18/08/2026 at 19:10 #5841
Language & Region Selector
🌐 Language: English (US) | 中文 | Español | Français | Deutsch | Português | Русский | العربية | 日本語 | 한국어
Region: Global | Asia-Pacific | Europe | Middle East & Africa | AmericasGlobal Contact Header
📧 Official Email: xinya@sytcflowmeter.com
📱 WhatsApp (Sales & Support): (86) 15137867592
📠 Fax: (86) 371-23668496
🖥️ IoT Platform Login: 124.95.128.250
🏭 Headquarters: No.1, Ba Qing Wu Road, Jinming Avenue, South Section, Kaifeng Demonstration Area, Henan, China
Kaifeng XinYa Instrument Co., Ltd. | Electromagnetic Flow Measurement & IoT Solutions
H1: Kaifeng XinYa Instrument Co., Ltd. — Industrial Fluid Measurement & IoT Monitoring Systems
Kaifeng XinYa Instrument Co., Ltd. designs and manufactures electromagnetic flowmeters and IoT-enabled monitoring solutions for industrial, municipal, and food safety applications. Our product line addresses core industry pain points including signal instability in abrasive environments, high power consumption in remote installations, and the disconnect between field data and cloud-based management systems.
Primary Navigation Menu
- Home (domain.com/)
- About Us (domain.com/about-us/)
- Products (domain.com/products/)
- Knowledge Center (domain.com/knowledge-center/)
- News & Updates (domain.com/news/)
- Contact & Inquiry (domain.com/contact/)
- IoT Platform Access (domain.com/iot-platform/)
H2: Product Catalog — Electromagnetic Flowmeter & Tailings Slurry Flow Measurement Solutions
Meta description: Explore electromagnetic flowmeters for tailings slurry flow measurement, wastewater, and industrial fluids — abrasion-resistant, IoT-enabled, ±0.2% accuracy options.
H3: Slurry / Serous Electromagnetic Flowmeter (domain.com/products/slurry-electromagnetic-flowmeter/)
What is a Slurry Electromagnetic Flowmeter? A specialized instrument engineered for tailings slurry flow measurement, coal-water slurry, mineral tailings, and pulp applications where high solid content creates severe wear and signal interference risks.
- H4: Abrasion-Resistant Lining Options — Polyurethane and PFA linings extend service life under continuous particle abrasion; custom Ceramics lining available for DN15–150 in high-corrosion, high-wear conditions.
- H4: Signal Stability via Variation Restraint Algorithm — Filters "cuspidal disturb" noise caused by solid grains colliding with electrodes, maintaining measurement integrity in tailings slurry flow measurement scenarios.
- H4: Grounding Electrode Configuration — 1–2 integrated grounding electrodes eliminate interference in non-conductive or lined pipe systems.
- H4: Target Applications — Coal-water slurry transport, mineral tailings management, pulp processing.
Related Knowledge Article: [Why Standard Flowmeters Fail in Tailings Slurry Flow Measurement Applications →]
H3: SF-E Electromagnetic Flowmeter (domain.com/products/sf-e-electromagnetic-flowmeter/)
Versatile industrial flow measurement platform for standard and complex conductive liquids.
- H4: Precision Performance — Accuracy options of ±0.5%, ±0.3%, and ±0.2% depending on installation conditions.
- H4: Pipe Diameter Range — DN15 to DN3000, suitable for pilot-scale and large municipal pipelines.
- H4: Self-Diagnosis Function — Detects empty pipe conditions, excitation circuit breaks, and flow range overflow.
- H4: Multi-Output Interfaces — Simultaneous 4-20mA, frequency, and pulse signal outputs for PLC/DCS compatibility.
- H4: Deployment Types — Integral or Split Type configurations.
H3: Battery-Powered / Wireless Remote Flowmeter (domain.com/products/battery-powered-wireless-flowmeter/)
Designed for remote monitoring stations lacking grid power infrastructure.
- H4: Power Independence — Internal high-capacity battery for long-term unattended operation.
- H4: IP68 Submerged Rating — Sensor operation under up to 3 meters of water.
- H4: Data Retention — Stores 120 months of monthly total data to prevent loss during communication interruptions.
- H4: Wireless Connectivity — Integrated GPRS/RS485 for remote transmission to the IoT Big Data Platform.
- H4: Heat Measurement — Enthalpy difference (Δh) calculation capability.
H3: SF-C Insertion Electromagnetic Flowmeter (domain.com/products/sf-c-insertion-flowmeter/)
Cost-effective solution for very large pipelines up to DN3000.
