25/08/2025 at 13:37 #3799
In modern kitchens, borosilicate glass food containers are becoming increasingly popular. Compared to traditional plastic containers, they offer advantages such as high and low temperature resistance, safety, environmental friendliness, and odor resistance, making them particularly suitable for storing and heating food. Whether refrigerated or placed directly in the microwave or oven, borosilicate glass food containers demonstrate superior performance. However, improper cleaning and maintenance can significantly shorten the lifespan of even the best containers and pose potential safety risks.
This article will provide beginners with detailed cleaning tips, key maintenance points, and precautions for borosilicate glass food containers, helping them to use them effectively in daily life, extending their lifespan and making kitchen life safer and healthier.
1. Characteristics of Borosilicate Glass Food Containers
Before delving into specific cleaning and maintenance techniques, let's first understand the basic properties of borosilicate glass food containers.
Strong resistance to high and low temperatures: Borosilicate glass can withstand temperature fluctuations ranging from -20°C to 400°C. This means it can be frozen in the refrigerator or heated directly in the oven or microwave, and is not susceptible to cracking due to sudden temperature changes. Safe, environmentally friendly, and free of harmful substances: Unlike some plastic food containers that may release harmful substances, borosilicate glass is BPA-free (Bisphenol A), making it a safe and environmentally friendly material suitable for long-term food contact.
High transparency makes it easy to observe food status: The transparent glass material makes it easy to check the freshness and storage condition of food, eliminating the hassle of frequent openings.
Resistant to odor retention: The smooth surface of borosilicate glass resists absorbing oils and food odors, making it suitable for storing a wide variety of ingredients.
Thanks to these characteristics, borosilicate glass food containers are becoming increasingly popular in homes, restaurants, and even offices. However, to keep them looking new for a long time, proper cleaning and maintenance are crucial.
2. Cleaning Tips for Borosilicate Glass Food Containers
Many novice users often overlook details when using the containers for the first time, resulting in scratches, incomplete cleaning, and even accidental breakage. The following cleaning tips will help you easily master the proper method. 2.1 Initial Cleaning Before Use
It is recommended that newly purchased borosilicate glass food containers be cleaned with warm water and a small amount of salt or baking soda. This not only removes any traces of the manufacturing process but also provides a preliminary sterilization.
2.2 Controlling the Water Temperature During Cleaning
Avoid suddenly rinsing containers that have just been heated with cold water, and do not immediately wash containers with hot water after taking them out of the refrigerator. Although borosilicate glass is resistant to temperature fluctuations, frequent rapid heating and cooling can increase the risk of cracking.
2.3 Choosing Appropriate Cleaning Tools
Recommended: A soft sponge, rag, or dedicated glass brush.
Avoid: Steel wool or hard brushes, as these tools can easily leave fine scratches on the glass surface, affecting its appearance and durability.
2.4 Using a Neutral Detergent
Avoid using strongly acidic or alkaline detergents. A mild, neutral detergent is recommended, which effectively removes grease and dirt without corrosively damaging the glass surface. 2.5 Focus on cleaning the container's rims and seals.
For borosilicate glass food containers with silicone seals, pay special attention to cleaning the rims and grooves. Oil or liquid residue left on them for extended periods can easily breed bacteria and create odors. It's recommended to remove the seals, clean them separately, and air dry them each time you clean them.
2.6 Tips for Removing Stubborn Stains
Tea or coffee stains: Mix baking soda with a small amount of water to form a paste. Apply it to the stain and gently rub.
Greasy odors: Soak in lemon juice or white vinegar for 15 minutes, then rinse with clean water.
3. Maintenance Tips for Borosilicate Glass Food Containers
If you want your borosilicate glass food containers to last longer, the following maintenance methods are essential.
3.1 Avoid Violent Impacts
Although borosilicate glass is relatively hard, it is still glass and can crack or even shatter if subjected to severe impact. During daily use, avoid direct contact with metal utensils. 3.2 Proper Storage
After cleaning and drying, it is recommended to store borosilicate glass food containers in a dry cabinet. If the containers are in sets, place a soft cloth or paper towel between stacking to prevent scratches caused by friction.
3.3 Regular Replacement of Sealing Rings
After long-term use, silicone sealing rings may age or deform, resulting in a loss of sealing performance. It is recommended to inspect them every six months to one year and replace them as needed.
3.4 Controlled Heating Methods
Although borosilicate glass food containers are microwave- and oven-safe, they should be heated away from direct contact with open flames or the heating plate of an induction cooker. Doing so may damage the container due to uneven heating.
3.5 Regular Deep Cleaning
Every two to three weeks, deep clean the container with diluted white vinegar or baking soda. This not only sterilizes and disinfects the container but also maintains its glossy, clear appearance.
4. Precautions for Using Borosilicate Glass Food Containers
In addition to cleaning and maintenance, the following points should be observed during daily use to avoid damage to the container or food safety issues caused by improper handling. Avoid refrigerating immediately after filling a container with hot liquids.
For example, hot soup or freshly baked food should be brought to room temperature before refrigerating.
Don't overfill food.
When storing liquid foods, it's recommended to leave 2-3cm of headroom to prevent expansion during heating or freezing, which could cause the container to crack.
Avoid cutting ingredients directly with the container.
Some people cut fruit or meat directly in glass containers, which can easily scratch the bottom and shorten its lifespan.
Check the container regularly.
If you notice cracks or chipping, stop using it immediately to prevent accidental breakage from high temperatures or impact.
Borosilicate glass food containers, due to their heat resistance, environmental safety, and beautiful transparency, have become a popular storage tool in modern homes and the catering industry. However, to maintain their performance and appearance over the long term, users need to master proper cleaning techniques and maintenance methods.
In daily use, beginners should pay attention to water temperature control, use soft cleaning tools, avoid strong acidic and alkaline detergents, and regularly check the integrity of the seal and container. Scientific cleaning and maintenance not only extend the lifespan of borosilicate glass food containers, but also ensure safe and healthy food storage.
As a professional borosilicate glass food container manufacturer, Bestfull leverages years of production experience and rigorous quality management to provide safe, durable, and beautifully designed food storage solutions for households and the restaurant industry worldwide. The company not only prioritizes its products' high and low temperature resistance and environmental performance, but also strives to optimize the containers' sealing and ease of use, ensuring consumers enjoy a high-quality experience during daily storage, microwave heating, and refrigerator storage. Through scientific cleaning and maintenance recommendations, Bestfull helps users extend the lifespan of their products while promoting healthy food storage, making it a trusted partner in kitchen life.
http://www.bestfulltech.com
bestfulltech -
