported refrigerant alongside R32.
Dedicated Safety Systems for R290 Production
Because R290 is a flammable refrigerant, ODM buyers should ask specifically about safety infrastructure during manufacturing. SPRSUN maintains dedicated R290 production safety systems, including a three-level refrigerant leak alarm and response system:
- L3 workstation exhaust: localized ventilation response at the individual workstation level
- L2 full line exhaust: ventilation response across the entire production line
- L1 power cutoff and evacuation: full shutdown and personnel evacuation protocol in the event of a serious leak
This tiered structure indicates that refrigerant safety is addressed as a structured production control rather than a single generic precaution, which is a relevant due diligence point for any brand placing an R290 ODM order.
Manufacturing Scale and Quality Control Behind ODM Orders
Specifications on paper are only meaningful if backed by the manufacturing capacity and quality processes needed to deliver consistent product at volume. SPRSUN operates an 85,000 m² self-owned 5G smart manufacturing facility with annual production capacity over 500,000 units. The facility includes four automated flexible production lines capable of model changeover within 30 minutes, which is directly relevant to ODM buyers who require multiple customized configurations without extended retooling delays.
Quality verification runs through nine specialized laboratories covering performance, acoustic, mechanical reliability, and durability testing, supported by multi-stage quality control with 10 parallel testing stations. Laboratory capability spans an ambient temperature range of -50°C to +60°C and a water temperature range of 5°C to 80°C, with real-time testing data recorded and linked to barcode-traceable inspection reports that are searchable by barcode or product ID, with Excel export available.
What “ODM” Means in Practice at SPRSUN
For brands unfamiliar with the distinction, SPRSUN’s service model clarifies the boundaries between manufacturing arrangements:
- OEM manufacturing: production based on a buyer’s existing design and specification
- ODM product development and manufacturing: SPRSUN handles product development alongside manufacturing
- Private label manufacturing: standard products rebranded under a partner’s label
Across these models, SPRSUN supports customization across appearance, structure, function, technical specifications, control systems, product configuration, branding, and packaging. This breadth is particularly relevant to the R290 inverter heat pump category, where buyers may need configuration differences in outlet water temperature, control module setup, or enclosure design while keeping the same underlying refrigerant and inverter technology.
Order Process and Lead Times
ODM buyers evaluating a manufacturing partner also need clarity on timelines. SPRSUN’s standard products carry a production lead time of approximately 7–40 days after order confirmation, with in-stock sample dispatch possible within 7 days. Customized ODM orders follow a project-based order confirmation process covering specifications, customization scope, minimum order quantity (MOQ), pricing, and estimated delivery schedule. Standard products support sample orders including single units with no fixed minimum order quantity, while customized products have MOQ and pricing evaluated on a per-project basis.
Certifications Relevant to R290 ODM Sourcing
Brands sourcing R290 inverter heat pumps for distribution into regulated markets, particularly in Europe, will want documentation covering compliance schemes. SPRSUN holds ISO 9001, ISO 14001, and ISO 45001 management system certifications, CE product certification, CCC certification, KEYMARK certification, and TÜV testing per EN 14511, along with TÜV SÜD ErP A+++ assessment for the latest R290 and R32 DC inverter heat pump series. The company’s product compliance schemes extend to CE, KEYMARK, AIT, ISO, SAA, RoHS, BAFA, CCC, ErP, MSC, and CB.
Export Experience Supporting International ODM Partnerships
SPRSUN has exported products for 17 consecutive years to Europe, and its products are currently supplied to more than 60 countries and regions worldwide, covering Europe, Asia, Oceania, and the Americas. Approximately 90% of its business comes from overseas markets, with Europe representing more than 70% of overseas business. This export history is directly relevant to ODM buyers seeking a partner already familiar with cross-border compliance and logistics for heat pump products.
For businesses evaluating “R290 inverter heat pump ODM specifications,” the core considerations are refrigerant-specific safety systems, verified technical performance data, manufacturing scale capable of supporting customization without excessive delay, and certification coverage suited to the target export market. SPRSUN’s documented production facility, laboratory infrastructure, three-level refrigerant safety protocol, and ErP A+++-assessed R290 inverter technology collectively address these buyer priorities, positioning Guangzhou SPRSUN New Energy Technology Development Co., Ltd. as a manufacturing partner equipped to support ODM, OEM, and private label heat pump programs built around R290 technology.
https://sprsunheatpump.com/
Guangzhou SPRSUN New Energy Technology Development Co., Ltd. -
