04/09/2026 at 15:41 #5990
Combed cotton is cotton that has been put through an extra refining step — and it makes a dramatic difference in how your towel feels and performs.
Here is how it works: after cotton is harvested, the fibers go through a combing process that removes short, weak, and protruding fibers. What remains are only the longest, strongest, and smoothest fibers. These premium fibers are then spun into yarn and woven into towels.
Why this matters for your towels:
Softer feel: Short fibers have rough ends that can poke and irritate skin. Removing them creates a smoother, gentler surface.
Less lint: Short fibers are the ones that shed during washing. Combed cotton towels produce significantly less lint.
More durable: Longer fibers create stronger yarns that resist breaking and fraying.
Better absorbency: Smoother, more uniform fibers create better capillary action for pulling in moisture.
SEMAXE uses 100% combed cotton: Our combing process removes the short, scratchy fibers that make other towels feel rough. What remains are only the longest, smoothest strands — creating a gentle towel that feels soft from the very first use and gets even softer with every wash.
Sources: Textile industry standards, bed bath and table towel guides
What is the difference between combed cotton and regular cotton towels?
The difference is in the fiber preparation — and it shows up in everything from softness to durability.
Regular cotton (sometimes called carded cotton) goes through a basic cleaning process to remove debris, but it does not sort fibers by length. Short fibers remain in the yarn, creating rough spots, weaker points, and more lint.
Combed cotton goes through an additional step: a combing machine that removes short fibers and impurities, leaving only fibers of uniform length. The result is a smoother, stronger, and more consistent yarn.
Side-by-side comparison:
Feature Regular Cotton Combed Cotton Softness Can feel rough or scratchy Smooth and gentle Lint More shedding Less lint Durability Shorter fibers break more easily Stronger, longer-lasting Absorbency Inconsistent Superior moisture absorption Price More affordable Slightly higher, worth the difference The SEMAXE advantage: We use only 100% combed cotton in every towel — because we believe your skin deserves the softest, most durable, most absorbent material possible. The extra step in our process means a better towel for you.
Sources: Textile manufacturing standards, bed bath and table product guides
http://www.semaxe.com
SEMAXE LLC -
