04/09/2025 at 16:02 #3825
https://www.jindoor.com/Sectional-High-Speed-Rolling-Doors.html
Sectional high speed rolling doors are increasingly used in modern industrial facilities due to their ability to combine durability, safety, and efficiency in one system. Unlike conventional rolling shutters or standard industrial doors, these doors feature a segmented design with advanced mechanical and control components that ensure reliable operation in demanding environments. Shanghai Jindoor Technology Co., Ltd., as a professional manufacturer, offers sectional high speed rolling doors that are engineered for long-term performance and tailored to meet the needs of logistics centers, warehouses, manufacturing plants, and cleanroom facilities.
1. Door Panel Segments
The defining feature of a sectional high speed rolling door is its segmented door panels. Instead of a single large curtain, the door is constructed with multiple insulated sections that are joined together with hinges. This segmented structure provides superior strength and rigidity, allowing the door to withstand wind pressure, frequent cycles, and mechanical stress. Additionally, the panels can be designed with thermal insulation materials or transparent acrylic windows, providing both energy efficiency and visibility where required. The modular design also makes maintenance easier, as individual sections can be replaced without dismantling the entire door.
2. Track System
A precision-engineered track system guides the movement of the segmented panels during opening and closing. The tracks are typically made of high-strength galvanized steel or aluminum alloys, ensuring corrosion resistance and smooth operation. Depending on the installation site, the tracks can be designed for vertical lift, high lift, or low headroom lift configurations, making them adaptable to different ceiling heights and building layouts. The advanced track design minimizes friction, reduces noise, and guarantees that the door operates at high speeds while maintaining stability and alignment.
3. Motor Drive System
The power source of a sectional high speed rolling door is a high-performance motor drive system. Equipped with frequency inverters, these motors allow precise control of speed acceleration and deceleration, reducing mechanical wear and extending service life. The motor can be configured for direct drive or chain drive depending on the door size and operational requirements. With high torque output and rapid response, the motor ensures that the door opens and closes within seconds, improving logistics efficiency and minimizing air exchange, which is particularly important for temperature-controlled or dust-sensitive environments.
4. Control System
An intelligent control system is the core of modern sectional high speed rolling doors. Advanced PLC-based controllers integrate multiple functions such as torque monitoring, obstacle detection, and emergency stop mechanisms to ensure safe and reliable operation. The system can be connected to sensors, remote controls, card readers, or building management systems for seamless integration into facility operations. For safety, photoelectric sensors and bottom safety edges detect obstructions and prevent accidents. Additionally, the control system can be programmed for automatic opening and closing cycles, making it highly adaptable for areas with high traffic flow.
The structural components of sectional high speed rolling doors—segmented door panels, track system, motor drive, and intelligent control—work together to deliver a product that is both robust and efficient. These doors provide faster opening speeds than conventional sectional doors while maintaining durability and safety, making them an ideal solution for modern industrial facilities. Shanghai Jindoor Technology Co., Ltd. continues to refine these technologies, offering customized solutions that enhance productivity and provide long-term value to clients worldwide.
Shanghai Jindoor Technology Co., Ltd. -
