28/02/2025 at 18:14 #2570
A Modular Approach to Energy Storage
RENOPI (Shenzhen) New Energy Technology Co., Ltd. is a 5.12kWh Rack Battery manufacturer. The 5.12kWh Rack Battery is built around a modular design philosophy that prioritizes flexibility and ease of use. Each module is designed to fit seamlessly into a standard 19-inch rack, making it an ideal choice for both new installations and upgrades to existing systems. This standardized approach not only simplifies the installation process but also ensures that maintenance and troubleshooting are straightforward and efficient.
One of the standout features of the 5.12kWh Rack Battery is its scalability. With the ability to connect up to 16 modules in parallel, users can achieve a total storage capacity of 81.92kWh. This scalability is particularly advantageous for businesses and industries that require large-scale energy storage solutions to support their operations. Whether it's a small residential solar setup or a large commercial facility, the 5.12kWh Rack Battery can be customized to meet specific energy needs.
Advanced Battery Management System (BMS)
At the heart of the 5.12kWh Rack Battery is an intelligent Battery Management System (BMS) that ensures the safe and efficient operation of the module. The BMS provides comprehensive protection against over-discharge, over-charge, over-current, and extreme temperatures. It also automatically balances the current and voltage of each battery cell, extending the overall lifespan of the module and maintaining optimal performance.
This advanced BMS is crucial for maintaining the longevity of the battery, which is rated for a 10-year lifespan at 25°C. The module can withstand up to 6500 cycles at an 80% depth of discharge (DOD), making it a reliable choice for long-term energy storage needs. The robustness of the BMS also ensures that the battery operates efficiently within a wide temperature range, from -20°C to 55°C for discharge and 0°C to 55°C for charging.
Eco-Friendly and Efficient Design
In addition to its technical prowess, the 5.12kWh Rack Battery is designed with sustainability in mind. The overall material used in the module is non-toxic and environmentally friendly, aligning with RENOPI's commitment to building a greener world. This eco-friendly approach not only benefits the environment but also enhances the appeal of the product for environmentally conscious consumers.
The module's efficiency is further enhanced by its compact design and high energy density. With dimensions of 482.6mm x 155mm x 460mm and a weight of 42.5kg, the 5.12kWh Rack Battery offers significant energy storage in a relatively small footprint. This makes it an ideal solution for installations where space is limited, such as urban residential areas or crowded commercial facilities.
Applications Across Sectors
The versatility of the 5.12kWh Rack Battery makes it suitable for a wide range of applications. For residential users, it provides a reliable energy storage solution that can store excess solar power generated during the day for use during peak hours or during power outages. This not only reduces reliance on the grid but also lowers electricity bills.
In commercial and industrial settings, the 5.12kWh Rack Battery can be used for load leveling, peak shaving, and backup power. By storing energy during off-peak hours and releasing it during periods of high demand, businesses can optimize their energy usage and reduce operational costs. Additionally, the module's ability to handle high discharge currents (up to 100A peak) makes it suitable for applications that require rapid energy release, such as electric vehicle charging stations.
Why Choose RENOPI?
Partnering with RENOPI means gaining access to a trusted and innovative energy storage solution. All RENOPI products are certified by TUV NORD and listed in the PV*SOL Database, ensuring that users receive products of the highest quality and reliability.
https://www.renopi.com.cn/
RENOPI (Shenzhen) New Energy Technology Co., Ltd. -
