01/09/2026 at 18:13 #5963
A shell and tube heat exchanger can remain in service for many years, but its actual performance depends heavily on how the equipment is operated and maintained. In industrial plants, heat-transfer surfaces are exposed to water deposits, process residues, corrosion, suspended particles, and repeated temperature changes. Without proper maintenance, these conditions can gradually reduce heat transfer and increase pressure drop.
For a shell and tube heat exchanger, routine maintenance is not simply a matter of cleaning the tubes when performance drops. A practical maintenance program combines operating data, inspection, cleaning, fluid management, and timely replacement of worn components. This approach helps industrial users maintain predictable thermal performance while reducing unexpected shutdowns.
Monitoring Heat Exchanger Performance During Operation
The easiest time to identify a developing problem is before the exchanger reaches a critical condition. Operators can monitor several basic parameters during normal production and compare them with historical operating data.
Outlet temperature is one of the most useful indicators. If the process-side outlet temperature gradually moves away from its normal range while flow rates remain similar, fouling or reduced heat-transfer performance may be developing.
Pressure drop provides another useful signal. Deposits inside tubes can restrict the flow passage and increase resistance. On the shell side, accumulated material around the tube bundle may also affect fluid distribution.
A practical monitoring routine can include:
Recording inlet and outlet temperatures on both sides.
Checking flow rates at regular intervals.
Monitoring tube-side and shell-side pressure drop.
Comparing current readings with commissioning data.
Investigating gradual changes instead of waiting for a major failure.
These records can also help maintenance teams determine whether a problem is caused by the exchanger itself or by another part of the cooling circuit.
For example, a change in cooling-water temperature may reduce exchanger performance even when the equipment is clean. Similarly, a pump problem can reduce flow and create a thermal performance issue that might initially appear to be exchanger fouling.
This is why industrial heat exchanger maintenance should begin with operating data rather than immediately dismantling the equipment.
Cleaning Methods Depend on Fouling Conditions
Fouling is one of the most common reasons for declining heat exchanger performance. The type of deposit determines the appropriate cleaning method.
Water systems may develop mineral scale, while oil circuits can produce sludge or carbon-based deposits. Process industries may encounter solids, polymers, crystallized materials, or other residues.
Mechanical cleaning is often suitable for tube-side deposits that can be physically removed. Brushes, rods, water jets, and specialized cleaning tools may be selected according to tube diameter and material.
Chemical cleaning can be useful when deposits are difficult to remove mechanically. However, the cleaning chemical must be compatible with the tube, gasket, shell, and process residue. Incorrect chemical selection can damage the equipment rather than improve it.
For some installations, a combination of methods provides better results.
Fouling Type Common Source Possible Maintenance Approach Mineral scale Hard cooling water Mechanical or chemical descaling Oil deposits Lubricating or process oil Solvent or suitable chemical cleaning Suspended solids Poor filtration Flushing and mechanical cleaning Biological deposits Untreated water Water treatment and cleaning Process residue Manufacturing fluid Application-specific cleaning Cleaning frequency should also be based on actual operating conditions. Cleaning too rarely allows deposits to become difficult to remove. Cleaning too frequently can increase maintenance labor and expose components to unnecessary mechanical or chemical stress.
The objective is to maintain acceptable thermal performance without creating an excessive maintenance cycle.
Tube Inspection Helps Prevent Larger Failures
Tubes are among the most important components in a shell and tube exchanger. A small leak can allow the two process fluids to mix, potentially contaminating the product or damaging downstream equipment.
Visual inspection can identify obvious problems such as corrosion, deformation, deposits, or damaged tube ends. However, visual inspection alone cannot detect every internal defect.
Depending on the application, more detailed inspection may include pressure testing, eddy current testing, ultrasonic inspection, or other non-destructive testing methods.
A tube heat exchanger inspection is particularly important for equipment exposed to corrosive fluids, high temperatures, high pressure, or frequent thermal cycling.
Tube condition should be assessed based on:
Wall thickness
Pitting or localized corrosion
Cracks
Erosion
Tube-to-tubesheet joint condition
Internal deposits
Signs of leakage
If only a small number of tubes are damaged, plugging may sometimes be considered as a temporary or practical maintenance measure. However, the allowable number of plugged tubes depends on the exchanger design and required heat-transfer capacity.
Repeated tube failures usually indicate that the underlying operating condition needs investigation. Increasing corrosion resistance, improving filtration, adjusting fluid chemistry, or changing operating conditions may be more effective than repeatedly replacing individual tubes.
