06/05/2025 at 16:33 #2972
In modern office spaces and printing services, the neat binding of materials not only affects the professionalism of the documents, but also directly affects the efficiency and aesthetics of the work. Among the many binding methods, plastic binding combs have become one of the first choices for enterprises and individual users due to their easy operation, low cost, and strong reusability. However, many people will encounter a problem when using them: "What are the specifications of plastic binding combs? How should I choose?" If you have such doubts, then this article will give you a comprehensive analysis of various specifications and sizes, and teach you how to choose the right binding comb according to the usage scenario, so that the binding work is more efficient and the documents are more outstanding.
1. What is a plastic binding comb?
Plastic binding combs are a common office binding consumables, usually used in conjunction with binding machines, mainly used for binding documents, reports, manuals, textbooks, contracts, etc. It is long and has a toothed opening structure, similar to a row of combs, hence the name. When binding, the punched paper is embedded in the plastic comb teeth to achieve neat fixation of the documents.
Its advantages include:
Simple binding operation, suitable for large-scale document processing;
Can be disassembled and assembled repeatedly, convenient for adding and deleting document content;
Rich colors, meet the personalized needs of different occasions;
Low cost, suitable for large-scale office procurement.
2. Common sizes of plastic binding combsSize
packing
Pcs/box
Boxes/ctn
Pcs/ctn
Shape
6mm(1/4’)
White corrugated box
25
80
1000
round
8mm(5/16’)
25
80
1000
round
10mm(3/8’)
25
80
1000
round
12mm(1/2’)
25
80
1000
round
14mm(9/16’)
25
80
1000
round
16mm(5/8’)
25
80
1000
round
18mm(11/16’)
25
80
1000
round
20mm(3/4’)
25
80
1000
round
22mm(7/8’)
25
80
1000
round
25mm(1’)
25
80
1000
round
28mm(11/8’)
25
80
1000
round
32mm(11/4’)
25
80
1000
round
38mm(11/2’)
25
80
1000
round
45mm(13/4’)
25
80
1000
round
51mm(2’)
25
80
1000
round
25mm()
25
80
1000
round
28mm()
25
80
1000
round
3. How to choose the appropriate specifications according to actual needs?
Faced with so many types of plastic binding combs, first-time buyers are easily "dazzled". The following practical purchase suggestions can help you quickly choose the right model:
Choose the diameter according to the number of pages in the document
The most important thing is the diameter of the comb. If there are many pages, choose a large diameter; if there are few pages, choose a small diameter. Choosing a large diameter wastes costs and the binding is not compact; choosing a small diameter cannot fit, affecting the appearance and use experience.
For example: For a training material of about 75 pages, it is recommended to choose a binding comb with a diameter of 12mm or 14mm; if it is a 250-page product manual, you need to choose a binding comb with a diameter of 32mm or 38mm.
Choose whether it can be bound repeatedly according to the frequency of use
Some documents, such as contracts, project drafts, and continuously updated documents, need to be frequently disassembled and reassembled. It is recommended to use high-quality binding combs with flexible teeth and strong plastic flexibility to avoid frequent replacement.
Choose the number of holes according to the binding direction and format
For regular office environments and standard A4 files, just choose a 21-hole plastic binding comb;
If it involves American documents or special formats, please confirm in advance whether 19 holes or other specifications are required;
If horizontal binding and cross-page display (such as project display manuals) are required, special models such as 38 holes and A3 specifications can be selected.
4. Tips to improve binding efficiency
In addition to choosing the right size, mastering some tips can also greatly improve binding efficiency:
Pre-punching in batches: Before punching a large number of documents, you can batch them into 10-15 pages to avoid paper jams;
Marking order and content pages: Arrange the page numbers and order in advance to avoid confusion during binding;
Use a punch alignment device: It can effectively ensure that the hole positions are consistent and neat, and improve the appearance of the finished product;
Classify and store binding combs: Place them by color and size number to save time searching.
I hope the content of this article can help you no longer be confused when buying plastic binding combs, and easily find the one that suits you best. If you are the person in charge of office stationery procurement, the operator of a printing agency, or are interested in purchasing binding combs in large quantities, please contact us for more product information and customized plastic binding comb solutions!
http://www.mingyangindustrial.com
Hangzhou Fuyang Mingyang Industrial Co., Ltd. -
