16/06/2025 at 20:40 #3280
In industrial production, workshops often generate large amounts of oil mist,
micro mist, and smoke due to the use of cutting fluid, coolant, and lubricating
oil, which not only endangers the health of employees but also poses potential
damage to equipment. To solve these problems, the Bodi Honor HCY-W6 centrifugal
oil mist collector has made a new appearance, creating an environmentally
friendly and safe production environment for enterprises.Efficient filtration principle: Triple filtration layer by layer
purificationHCY-W6 adopts an innovative triple filtration system to ensure that oil mist
particles are purified layer by layer from large to small, ultimately achieving
efficient air cleaning.1. Inlet: Optimize airflow distribution
Horizontal air intake design ensures that oil mist particles are evenly
dispersed into the equipment, laying the foundation for subsequent filtration.
Sealed design prevents leakage and ensures equipment operational efficiency.2. Initial filtration section: 20mm metal wire mesh filter
Intercept large particles of oil mist and droplets to achieve preliminary
separation. The metal wire mesh filter can be cleaned and reused, improving
equipment economy, while recycling coolant and reducing waste.3. Medium efficiency filtration section: F5~F8 medium efficiency filtration
cottonEffectively filters medium-sized particles and provides protection for
high-efficiency filters. Different filtration levels can be selected according
to needs, balancing purification efficiency and consumable costs.4. High efficiency filtration section: HEPA high-efficiency filter (H13
level)Capture ultrafine particles of PM2.5 and below, with a filtration efficiency
of up to 99.9%. Meet the purification standards of cleanroom level and
comprehensively improve the air quality in the workshop.5. Brushless fan: capable of infinite speed regulation
Support infinite speed regulation, adjust air volume according to actual
working conditions, balance energy consumption and performance. The fan operates
without friction and has a low noise level of ≤ 65dBA, providing a quiet
operating environment for the workshop.Highlights and core advantages of Bodi Honor HCY-W6
1. Harting connector: a new choice for intelligent industry
Modular design: supports multiple sizes and pin numbers, and can
simultaneously meet the needs of power, signal, and data transmission.High protection level: Excellent waterproof and dustproof performance,
suitable for various harsh environments, ensuring long-term stable operation of
the system.Easy to install and expand: Flexible interface design, supporting quick
installation and disassembly, suitable for the expansion needs of complex
production systems.2. Energy saving and environmentally friendly, quiet operation
Brushless fan technology not only reduces operating energy consumption, but
also controls noise within ≤ 65dBA, improving the workshop environment. The
filter has a lifespan of up to 8-12 months, reducing maintenance frequency and
consumable costs.3. Flexible installation, adaptable to various working conditions
Provide two options for top installation and side installation to meet
different workshop layout requirements. Support multiple accessory extensions
(such as pipeline systems, electrical control systems, etc.) to optimize the
user experience.4. Durable and easy to maintain
Alloy steel shell, designed for a service life of up to 20 years. Lock lock
hinge door design, quickly complete filter element replacement, saving time and
effort.Whether it is conventional machining of lathes and milling machines, or
high-precision grinding and gear machining, this small centrifugal oil mist
collector can provide efficient oil mist purification effect, meet the needs of
various equipment and scenarios, and assist in the construction of
environmentally friendly production and healthy workshops.Let HCY-W6 become the environmental guardian of your workshop, helping
enterprises achieve higher production priceshttp://www.bodhicollector.com
Wuxi BODHl Environmental Technology Co., Ltd. -
