12/11/2024 at 18:38 #1929
Whether you need a 16KW diesel generator or a 20 KVA silent generator, our 50HZ 4-cylinder DG set can provide stable, efficient power support. With flexible customization options, a variety of optional accessories, and strong technical support from ISUZU engines, you will receive a generator tailored to your needs, ensuring smooth operation across various applications and providing long-lasting power reliability for your business.
Superior Power Performance of 20 KVA Silent Generator
This 20 KVA silent generator is equipped with the JE493DB-04 engine from the world-renowned brand ISUZU, which delivers a powerful output of 21KW. It is designed for situations requiring a continuous power supply. ISUZU engines are known globally for their efficient fuel economy and durability. With a fuel consumption rate of less than 230g/kW.h, this engine not only significantly reduces operational costs but also enhances the overall performance of the generator.The engine has a 2.771L displacement and a four-cylinder design, which provides stable power output and low noise levels. The four-cylinder engine construction ensures that the generator maintains stability during long-term operation, making it ideal for various industrial and commercial applications. This 20 KVA silent generator is particularly suited for environments with strict noise requirements, such as hospitals, schools, and office buildings. Its silent design ensures that the generator maintains extremely low noise levels even at full load.
As a leading 20 KVA silent generator manufacturer, our products maintain a stable 50Hz frequency and 1500 RPM speed under full load, ensuring reliable power output for various equipment. Whether used as a primary power source or as an emergency backup, this generator meets diverse needs, ensuring the continuity and reliability of power supply.
Excellent Efficiency of the 16KW Diesel Generator
The 16KW diesel generator is an ideal power solution for industrial and commercial applications, offering excellent energy-saving performance and efficient power output. This generator uses the VG-184ES engine, providing a rated power of 16KW, and can reach up to 22KVA in an emergency. This feature allows it to quickly deliver enough power to keep essential equipment running, avoiding business interruptions or equipment damage during unexpected power outages.In terms of design, the 16KW diesel generator features a sturdy structure with H-class insulation, ensuring that it can effectively resist heat buildup and extend its lifespan during long-term, high-load operations. Additionally, its IP23 protection level safeguards the generator from dust and water droplets, enabling efficient performance even in harsh outdoor environments.
EMEAN POWER is a reliable 16KW diesel generator supplier, offering an efficient diesel fuel system that optimizes fuel utilization while providing high power output, further reducing long-term operating costs. This 16KW diesel generator is ideal for factories, construction sites, and other applications requiring reliable and continuous power supply. It is a dependable power source for both industrial and commercial fields.
Diverse Customization Options to Meet Your Needs
To better accommodate the specific needs of different users, our 20 KVA silent generator and 16KW diesel generator both offer flexible and diverse customization options. Users can choose a voltage range from 110V to 660V, ensuring compatibility with various power systems. Additionally, users can opt for single-phase or three-phase power output based on the specific needs of their environment.The configuration of this 50HZ 4-cylinder DG set is also flexible, allowing users to choose from Stamford, Leroy Somer, or Marathon generators to meet different power requirements. Furthermore, EMEAN POWER offers a variety of smart control panel options, such as Smartgen or Deep Sea, making generator management and monitoring more intelligent and convenient.Users can customize fuel tank capacities based on their operation duration, ensuring sufficient fuel supply during long-term operation and reducing interruptions and maintenance needs. These customization options ensure that the generator meets the diverse needs of users. Whether working under different voltage requirements or adapting to various environmental challenges, customized solutions provide higher efficiency and a better user experience.
Multiple Optional Accessories to Enhance Equipment Performance
To ensure that this 50HZ 4-cylinder DG set performs excellently in various work environments, we offer a wide range of optional accessories. These accessories add more functionality and flexibility to the generator, ensuring efficient and stable operation in complex conditions:
Jacket Heater: Ideal for cold environments, it preheats the engine, ensuring smooth startup in low temperatures.
ATS (Automatic Transfer Switch): Automatically switches to generator power when the main power is off, ensuring uninterrupted operation of key equipment.
Remote Control: Allows users to monitor and manage the generator's status remotely, improving operational convenience.
Oil Heater: Maintains fuel fluidity in extreme cold, ensuring normal operation in low-temperature environments.
Trailer: Provides mobility for the generator, ensuring quick and flexible deployment to areas needing power.
Charger: Provides continuous charging support for the generator's starting battery, ensuring quick startup when needed.
These accessories not only enhance the generator's reliability and durability but also allow for tailored configurations based on actual needs, ensuring adaptability to various working scenarios and operating environments.
ISUZU Engine – The World's Leading Power Source
As a world-leading engine brand, ISUZU is recognized globally for its reliable power output and excellent fuel efficiency. The ISUZU JE493DB-04 engine plays a vital role in the 20 KVA silent generator and the 16KW diesel generator. Its four-cylinder design ensures continuous and stable power output in various working environments. It also offers the advantages of low noise and low vibration, making it ideal for quiet, efficient operations.
ISUZU engines are built for durability and high efficiency, adapting to harsh working environments and widely used in power generation equipment, commercial vehicles, and industrial machinery. Choosing a generator with an ISUZU engine means users benefit from long-term, reliable power. Whether for industrial, commercial, or emergency backup power, ISUZU engines ensure efficient operation under various conditions. For those in need of efficient and stable power solutions, selecting our 50Hz 4-cylinder DG set ensures smooth equipment operation across different working conditions, supporting your business continuously.
https://www.emeanpower.com/ISUZU-16KW-36KW/20KVA-16KW-Diesel-Generator-With-ISUZU-Engine.html
http://www.emeanpower.com
EMEAN POWER -