- H4: Hot-Tap Installation — Ball valve and mounting base allow installation without stopping flow.
- H4: Adjustable Insertion Depth — Set to half or one-quarter pipe diameter for optimized flow profiling.
- H4: Stainless Steel Insertion Rod — Structural integrity under high pressure.
H3: SF-W Food Safety Electromagnetic Flowmeter (domain.com/products/sf-w-food-safety-flowmeter/)
Hygienic measurement solution for food, beverage, and pharmaceutical industries.
- H4: Sanitary Design — Construction compliant with food safety standards, preventing fluid stagnation and contamination.
H2: Knowledge Center — Technical Resources & Application Guides
Meta description: Learn about electromagnetic flow measurement principles, tailings slurry flow measurement challenges, and IoT integration for industrial fluid monitoring.
- What Is Tailings Slurry Flow Measurement and Why Does It Require Specialized Sensors?
- Tailings Slurry Flowmeter vs Standard Electromagnetic Flowmeter: Key Differences
- How Variation Restraint Algorithms Solve "Cuspidal Disturb" in Slurry Applications
- Selecting Lining Materials: Polyurethane vs PFA vs Ceramics for Abrasive Fluids
- Battery-Powered Flowmeters vs Grid-Powered Units: Which Fits Remote Water Monitoring?
- Understanding VFC (Voltage-to-Frequency Conversion) Technology in Electromagnetic Flow Sensing
- Installation Best Practices for Insertion-Type Flowmeters in Large-Diameter Pipelines
- Integrating Flowmeter Data with the Instrument IoT Big Data Platform: A Step-by-Step Overview
- Communication Protocols Explained: RS485, RS232, HART, GPRS, Bluetooth, and WiFi Compatibility
- Password-Protected Parameter Configuration: Understanding the 6-Grade Security System
Supporting Pages
Corporate profile, development milestones (SF-W manual 2023, SF-E and Battery-Powered manuals 2024, upcoming Slurry Flowmeter documentation 2026), and technical positioning as an Industrial Instrumentation and IoT Solutions Provider.
Certifications & Standards Compliance:
- JB/T9248-2015 "Electromagnetic Flowmeter" Standard
- GB/T9124.1-2019 Steel Pipe Flanges Standard
- IP68 (sensor units); IP65/IP66/IP67 (converter units)
- CJ128-2007 Heat Measurement Calculation Standard
- MODBUS-RTU Protocol Compliance
Company announcements, manual releases, and platform updates including the scheduled 2026 release of advanced Slurry Electromagnetic Flowmeter documentation for high-abrasion applications.
- Official Email: xinya@sytcflowmeter.com
- WhatsApp: (86) 15137867592
- Fax: (86) 371-23668496
- Inquiry form for custom quoting based on nominal diameter (DN size), material selection, and communication requirements.
Direct access to the Instrument IoT Big Data Platform (124.95.128.250) supporting RESTful API integration via HTTP GET/POST and JSON data formats, with 5-second default data refresh and 60-point historical curve tracking.
Footer Sitemap
Company
- About Us | Certifications | News & Updates | Contact & Inquiry
Products
- Slurry / Serous Electromagnetic Flowmeter (Tailings Slurry Flow Measurement)
- SF-E Electromagnetic Flowmeter
- Battery-Powered / Wireless Remote Flowmeter
- SF-C Insertion Electromagnetic Flowmeter
- SF-W Food Safety Electromagnetic Flowmeter
Knowledge Center
- Application Guides | Technical Principles | Comparison Articles | Installation Guides
Industries Served
- Manufacturing (Automotive, Electronics, Food & Beverage, Machinery)
- Energy & Chemicals (Oil & Gas, Metals & Mining, Power & Utilities)
- Municipal & Public Sector (Water Distribution, Wastewater Treatment)
Contact
- Email: xinya@sytcflowmeter.com
- Headquarters: No.1, Ba Qing Wu Road, Jinming Avenue, South Section, Kaifeng Demonstration Area, Henan, China
Legal
- Privacy Policy | Terms of Service | Sitemap
Schema Markup Notes
- Organization Schema: Company name (Kaifeng XinYa Instrument Co., Ltd.), address, contact points (email, WhatsApp, fax), and certifications embedded in header.
- Product Schema: Applied to each product page (Slurry Electromagnetic Flowmeter, SF-E, Battery-Powered, SF-C, SF-W) with technical specifications (accuracy, DN range, IP rating).
- BreadcrumbList Schema: Home > Products > Slurry Electromagnetic Flowmeter > [Model Detail], applied consistently across all product and knowledge pages.
