13/10/2025 at 15:10 #4046
iPhone14Pro users and repair professionals often encounter a variety of screen-related issues, from display flickering to touch sensitivity problems. Kelai’s JK FHD iPhone14Pro replacement screens are engineered to address these challenges with precision, durability, and high visual performance. With advanced LTPS in-cell technology, LED backlighting, and a wide viewing angle range, these screens ensure every repair meets professional-grade standards.
1. Screen Flickering
Problem: Flickering occurs when the backlight or display driver malfunctions, causing the screen to blink or display unstable visuals.
Solution: JK FHD iPhone14Pro screens feature a stable LED backlight structure and optimized display driver, eliminating flickering and ensuring smooth, consistent visuals.
2. Dead Pixels
Problem: Individual pixels remain black or colored, creating noticeable spots on the display.
Solution: JK FHD modules are produced under strict GMP standards with 100% quality inspection, drastically reducing dead pixels and ensuring perfect screen clarity.
3. Touch Sensitivity Issues
Problem: Screens fail to respond accurately to touch or show delayed response.
Solution: With in-cell touch panel technology, JK FHD screens restore precise touch response, ensuring smooth operation for typing, swiping, and gaming.
4. Color Inaccuracy
Problem: Colors appear washed out, oversaturated, or inconsistent across the display.
Solution: JK FHD iPhone14Pro screens maintain 90% NTSC color gamut, 6500K color temperature, and 1400:1 contrast ratio, delivering accurate and vibrant colors comparable to original displays.
5. Dim or Uneven Brightness
Problem: Backlight issues lead to dim or uneven brightness across the screen.
Solution: The 700±50 Cd/m² LED backlight ensures even brightness and visibility in all lighting conditions, enhancing viewing comfort and display quality.
6. Narrow Viewing Angles
Problem: Colors and brightness degrade when viewing the screen from the side.
Solution: JK FHD screens provide a full viewing angle range (ALL o'clock), maintaining color accuracy and clarity from every angle, perfect for multitasking and media consumption.
7. Physical Damage After Replacement
Problem: Replacement screens that are not precisely engineered can crack or misalign during installation.
Solution: JK FHD iPhone14Pro screens are engineered specifically for iPhone14Pro, with precise dimensions and reinforced build quality, minimizing risk during replacement and ensuring long-lasting performance.
From flickering to touch issues, dead pixels, and brightness inconsistencies, the JK FHD iPhone14Pro replacement screens from Kelai solve the most common screen problems quickly and reliably. Designed for both professional technicians and DIY repairs, these screens deliver premium quality, precise performance, and durability, making them the top choice for after-sales smartphone repairs.
Technical Specifications
Viewing Angle Range: ALL (o’clock)
TP Structure: In-cell
Backlight Structure: LED Backlight
Brightness Range: 700±50 Cd/m²
Contrast Ratio: 1400:1
NTSC (1931): 90%
Color Temperature: 6500K
Screen Size: 6.1 Inch
Screen Resolution: 1179×2556 (832×1804
https://www.jklcddisplay.com/
Shenzhen Kelai Intelligent Display Co., Ltd. -