Gaskets and Connections Require Regular Attention
The heat-transfer surfaces receive most of the attention during maintenance, but gaskets and connections are equally important for equipment reliability.
Gaskets can deteriorate because of temperature, pressure, chemical exposure, compression changes, or repeated opening of the equipment. A damaged gasket may result in external leakage or internal cross-contamination.
During scheduled maintenance, operators should inspect:
Gasket surfaces
Flange connections
Nozzles
Bolts and fasteners
Tube sheet areas
Shell welds
Drain and vent connections
When an exchanger is opened, gasket surfaces should be cleaned carefully before installing new sealing components. Reusing a damaged or permanently compressed gasket can create leakage problems after the equipment is returned to service.
Bolting should also be tightened according to the equipment manufacturer's recommended procedure. Uneven tightening can create local gasket stress and reduce sealing reliability.
For demanding industrial applications, material compatibility is important. A gasket suitable for cooling water may not be suitable for a chemical process fluid or high-temperature application.
This is one reason customized heat exchanger manufacturing often considers the complete operating environment rather than selecting only the shell and tube dimensions.
Improving Service Life Through Better Operating Practices
Maintenance is only one part of equipment reliability. Operating conditions have a direct influence on how quickly an exchanger deteriorates.
Sudden temperature changes can create thermal stress, especially when the shell and tube materials have different expansion characteristics. Repeated thermal shocks can gradually affect tubes, tube sheets, welds, and sealing components.
Flow conditions also matter. Extremely low flow can reduce heat transfer and encourage deposits. Excessive flow can increase erosion and pressure drop.
Water quality should be controlled when cooling water is used. Filtration and appropriate water treatment can reduce the amount of material reaching the exchanger.
For process fluids, upstream filtration may be equally important. A precision filtration system can prevent suspended particles from entering narrow tube passages and reduce cleaning requirements.
A practical reliability strategy therefore includes:
Maintaining suitable fluid velocity.
Controlling cooling-water quality.
Keeping upstream filters in good condition.
Avoiding unnecessary thermal shock.
Monitoring pressure drop and outlet temperatures.
Scheduling inspections according to actual operating conditions.
These measures can reduce the amount of corrective maintenance required over the equipment's operating life.
Choosing a Heat Exchanger That Supports Maintenance
Maintenance requirements should be considered before a heat exchanger enters service. Different exchanger configurations offer different levels of accessibility.
A fixed tube sheet design can be suitable for many applications, but cleaning the shell side may be more difficult. U-tube designs can accommodate thermal expansion, while floating-head configurations may provide easier access to the tube bundle in applications where regular inspection and cleaning are expected.
Tube diameter and tube arrangement also influence maintenance. Very small passages may provide useful heat-transfer characteristics but can be more difficult to clean when the process contains suspended solids.
Material selection should reflect the actual process. Stainless steel may be preferred in corrosive environments, while other alloys may be required for specific chemical conditions.
A high performance industrial heat exchanger should therefore be evaluated not only by initial thermal performance but also by its expected maintenance requirements.
Maintenance Consideration Design Question Tube cleaning Can the tubes be mechanically cleaned? Shell inspection Is shell-side access sufficient? Tube bundle removal Can the bundle be removed safely? Gasket replacement Are sealing components accessible? Corrosion inspection Can critical areas be examined? Spare parts Are replacement components available? The right configuration is the one that matches the process, maintenance resources, installation environment, and expected service conditions.
A well-maintained shell and tube heat exchanger can provide stable thermal performance across long operating periods, but reliability does not come from equipment design alone. Regular monitoring, appropriate cleaning, fluid-quality control, tube inspection, and correct operating practices all contribute to service life.
For industrial facilities, the most effective maintenance strategy is usually preventive rather than reactive. Small changes in pressure drop, temperature difference, or flow behavior can provide early indications of developing problems. Addressing these changes before severe fouling, corrosion, or leakage occurs can simplify maintenance and reduce disruption to production.
As process equipment becomes increasingly integrated, heat exchanger maintenance also affects the performance of pumps, compressors, cooling systems, and downstream production equipment. A disciplined maintenance program therefore protects more than one piece of equipment. It helps keep the wider thermal system operating within its intended range.
For plants requiring dependable process heating and cooling, choosing a suitable exchanger configuration and establishing a realistic maintenance plan from the beginning provides a practical foundation for long-term operation.
http://www.wyheatexchanger.com
Wangyue Company -
