Viewing 1 post (of 1 total)
09/06/2025 at 16:36 #3190
Smart Glassfiber Diameter Analyser
Using artificial intelligence to analyze the diameter of each fiber, you can count and measure the number of fiber bundles, average diameter, diameter labeling difference, diameter range, coefficient of variation, number and proportion of fibers per group with diameter spacing of 1; the number of measurements is greater than 5,000, and the fastest time is only 3 minutes to see the report results, and there are 24 hours of unattended operation, and a single device can process more than 200 samples per day.
Main Functions of The Product Scope of Application The diameter measurements of natural and non-natural fibers can be performed, such as glass fibers, animal hair fibers, bamboo fibers, carbon fibers, etc., and the data can be analyzed. 24no one on duty at the hour Automatic scanning equipment, without manual intervention, automatically finds the position of the slide after putting the produced samples into the device, and the scanning throughput supports 240 tablets each time. Fiber Diameter Calculation AI automatically perform diameter measurement on samples, and accurate diameter measurements can be carried out in complex samples and environments. Multiple Remote Audits Support multiple people to review the same fiber simultaneously through the cloud, and the report is more accurate. as long as there is a network and a computer, you can work. Data Cloud Storage The data stored in the cloud will not be lost, and you can view it at any time Automatic Reporting Automatically generate statistical reports for measured data without manual participation Main Technical Indicators of The Product Scan Range Maximum scanable area:29mm×18mm Objective Lens 20time (magnification 200 times), 40 times (magnification 400 times), 100 times (magnification 1000 times) Slide Loading Up to 240 slides (30 /box, load up to 8 boxes at a time) Scanning Speed not less than 0.75 cm²/min Scan Resolution ≤0.2um/pixel Image Deformation Error less than 1 Pixel/mm Support Picture Format jpg,tif External Dimensions L x W x H:1090mm x 660mm x 1450mm Product Weight (Net Weight) 400±2Kg Single Sample Report Time 3min/each Scan Rate Sample Size Per Day More than 200 copies Equipment Operation Stability 24unattended operation on the hour https://www.tanvint.com/en/
Tanwei -
