27/11/2026 at 16:52 #6783
2. Performance classification
EN ISO 5912 classifies camping tents by total weight — Class A at or below 2.5 kg, Class B above it — and then by climate grade: grade 1 for fair-weather short use, grade 2 for moderate conditions, grade 3 for all-climate and expedition use. The test battery covers tear strength, hydrostatic resistance, weather resistance, flammability and ventilation.
Grade is where buyers and factories most often talk past each other. A grade 1 spec quoted at a grade 3 price, or vice versa, is a specification error that no amount of quality control will fix later.
3. Chemistry
In the EU, REACH governs restricted substances in textile articles, including azo dyes and PAHs in rubber and plastic components. OEKO-TEX Standard 100 is voluntary but increasingly requested by retail buyers as evidence, and it is the fastest way to answer a chemical questionnaire.
Two components get overlooked: the printing on the carry bag, and the plastic pegs. Both are within scope, and both are commonly sourced from a different supplier than the canopy.
4. Systems and social audit
ISO 9001 and ISO 14001 cover quality and environmental management. SEDEX/SMETA and BSCI cover labour and social compliance. These are not product tests and they do not appear on a spec sheet, but for European retail buyers they are usually a gate rather than a score — you are either on the approved factory list or you are not.
Where programs actually fail
Across the four sets, the failure modes are remarkably consistent, and almost none of them are about the tent itself.
Sample-to-bulk drift. A hand-made sample passes; the bulk run uses a different fabric lot with different coating weight. The test report describes a product that was never shipped.
Pre-treatment skipped. Reports issued without leaching or weathering data get rejected at retail onboarding, usually four weeks before the delivery window.
Label and warning text. Care labels, fibre content and warning language are checked as strictly as the fabric. Localisation errors are common and entirely avoidable.
Children's product classification. A play tent sold as a toy falls under EN 71 in the EU and CPSIA in the US; the same item sold as camping equipment does not. How the product is positioned determines which test suite applies, and this decision is usually made by a marketing team, not a compliance team.
Report ownership. A test report issued to the factory is not automatically valid for the brand. Buyers should confirm in writing whose name is on the certificate.
The 2027 calendar
Compliance work has a fixed duration that cannot be compressed by paying more, which means the calendar matters more than the contract.
Window Activity Why it sits here Nov – Dec 2026 Range review, gap analysis against target markets Cheapest point to change material or supplier Jan – Feb 2027 Sampling, then third-party testing (typically 4–6 weeks including pre-treatment) Leaves room for one re-test without losing the season Mar – Apr 2027 PO placement, bulk fabric and hardware booking Coating lines and frame suppliers book out first May – Jul 2027 Production and peak-season shipping Container space tightens from June Aug – Sep 2027 Reorders, holiday and promotional programs Short-run top-ups at premium freight Two rules of thumb worth keeping. A standard production cycle runs around 60 days from deposit to shipment; add sampling and third-party testing ahead of it and a first-time programme realistically needs 90 to 120 days from brief to container. A repeat order with unchanged specification and an unchanged fabric lot can move in roughly half the time — which is why buyers increasingly ask for lot retention as a contractual term.
Model count matters too. A programme spread across five colourways and three sizes will not run like a single-SKU order even at the same total volume, because each variant carries its own sampling, labelling and inspection load.
What compliance costs, and how to budget it
Testing is rarely the largest line. For a typical programme, third-party testing runs to a few thousand US dollars per model family across the required markets, which is small against tooling and freight.
The real cost sits in three places:
Sample rounds. Each material change restarts testing. Locking specification before sampling is the single largest saving available.
Restricted material pool. Compliant flame-retardant finishes, low-PAH coatings and azo-free dyes narrow the supplier list and can add a few percent to fabric cost. This is not negotiable, and it is easier to price in at the brief than to absorb at the PO.
MOQ exposure. A compliance-driven material change late in the process can force a new minimum order quantity. Deciding specification early is, in practice, a working-capital decision.
A pre-PO checklist
Before signing, confirm in writing:
Which markets the product will be sold in, and therefore which standards apply
Whether flammability reports include leaching and accelerated weathering data
Whose name appears on the test report, and whether it transfers to your brand
The climate grade claimed under EN ISO 5912, stated numerically
Chemical status for canopy, bag printing and plastic hardware
Care label and warning text approved in every target language
The factory's social audit status and expiry date
Seven questions. In our experience, most sourcing problems that surface in July were answerable in January. If you are scoping a 2027 programme, send us the target market and the intended use — we will come back with the applicable test list before we quote a price.
FAQ
Is CPAI-84 still required in the US?
It remains the flammability methodology referenced by most US retailers and by several state regulations, and it is still the specification most buyers write into purchase agreements. Confirm the current requirement with your retailer and an accredited laboratory before finalising a specification.Can a CPAI-84 report be used for Canada?
Not automatically. Canada's Tents Regulations (SOR/2016-185) reference CAN/CGSB-182.1. Some laboratories issue reports against both, but they are separate documents and should be requested as such.What is the difference between EN ISO 5912 Class A and Class B?
Class A covers tents with a total weight at or below 2.5 kg, intended for light, short-duration use. Class B covers tents above 2.5 kg, intended for longer use and harsher conditions. Each class is further graded 1 to 3 by climate.How long does testing take?
Typically four to six weeks for a full battery including pre-treatment and re-test allowance. Plan for it inside the sampling window, not after it.Does a factory's ISO 9001 certificate cover product compliance?
No. ISO 9001 certifies a quality management system. Product compliance is demonstrated by test reports against the relevant product standard, issued by an accredited third-party laboratory.
About Sunhike Outdoor Gear
Quzhou Sanhe Outdoor Equipment Technology Co., Ltd. integrates tent design, development, production and sales in Longyou, Zhejiang, China. Our 18,000 m² facility employs more than 300 people, including 30 technical staff, across marketing, R&D, production operations, quality control and supporting functions. We bring 20 years of overseas market experience to programmes in Japan, the US, Germany, the UK and beyond.
Product lines cover summer shelters, beach shelters, family tents, inflatable structures, gazebos and kids playpens, supplied through OEM and private-label arrangements. Factory operations follow ISO 9001 and 5S, with factory audit support available, and products can be tested through BV and SGS against the standards your market requires. Standard MOQ is 500 pcs; samples are available at three times the unit price, refundable against the order.
http://www.sunhikegear.com
Quzhou Sanhe Outdoor Equipment Technology Co., Ltd. -
